Question about Sony DAV-S400 System
Sony dav s400 protect sign?- HELP!
System just will not start now all i get is this protect sign in the window. My system will not do any thing, if it does start then any noise from the tvor speakers we just get this protect single Help
  • 2 more comments
  • george1971 Nov 20, 2007
    hi, all i get on the front of the panel was at first it said "HPTheatre" and now all i get is the "protect" sign and nothing will happen it is as if it has locked
  • Anonymous Apr 06, 2008
    aksecly the same problem! The "protect" sign!!
    i have opent it and i don't see a white cabel, on my right hand!
    I hurt a story off someone that he fix'it it with a hot tin shizzel!
    is that trouh? i ralley need some help!
  • Anonymous Apr 15, 2008
    I have the same problem but don't really want to be taking the thing apart? Any other suggestions apart from an out of warranty repair job? Also I notice that there are not many authorised Sony repair shops around...
  • dannymow Apr 29, 2008
    me too
 NAME:  POPOOLA SAMUEL OKE
EMAIL:[email protected]
open the system and remove the cables (white cable) that are installed on the panel at the right hand-side.Replace the dettach cables after 10minutes,couple the system back and insert your cd.
i am sure it will work fine.
nb: the white cables are about 5cables at different location on the panel.
Posted on Oct 29, 2007
    Fixya-Fanatic:
    Visited the website for 90 consecutive days.
  • 408 Answers
Hi, you have to unplug your unit and open it up you will see two printed circuit boards one slightly over the other at the back of the unit. You have to loosen the top one off so that you can get to the bottom one, turn the bottom over and take the protective copper board off wth care so that you can see the soldered joints. Check all large pole joints and re-solder as i had to do 14 joints also the brown capacitor was loose on my board and re-soldered that also. I found that the cable inside the unit that comes from the headphone socket,follow it to where it is connected to the bottom board, three of the soldered joint were loose and i re-soldered them also. Rebuild circuit boards into place dont forget to put the copper cover board back in place on the bottom circuit board. The above info i found on an internet site and followed the instructions my unit now works just as new. P.S. USE SMALL TIPPED SOLDERING IRON.
Posted on Apr 24, 2008
SOURCE:
Will DAV-S400 work with a Sony KDL37W5500 HD TV
Yes but only through scart cables, you will not get HD because your DVD dose not have HDMI output.
Nov 17, 2009 | Sony DAV-S400 System
Power protector on sony surround sound system
Power protect is an error message that some thing is wrong in your sound system and requires qualified tech.
Normally that error message appears when unit got problem in amplifier output section, either it is speaker problem or some output chip is fried.
Feb 25, 2009 | Sony DAV-S400 System
Installation instructions
Hi
here is a link to download user manual from sony...
http://support.sony-europe.com/hav/ha/hta/dav/dav.aspx?site=odw_en_GB&m=DAV-S400
click on user manual tab and you will see english plus other language versions.
Hope that helps?
Dec 20, 2008 | Sony DAV-S400 System
Sony DAV-S400 Laser Unit Replacement
where did you get your laser from as i need one for my sony hcd-s300
Nov 27, 2008 | Sony DAV-S300 System
Sony compact AV SYSTEM DAV-S400
Hi Joey - I had exactly the same problem.
In my case, I followed the advice of others and took the thing apart. On the main amp board there is a large brown capacitor. Mine had come completely loose, so I soldered it back in place with a good amount of solder to make sure the contacts were ok. I also dabbed some solder on the headphone connectors on the same board (just follow the wire from the headphone socket to the board). Well, when I put it back together and tried it again everything worked perfectly, and it has so far remained free from the error. Hope that helps !
Nov 14, 2008 | Sony DAV-S400 System
Sharp LC-32D44
Below picture shows Audio inputs of Sony DAV-S400 and you can hook up any one.
Go to menu of home theater system and enable surround.
Need further help, let me know please...
Oct 26, 2008 | Sony DAV-S400 System
Protect
The protect message indicates that a problem was found in the output stage of the amplifier. Unless this gets repaired, nothing will work. As a verification that the speakers or the wires are not the problem, unplug all of the speakers and try again. If protect still is displayed, the problem is inside the unit.
Dan
Apr 09, 2008 | Sony DAV-S400 System
Sony DAV-S400
You need to get a one off remote control from this company. http://www.dvdchips.co.uk/ It works I have unlocked mine.
Dec 04, 2007 | Sony DAV-S400 System
Sony DAV-S400 System Logo
783 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
