Question about Bosch 24 in. SHU43 Built-in Dishwasher
How do I access outlet hose on Blanco dishwasher BFD4X
Blanco Dishwasher BIDW605 does not
I would check the hose/water filters. make sure that you have proper flow from the hoses
Apr 04, 2008 | Dishwashers
Blanco dishwasher
Dishwashers do not usually complete the cycle if the water temperature is not adequate for the wash program selected. This could be due to inlet hot water not at correct temperature if dishwasher uses hot water or the heater or thermostat within dishwasher being faulty and not able to heat the inlet cold water to the right temperature. Try to run the dishwasher with the rinse or quick wash (low temperature) setting and see if it completes. Might help if you post the Model number in the comments field.
Apr 22, 2014 | Dishwashers
The water does not drain
Follow the below diagnosis:
1. Drain Hose
It is quite common for a dishwasher to not drain because either the drain hose or the air gap (if the unit has one) is clogged up. Drain hose clogs commonly occur where the hose is attached to the main household drain line, or where the hose connects with the garbage disposer. Try removing the drain hose to unclog any debris. Don't forget to reattach the hose before you start your dishwasher again.
Checking a drain hose
Note:
Disconnect the power source to your dishwasher before you conduct this or any other check. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel.
Before you can check your dishwasher's drain hose for a blockage, you have to gain access to the hose. First remove the lower kickplate panel located below the door. This panel can be removed by removing a couple of screws that are located either above or below the panel. On some models, the dishwasher door has to be open to access and remove the screws, but then closed in order to remove the panel.
With the panel removed, locate the drain hose. It is connected to the pump located below the lower spray arm. The drain hose runs from the pump to the sink drain, or to the air gap on top of the sink. There is a second hose leading from the pump that is a recirculation hose. When you are checking the drain hose for a blockage, you should check the recirculation hose as well.
Place a shallow pan below the hose to catch any spills. Disconnect the drain hose form the pump by pinching the wire clamp with pliers and then sliding the clamp up the hose. Remove the hose from the pump assembly and wiggle the hose in various locations. This may help to loosen the blocked debris.
Try running water through the hose to loosen and unblock the debris. A garden hose at full pressure is efficient to use for this task. Now disconnect the recirculation hose and check it for blockage in the same manner.
Once you have successfully removed any and all blockages from either or both hoses, reconnect each hose to the dishwasher. Replace the clamps, and replace the lower panel. Reconnect the dishwasher's power supply and run the dishwasher to make sure it is running proplerly.
Replacing a drain hose
Note:
Disconnect the power source to your dishwasher before you conduct this or any other repair. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel.
Before you can replace your dishwasher's drain hose, you have to gain access to the hose. First remove the lower kickplate panel located below the door. This panel can be removed by removing a couple of screws that are located either above or below the panel. On some models, the dishwasher door has to be open to access and remove the screws, but then closed in order to remove the panel.
Place a shallow pan below the hose to catch any spills. Disconnect the drain hose form the pump by pinching the wire clamp with pliers and then sliding the clamp up the hose. Remove the hose from the pump.
Reconnect on end of a new hose to the dishwasher's pump assembly and the other end of the new hose to the sink drain.
Replace the clamps, and replace the lower panel. Reconnect the dishwasher's power supply and run the dishwasher to make sure it is functioning proplerly.
2. Pump Assembly
The pump assembly is comprised of a pump, wash impeller, and drain impeller. The pump ejects the water from the unit, the wash impeller pushes water through the spray arm, and the drain impeller directs the water towards the drain port. Examine your dishwasher's pump assembly. Clean out any debris that may be blocking it. Replace the pump assembly if any of its parts appear to be worn or defective.
3. Belt
It isn't very common, but sometimes a dishwasher's pump assembly is driven by a belt. If that belt becomes worn and defective, then it cannot properly run the pump that drains your dishwasher's tub. If your dishwasher uses a drive belt, examine it now. If it shows signs of wear, replace it.
Examining a dishwasher belt
Note:
Disconnect the power source to your dishwasher before you conduct this or any other part examination. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel.
Locate and gain access to your dishwasher's belt. It will be located behind the lower kickplate panel. The belt will be made of rubber and will be about twenty-five inches long. Some are clear in color, while others are black. The belt will be looped around a pulley at the base of the pump assembly and around a pulley at the base of the motor. The motor will likely be towards the right, with the pump assembly located closer to the middle.
You do not have to move the dishwasher away from the wall in order to access and/or replace its belt. You only need to remove the lower kickplate/access panel. There will be a few screws holding the lower access panel in place. Remove these screws to remove the panel. You may need to first open the door to remove the screws, but then close the door to remove the panel.
With the lower panel removed, the belt is fully exposed. Closely examine your dishwasher's belt. You are looking for signs of wear such as little cracks in the rubber and places where the belt may be stretched. If you find signs that your belt is worn, replace it.
Replacing a dishwasher belt
Note:
Depending on how much your worn belt is stretched, removing it might not prove to be too difficult. Replacing it, on the other hand, may require some tight maneuvering. You might want to try this tip:
1. Place one end of the above the pump pulley, around the pump housing.
2. Place the other end of the belt around the motor pulley.
3. Carefully roll the belt down from the pump housing to the pump's pulley.
Good luck.
Jan 09, 2012 | De Dietrich Dishwashers
How do i install a motor on a blanco dishwasher bfdwc65
Hi.
The parts' arrangement is similar to several Whirlpool model. The pump motor is located under the bottom place and it is accessed removing the front kick panel (in front at the bottom).
Here a movie showing the procedure on a Whirlpool similar to your Blanco. I also tried to describe the procedure below. Check also the parts diagram for your model at the end of this comment. Sometimes it is not necessary to lean the appliance on one side, depending on how you can reach pump motor and hoses. See movie and description.
To remove the old motor you need to:
  1. Disconnect power.
  2. Move appliance forward.
  3. Disconnect drain and inlet hoses and remove water from tub (if any).
  4. Remove baskets or anything else from inside the machine.
  5. Remove spray arms and remove the assembly at the bottom of the machine.
  6. Put some clothes or towels on floor and lean the machine on one side.Water will leak out, the clothes will help here.
  7. Take the kick panel in front off.
  8. Undo the screws that hold the pump to the machine cabinet.
  9. Use a flat screwdriver to loose the clip holding the hoses. Loose the clip but do not open it completely (it will help later).
  10. Pull off the two hoses.
  11. Disconnect the electrical connector to the pump
  12. Lift the pump motor and pull it out from cabinet.
To put in new pump.
  1. Insert the two hoses on new pump.
  2. Set the clips.
  3. Put the pump motor in place inside the cabinet.
  4. Arrange hose and pump motor correctly and put screws back.
  5. Reconnect the wiring connector.
  6. Lift up the appliance.
  7. Put back spray arms and internal assembly.
Before putting on the front panel:
  1. Connect power and test for leaks.
  2. Disconnect power and fix any leak present (adjust hoses).
  3. If there is no leak put panel back.
  4. Set back the appliance and connect power.
Always observe strictly health and safety prescription. Disconnect power before performing any maintenance. Beware of panel's sharp edges, particularly when removing kick panel and accessing parts in the tight space under the bottom of the tub.
Here diagrams showing all parts:Exploded view.
Regards.
Ginko
Sep 07, 2011 | Dishwashers
Water not draining
There are several components to check when your dishwasher refuses to drain water. You need to check your drain hose, your pump assembly, timer, motor and drain valve and/or solenoid.
Most of the time it is the drain hose that is responsible for such problem. To check the drain hose, please follow the steps below:
  1. Disconnect the power source to your dishwasher before you conduct this or any other check. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel.
  2. Before you can check your dishwasher's drain hose for a blockage, you have to gain access to the hose. First remove the lower kickplate panel located below the door. This panel can be removed by removing a couple of screws that are located either above or below the panel. On some models, the dishwasher door has to be open to access and remove the screws, but then closed in order to remove the panel.
  3. With the panel removed, locate the drain hose. It is connected to the pump located below the lower spray arm. The drain hose runs from the pump to the sink drain, or to the air gap on top of the sink. There is a second hose leading from the pump that is a recirculation hose. When you are checking the drain hose for a blockage, you should check the recirculation hose as well.
  4. Place a shallow pan below the hose to catch any spills. Disconnect the drain hose form the pump by pinching the wire clamp with pliers and then sliding the clamp up the hose. Remove the hose from the pump assembly and wiggle the hose in various locations. This may help to loosen the blocked debris.
  5. Try running water through the hose to loosen and unblock the debris. A garden hose at full pressure is efficient to use for this task. Now disconnect the recirculation hose and check it for blockage in the same manner.
  6. Once you have successfully removed any and all blockages from either or both hoses, reconnect each hose to the dishwasher. Replace the clamps, and replace the lower panel. Reconnect the dishwasher's power supply and run the dishwasher to make sure it is running properly.
To replace the hose, please follow the steps below:
  1. Disconnect the power source to your dishwasher before you conduct this or any other repair. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel.
  2. Before you can replace your dishwasher's drain hose, you have to gain access to the hose. First remove the lower kickplate panel located below the door. This panel can be removed by removing a couple of screws that are located either above or below the panel. On some models, the dishwasher door has to be open to access and remove the screws, but then closed in order to remove the panel.
  4. Place a shallow pan below the hose to catch any spills. Disconnect the drain hose form the pump by pinching the wire clamp with pliers and then sliding the clamp up the hose. Remove the hose from the pump.
  5. Reconnect on end of a new hose to the dishwasher's pump assembly and the other end of the new hose to the sink drain.
  6. Replace the clamps, and replace the lower panel. Reconnect the dishwasher's power supply and run the dishwasher to make sure it is functioning properly.
That should do the job for you. And if that does not do it, then it means the problem is from other components of the dishwasher.
Hope this information helped.
Jan 15, 2011 | Dishwashers
Not draining
Jan 14, 2011 | Roper 24 in. RUD3000 Built-in Dishwasher
Water Won't drain fro the dishwasher model Blanco bfdw650s
If you "Lower" the hose to the bucket and it "drains" you are just using gravity to remove the water. The pump may be helping a little but if you raise the hose up and the water stops coming out, it's a good indication that the pump is bad. Unless the place you are attaching the hose to is plugged up, you need a new pump or a new impellor. Since the motor is good, try to get a replacement impellor, that the thing that moves the water. One other thing, you did say how well it washes the dishes? If the impellor is bad, it probably doesn't.
Sep 08, 2009 | Frigidaire 24 in. FDB126RB Built-in...
Leaking dishlex dishwasher outlet hose
HI If you get me the model#, I can look this up for you.
Thanks
Vic
May 23, 2009 | Dishwashers
Bosch 24 in. SHU43 Built-in Dishwasher Logo
18 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
