When i select a song it either does not work, it skips, or only plays in one headphone, i need help please.
When i try to play the songs on my MP3 the first song is like completely stopped and then the rest of the songs are like one second then the next couple of seconds it is really skipping...
Dear sudoorn,
- Check once again if the shake/shuffle is off.
- When using headphones be sure no to press any buttons on the headphones because some headphones skip songs (or rewind, pause etc.) by using such buttons.
If this is not the cas then maybe your headphones are broken and they give a false signal to your iPod to skip a song.
Hope this helped.
Kind regards,
FriskyR
Does the song play, or does it just keep skipping to the next song (does it show the song has length or not). If so it might be a dirty headphone jack.
okay if you notice, the headphone switch should have a + for increasing volume and a "-" for decreasing volume, in the middle is this groove part, which can be clicked aswell. Click the middle to play/pause. And double click it twice really fast to skip to the next song! Enjoy
Do you mean it plays a few seconds then skips onto the next song? If that is the case then most likely you have "Intro" play set which only plays a few seconds as a introduction then skips to the next time.
To fix this, during music playback, press the [menu] button, then there should be an option there to change it from "Intro" to "NORMAL" instead.
WAHA i've fixed it it was on repeat intro which means it plays the first quarter of he song so pretty much try to look at the repeat button and see if it is on that.....
We could try formatting the player and after the format has been complete try updating the firmware of the player. Change the settings fo the player to MSC then connect to your computer, open my computer and right-click the player and choose format remove the tick mark on the quick format and after the format has been completed. Unplug the device and go to the sandisk website and download the firmware update and install it and when it ask you to connect the device hook the plyer and perform the update for the player. Note: It may be the songs on the player are not that properly transferred that why it is skipping and also the player might also have had bad sectors that is why we have formatted the player. Hope this helps.
it keeps skipping and then it stops for a long time. i need help!
