I have sansui lcd tv 42" model SV4200lcd . After lieing around for six months without using it, i finally connected it. The picture is red with yellow colours around peoples faces, especially ears and neck. The commercials colours come ok but movies and everything else are horrible
ChadL777
  • 69 Answers
SOURCE: Color of people's faces in movies played via DVD is now blue since connected to LCD TV
The reason the picture is blue on the DVD is because you have poor video cables running the feed, probably RCA yellow cable im guessing. Get some nice component cables for the DVD feed and it will fix you right up.
Posted on Dec 26, 2007
  • 208 Answers
SOURCE: Coloured Pixels in or around black areas when watching TV
This is know as a diffusion issue. Most times this can be corrected with some minor alignment on the pots on the YSUS pwb. Sometimes the YSUS pwb has failed and will need to be replaced.
Posted on Feb 04, 2008
  • 191 Answers
SOURCE: Bad picture/colours on Samsung LCD TV
loretta change your power pack
entwined  try another cable
Posted on Nov 10, 2008
falter
  • 245 Answers
SOURCE: Hitachi 32'' lcd tv picture runs slow sometime and goes dark
go in touch wit HITACHI costumer help and service and tell them ur problem u have.....how old is ur TV?
hope u get a answer from hitachi....and good luck
Posted on Mar 12, 2009
ripleymojica
  • 643 Answers
SOURCE: Insignia 42 LCD TV Blurry Picture. Computer
tuner is going bad use a cable box that has hdmi or component video to bypass the tvx tuner
Posted on Jul 02, 2009
Cost to replace plasma on Sansui 42 inch TV
Hi Richard,
An original Sansui stand could be expensive try to find a universal stand to suit your TV here are some that should accommodate your TV: MISC STAND 3755BB 37 55 Lcd led plasma Stand
Jan 24, 2016 | Sansui Televison & Video
Hi I have teviono 42" lcd4203id model and tv is white picture nothing on there the TV powers up light comes on but it doesn't bring picture what the fault would be?thanks
TEVION 42" FLAT SCREEN LCD TV MODEL LCD4203ID
www.ebay.co.uk/.../TEVION-42...TV-MODEL-LCD4203ID-/1213...
eBayTEVION 42" FLAT SCREEN LCD TV MODEL LCD4203ID in Sound & Vision, Televisions ' eBay.Missing: white
main board for tevion lcd4203id 42" lcd tv mhdv4201 ... - eBay
www.ebay.co.uk > ... > Other TV & Home Audio Accs.
eBayMAIN BOARD FOR TEVION LCD4203ID 42" LCD TV MHDV4201-ZC01-01 (B) ... Mouse over image to zoom .... *Please open the back cover of TV then check the part number of screen, it would be on white label at back of screen ... of actual item in yourTV as well as check either if it is compatible with your TV model.
LCD TV Repair made easy # 1 - YouTube
? 7:38
https://www.youtube.com/watch?v=GryA_Zl4EBk
Aug 27, 2009 - Uploaded by Grants Pass TV Repair
I have a 2008 model Sanyo dp42848 42' lcd tv with ccfl lighting. .... bought a Seiki tv and within 1 month ...
LG 42LC2D 42 in. LCD HDTV Fusing unit - Que
Dec 29, 2015 | Televison & Video
Sansui 42 in no picture only sound
You should check the cable used, disconnect and reconnect from both TV and whatever it is connected to.
Jan 14, 2013 | Sansui HDLCD-4212 LCD TV
I have an LG 42" LCD tv with blurred image on half the screen
lg 42 in lcd tv power button blinks nine times before staying on and has sound but no picture
Feb 04, 2010 | LG 42LC2D 42 in. LCD HDTV
Hdmi cable is connected but no picture
sounds like the hdmi connection on the main board may be bad. try to use 2nd hdmi input if your tv has 2 hdmi inputs. trying using a a/v plug or rgb connection as well and see if you get a picture without the using the hdmi cord. finally, call tech support for you tv manufacturer and describe your problem and your troubleshooting and see if the issue is known and or covered by warranty. the service call is usually free. hope this helps
Apr 09, 2009 | LG 42LG70 42 in. LCD HDTV
PIP ON SANSUI LCD TV
Lets start at connections. What is your cable source? Do you have a converter or cable box connected to your TV?
YES : You must have two connections, so you will need to run a second coax cable from the wall. This can be a $10 fix and a 15 min hook up. (Ask if needed). You will also have to be using your TV through caox inputs (TV Source on TV)
NO: You will need a second line ran and hooked up to your TV input. (Ask If need specific hookup on model)
Feb 23, 2009 | Sansui HDLCD-2600 26 in. LCD Television
42 inch proscan lcd
If you use the connections for DVD you must use all of them.If you are using the standard yellow,white,and red connectors connect them to the connections listed as video and not the DVD titled connectors. But my advise is get an up converting DVD player and use a HDMI cable to get the best picture with out having to brake the bank buying a Blue Ray. I once connected a DVD player to my TV in the same fashion before finding out it only gives you a purplish black and white picture. Up converting DVD players can be bought around 30 dollars and up. A 6 ft HDMI cable will cost around 15 dollars. This way you will be getting the full effect and great picture your TV can produce.
Jan 31, 2009 | Proscan 42LA30H 42 in. LCD Television
42'' LG Plasma bought in Australia doesn't work in UK?
Find out if Australia uses a different standard of HD programming than Guernsey or not since it's not picking up any channels at all with an attenna. Does the skybox use only scart connections and that's how your small lcd is connected to it?
Nov 14, 2008 | LG 42LC2D 42 in. LCD HDTV
No picture
if nobody will repair the tv, then your probably better off buy a new one. yours could have the bulbs blow, there could be something wrong with the board or the power supply. i don't recommend working on a tv because they are very easy to mess up and do even more damage. for your next tv, get a higher rated brand like samsung or sony. they tend to be more reliable and are easier to fix/find somebody to fix
Oct 21, 2008 | Polaroid FLM-4201 42 in. LCD Television
Sansui Plasma, Green and Red Snow
I have the same tv - change the power supply. Corne Bronkhorst
Mar 14, 2008 | Sansui HDPDP4200 42 in. HD-Ready Plasma...
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
Electro Med Services...
