Question about Nike 7071/2 Eyeglasses
How do I remove the sweat's stain from my eyeglass?
Is ge doing anything about mold issue in their refrigerator model zir36nmarh
It is very easy to prevent and/or remove mold once formed.
Mold usually forms around the freezer doors an the door gasket. This usually happens in a humid climet when the "Energy Savings" mode is on. That causes sweating on the door frame followed by mold and black residu.
PREVENT MOLD BY TURNING THE ENERGY SAVINGS OPTION OFF!
You can usually turn it on during the winter, when home heating is running and humidity is low.
Remove mold from door gasket by applying any spray cleaner that contain Bleach or just use towel with bleach. For very dark stains, allow the bleach to stay for about one hour, it will remove most stains
After cleanup, using you finger, redress the door gaskets with a very light coat of common Petrroium Vaseline. This will leave the door gasket soft and protected for a long time.
Jun 02, 2014 | GE Refrigerators
How can you remove scratches from eyeglass lens?
I'm afraid not. the light modern glasses, have a coating, trying to remove a scratch will remove the coating, and change the correct focus on that part of the lens. If the scratch is in the visible part, do you see a dull part, I'm afraid you have to buy a new glass. If it is not visible for you, try to live with it, till you need a new pair.
May 15, 2014 | Cameras
How do i get yellow sweat stains out of white sheets?
Wash your sheets on a long cycle with the temperature at about 30 degrees celcius. Put a cap full of white bleach powder directly into the machine with your sheets. This should do the trick.
Jul 11, 2013 | Home
Blood stain on my pants
Blood stains are considered to be organic stains because they contain proteins. Protein is the building block for nearly every living thing on the planet, but it's also what makes removing a blood stain difficult. Proteins react chemically and bind to one another; typically, you can't remove blood stains completely using traditional stain lifting methods. To remove blood stains from clothing, avoid exposing the garment to heat or hot water. Opt for using a natural enzyme to lift the stain instead of using bleach, or other chemical stain lifters.
Apr 11, 2013 | Health & Beauty
What causes yellow underarm stains on my shirt?
The yellow stains that appear on your shirt are usually caused by many factors including sweat, soil, stress and antiperspirant ingredients. In case some of these factors come together, yellow stains appear on your clothes.
Feb 03, 2013 | Health & Beauty
Which ingredients should I look for in deodorants?
You should look for aluminum salt. It closes the skin's pores and so helps reduce sweating. Some aluminum salts may leave stains on clothes, so make sure it does not get in contact too much. Next look for the ingredient Triclosan, this is an antibacterial agent. Body odor is caused by the buildup of bacteria in sweat so Triclosan effectively controls odor throughout the day.
Can the aluminum salt in the deodorant stain my shirt?
The aluminum salt closes the skin's pores and help reducing sweat. Some aluminum salts may leave stains on clothes, so make sure it does not get in contact too much.
Do I need to clean my exercise bike often?
I can tell you that I have an upright exercise bike for almost three years and I clean my bikes thoroughly once every two months, you should also see after each exercise if there is any sweat stains on the bikes and if there are clean it that is the best way I know.
Aug 09, 2012 | Exercise & Fitness
I have a GE side by side refer. model # GSS25PSM. I'm getting water leaking along the bottom of the ice/water dispenser flange, then down the door face staining the SS. Any ideas? Thanks!!!
Duct door. Look up where the ice comes through the door if it's sweating the duct door is not sealing and you will probably have frost in the chute on the inside.
Feb 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Brown sweat stains on outside of refrigerator doors
Open the refrigerator and look at the controls. There should be a switch there that says Energy Saver on one side and Moisture Control on the other, move the switch to the Moisture side. That should take care of it
Jul 14, 2009 | Frigidaire FRS23H5AS Side by Side...
Nike 7071/2 Eyeglasses Logo
613 people viewed this question
Top Nike Clothing Experts
ray gallant
Da Doc
Bill Boyd
Are you a Nike Clothing Expert? Answer questions, earn points and help others
