Question about Health & Beauty
Leaking dorf kytin sungle lever sink mixer upswept spout
  • 148 Answers
SOURCE: Bathroom sink ''mixer tap'' leaking internaly.
if your valve is single handle there is usually a small
button type of cover for (sometimes rubber the size of a pencil erasure) that covers acces to a hex key screw that you have to remove to remove the handle
once you have removed the handle you will need a large adjustable wrench to turn a large nut that holds the cartridege tighten if still leaks remove and replace you can math the assembly at HD or Lowes
Posted on Dec 30, 2008
sledge1863
  • 149 Answers
SOURCE: leak at spout pivot point on Kohler K-378 traditional kitchen fau
Not going to stop the leak by tightening. Go to local plumbing or home store and they make a repair kit that has the pieces to fix your problem. Also has a diagram on the back of the kit to guide you, its really an easy fix, shut off water under the sink, both hot and cold,and just remove the handle and unscrewing the top of the valve assembly. Good luck dont forget to rate.
Posted on Mar 30, 2009
  • 82 Answers
SOURCE: I have a slow leak coming from the spout
ooops, didn't mean for that to be a request, sorry...It was a solution. Although, if you dont want to deal with Moen, you can get one at your local plumbing suplly store. I recommend taking the old one with you (make sure you shut the water off first!). Again, good luck
Posted on Sep 03, 2009
  • 744 Answers
SOURCE: I just purchased a SS Franke sink which came with
There should be a large nut under the single lever faucet that can be tightened. If the sink is already installed, you will need a special tool called a "spud wrench." If not installed, you can probably tighten the nut with a channel lock or other adjustable jaw pair of pliers.
Posted on Dec 06, 2009
  • 182 Answers
SOURCE: When lever on tub spout is pulled up for shower
2 things can be happing here depending on the age of the tub spout. If the spout is more than 5 years old, you may need to replace it. if not that old then you may have a screen filter blockage in the shower head itself. remove the shower head from the shower neck and see if there is anything in the filter. while you have the head removed, try the tub spout again and see if problem continues. this should guide you in the next step to either replace the tub spout or just clean the shower head screen filter. Hope this helps.
Posted on Dec 29, 2010
How to repair kitchen mixer leaking from swivel not the tap
You will need to take handle of to see where the leak is coming from. It could be from the cart. or the spout o rings or both.
Aug 24, 2014 | Plumbing
Vessel sink
Hi, I presume you mean that the water spout is dripping when the taps are opened, remove the spout (it either unscrews anticlockwise using a tool or pulls up with force) , at the base is a o-ring that needs to be replaced, obtainable from local hardware store.Hope this helps. Don't forget to rate this help.
Oct 14, 2013 | Home
Oliveri mixer taps
turn off the hot and cold water supply, place a container under the sink where the hose meets the Sink mixer.
release the pressure from the tap by opening the tap to let the water out.
use a suitable tool to undo the flexible hose from the underside of the tap, there should be a small "O" ring on it which you will have to replace as the "O" ring is possibly the cause of the leak.
Oct 01, 2013 | Home
Faucet leaking at tee where hot and cold connect to spout
The designs of the Kitchen Sink Faucet mainly exhibit differences in its handles and spouts. Differently curved spouts and handles diversify the range of products. Some have long spouts and some are with short ones. The spouting of water may also give different flow patterns with the external fixtures. The handles are mainly in single or double.
source Best Kitchen Faucets
Feb 03, 2012 | Kohler FortĀ© Widespread Lavatory Faucet...
We have a wall mounted kitchen sink mixer with a swivel spout. Water leaks from the swivel connection. What material do I have to prepare before disassembling the spout? an "O" ring? some kind...
The spouts normally take an "O" ring seal and these should be freely available at larger hardware or faucet outlets. There may also be a plastic wear ring which does not seal and is not normally replaced unless the spout is loose in its fitting.
Feb 23, 2011 | Garden
Kitchen sink leak
Hi
Where is it leaking from? is it a single spout/mixer tap?
Please verify, and i should be able to help you
Thanks
Steve :o)
Jul 17, 2009 | American Standard Home
Leaking Kitchen Tap
I am assuming that your kitchen tap is leaking through the spout
if it is single lever you will need to remove the crown and spout by removing a small erasure size cap on the housing right under the spout or up near the back of the ever then use a hex wrench to remove the set screw( plug the drain holes do it does not go down the drain)
turn the water off (hot and cold ) under the sink
remove the set screw and lift off the lever
at his point you can take an adjustible wrench(channel lock and tighten the big ring nut that holds the cartridge in place
temorairly put the handle back on and put the handle in the off position turn the water on under the sink and see if it stopped leaking
if it still leaks you have to turn the water back off and remove the lock nut then the cartridge and go to big box store with old cartridge and name of mfg and get a new one and install
If you have seperate hot and cold valves on top of sink deermne which is leaking by turning one off with oher on undr the sink
once you have determined which it is (hot or cold)
take a phillips head screw driver( remove plastic clear cap on top of faucet handle with sharp crewdriver of knife blade) and remove the screw holdin the handle on to the stem(turn counter clock wise
be sure to turn water of under snk on both faucet risers after removing acrylic handle you then take an adjustible wrench and remove the crown nut turn counter clockwise until it comes off over stem
remove stem( looks like size of a pretzel about six inches long with washers on side and one on end
take the stem to local hardware(ace) or big box store and go to lumbing section ask clerk to inspect and recommend replacement washers or replacement stem (if needed)
go back reinstall and tighten crown nut snug( open (turn counter clockwise) tem valve before you snug it down with crown nut
install acrykic or chrome handle with brass phillips screw then ut cap on and turn on water and check for leaks
good luck
Dec 30, 2008 | Home
Dec 30, 2008 | Plumbing
Health & Beauty Logo
50 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
