Question about JVC HV-28P37 28" TV
Jvc tv model. HV-28P37SJE
Tv has red led lit. When I press channel button red led changes to green, tv emits a clicking sound but does not start, instead the red led comes solidly. Any ideas?
SOURCE:
techman
  • 3130 Answers
SOURCE: Progressive power up problem
Yeppers. Sounds like the standby power supply has a bad capacitor in it and the regulator Ic is defective. These parts should only be replaced by quilified technician as there is very high voltage inside these sets. Good Luck
Posted on Jun 14, 2006
techman
  • 3130 Answers
SOURCE: Video will not turn off; "I2C-BUS STOP MODE" error at power up
Nope a very easy problem .. What it is is the relay is stuck on or closed so when you plug in the set the power comes up But the micro hasent told the rest of the set to work yet. So when you hit the power button. its just like you hit the power and it activated the relay and the rest of the set. Now in some rare occasions the driver transistor for the relay was shorted But most of the time its the contacts that weild shut, but you cant just clean them as it will work for a while, but in a month or so you will be in the smame boat. But if you not a tech this repair shouldnt cost you to much because if your not an experienced tech you can not only cause harn to the set but also you yourself BE CAREFULL and take the set to a pro!!!! Good Luck
Posted on Jul 27, 2006
  • 87 Answers
SOURCE: Black Box appearing on my screen
Shut off the closed captioning and your problem will be gone.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Posted on Jun 26, 2007
  • 57 Answers
SOURCE: RED BLINKING TIMER TV WONT TURN ON
Page 40 on the PDF link below may help - Ask me if you need further assistance.
Thanks
Len
http://resources.jvc.com/Resources/00/00/99/51798Cien.pdf
Posted on Feb 28, 2009
ginko
  • 19396 Answers
SOURCE: TV wont power on, clicking noise and flashing standby led
To all the user with this problem.
The TV is on protect mode. The clicking sound is the protection switch that keep turning the TV off to prevent further damage, this happens when a fault had been detected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
Posted on May 15, 2009
How do i get the code to program a jvc tv wth my universal remoteserrial # rc24922-c1122
Do a code search method as follows.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/laura_08254539050d64db
Dec 26, 2014 | Universal Remote Control Televison & Video
Need the code to program my universal remote to my jvc tv the serial# to my remote is rc24922-c1122 model jc024
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Dec 26, 2014 | GE 24926 Glow Keys Universal Remote...
I have a jvc tv model number AV-27530 and a tv guide universal remote i need programing instructions
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
Jun 22, 2012 | JVC Televison & Video
How to program emerson jumbo universal remote to jvc tv model dvd component
Click here to download the user manual to Jumbo remote controls. it will have all details.
The common proceedings are:
Direct Code Entry
Code Search
Jun 21, 2012 | Televison & Video
Programing jvc remote control 076NOES010
Direct Code Entry
    Code Search Method
Apr 19, 2012 | JVC YQ20932 Remote Control
What is the universal remote code for JVC AV27D302
Hello
Four Digit Universal remote codes for JVC are:-
0060 _0026_ 0197_ 0069_ 0247_ 0923_ 0012_ 0065_ 0067_ 0141_0048
Three digit Universal Remote Code for JVC are:-
013/ 054/ 055/ 060/ 065/ 067/ 089
Direct Code Entry
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
Nov 20, 2010 | JVC AV-27D302 27" TV
I bought my son a 19" philips tv model # 19pfl340d/27.in order to turn tv on it must be unplugged for 10-15 minutes.The first one I bought did the same thing and I returned it.this one is exactly the...
The remote control will not operate the TV when the TV is in the OFF mode (No LED lit on front bezel). To change the mode from OFF to STANDBY or ON, press the POWER button on the side of the TV. Once the POWER button is pressed, the LED will change to either red to indicate STANDBY or green to indicate ON, whichever mode the TV was in prior to being turned off with the TV POWER button.
By pressing the POWER button on the side of the TV, the mode will toggle from OFF to either STANDBY or ON. If the POWER button is pressed and then the LED on the bezel is red, the TV is in STANDBY mode and will need to be turned on using the remote control. If the POWER button is pressed and then the LED on the bezel is green, the TV is ON.
Nov 11, 2009 | Philips 19PFL3403D/27 19 in. LCD TV
I bought a universal jumbo remote and i followed instructions i to program it to my Jvc tv but it does not work can u help?
Make sure you try every code in the list for your JVC TV.
The codes for your Jumbo Universal Remote to control a JVC television are 013, 054, 055, 060, 065, 067, and 089.
To program your remote by entering a code, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Enter the first set of 3-digit codes from the list. The LED will blink once every keypress. After the 3rd digit, the red LED will turn off indicating that the code was recognized for the device. If the code was not compatible, the LED will flash several times and you need to return to step 2 to try that code again or to try the next code in the list.
  5. After the LED has turned off, aim the remote at the TV and press ON/OFF. If the device turns off, you have used the correct code and the remote was successfully programed. If the device does not power off, return to step 2 and try again with the next code in the list.
To have the remote try each TV code it knows one at a time, follow these steps:
  1. Turn on your TV.
  4. Press the ON/OFF button slowly and repeatedly until the TV turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
I hope that helps.
Sep 24, 2009 | Innovage Jumbo Remote Control
JVC HV-28P37 28" TV Logo
49 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
