Question about Sony VAIO PCV-W30 PC Desktop
Connect monitor - Sony VAIO PCV-W30 PC Desktop
How to connect 4 x HPL1706 monitors to a TV or PC/Laptop?
Did you try using a "Y" adapter cable. That would allow you to connect to two devices.
Mar 25, 2015 | HP L1706 17" LCD Monitor
How do i connect extertnal monitor
15-pin dsub (monitor connection on laptop - connect monitor there.
Then, find key with 'fn' in blue - find another key with image of two monitors (should be f5 key) - hold 'fn' key while pressing the two monitor key - will activate external monitor.
Aug 26, 2014 | Compaq Computers & Internet
Connecting my Dell Vostro 1400 to a Samsung S24B350H monitor
If the monitor has several video connections then you need to go into the monitor's settings and select the correct video input.
Mar 21, 2013 | Dell Vostro 1400 Notebook
Samsung Syncmaster 943b light blinking but screen remains blank, tested cables, message 'test good' flashes on screen then goes blank again.
try to connect monitor with other computer, this way u will confirm weather the fault is in monitor or in computer. if it is in monitor, check for bent pins in connectors which connecting computer & monitor, firmly connect both ends of connecter & tighten the screws. if problem not solves then u need to replace main board of monitor.
Aug 25, 2011 | Samsung SYNCMASTER 943B 19" LCD Monitor
I have sapphire ati radeon 5570 graphics card. i have aoc 912sw+ 19 inch lcd monitor. how to connect hdmi port of graphics card with monitor?
the HDMI port is for connecting video and sound to a home theatre / surround sound system. I understand that this monitor only has a VGA connector.
The sapphire ati radeon 5570 graphics card has the following ports on the back to connect to a display: DVI (white), VGA (blue) and DisplayPort (the thin slot in the middle). You can use an ordinary VGA cable to connect the card to your monitor.
Unfortunately you cannot connect this card directly to your monitor using the DisplayPort.
Hope this helps
Tom
Jul 21, 2011 | AOC 912SW-4 Monitor
Horizonal line in monitor screen cant seem to adjust
Try the following steps:
  1. On the monitor, press Menu, and select Factory Reset.
  2. If the monitor has more than one type of connection available such as VGA, DVI, or HDMI, try a different type of connection.
  3. Connect the monitor to another computer. If the line appears when the monitor is connected to the second computer, the monitor might be damaged or defective.Otherwise, the video card and driver is causing the problem from the computer. ry the following steps:
    3. Connect the monitor to another computer. If the line appears when the monitor is connected to the second computer, the monitor might be damaged or defective.Otherwise, the video card and driver is causing the problem from the computer. let me know if this resolved ur issue.. got plenty of resources to help u out.. regards guru
May 01, 2010 | Computers & Internet
Cant connect to laptop (only shows desktop no playback)
if u r connecting a laptop to an external monitor...just connect the monitor cable to the monitor jack in the laptop and u need to make changes to the display in the control panel...
Control Panel/Display/Setting tab/Advanced/Monitor or Display Tab...there u will get the choice to send the signal to either the monitor or laptop display...
chose and freez the choice....
Dec 14, 2009 | NEC MultiSync FE700 17" CRT Monitor
I noticed that my monitor has an additional port to connect another monitor to but for some reason its not recognizing the monitor
Is that a port for an additional monitor or is it simply an alternative method of connecting the monitor to the PC. My monitor has a vga input along with a dvi input and a hdmi input. These are all inputs not outputs.. Unless the port is specifically labeled as an additional monitor output, the chances are its an input.. You may have to use proprietry software to make any additional outputs available.. if the monitor is a Samsung, go to the samsung website and search for the monitor model. or read the manual..
Nov 02, 2009 | Sony DELUXEPRO SDM-X82 18.1" LCD Monitor
I want to connect my new monitor to an older computer (6 years old 1.3 Ghz) and the monitor says only CHECK SIGNAL CABLE) I checked them already and they are properly connected. The same thing when I...
If you can successfully connect another (second) monitor to your notebook and the Flatron will not work in the notebook I would be suspicious that this new monitor has a problem. Check for bent pins in the connector.
If you have not previously connected a second monitor to your notebook use the Fn key and toggle the key on your notebook that switches between the notebook screen and the external monitor. (The key that has the image of 2 monitor screens, might be F4). If the new monitor then works it would point to a problem on the old 1.3Ghz.
Jul 09, 2009 | LG Flatron W2242P-SF 22" Monitor
Sony VAIO PCV-W30 PC Desktop Logo
15 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
