Question about Sony STR-DE835 Receiver
Subwoofer problem have had 3 different subwoofers on this unit they arent clear they hum something is wrong. Can you help me?
Are they self powered?
Posted on Dec 19, 2007
SOURCE:
Why does my HTS-20 powered subwoofer make a low hum when plugged in, even turned off and not connected to the receiver and a louder hum when the subwoofer power is turned on?
I suspect the amplifier is damaged. This is not an easy repair to do unless you are well versed in audio electronics. I would recommend a repair shop to look at the subwoofer amplifier.
Jun 03, 2015 | Infinity HTS-20 System
KLH HPS 1100 powered subwoofer. as soon as plugged into AC we get a loud hum from spkr. had unit for 8yrs.
Hum usually indicates a power supply problem. If it has an internal supply you will need someone to check it's producing clean DC. Alternatively if you do open it (beware risk of shock!!) initially visually check condition of /replace any bulging electrolytic capacitors.
Jun 27, 2014 | Audio Players & Recorders
After a power outage I have a loud hum.
Hi, The Ground Rules Of all the annoyances that can afflict any audio/video home theater or even a simple stereo installation, the notorious "ground loop" may well be the most difficult and persistent one to track down and eliminate. A "ground loop" is caused by the difference in electrical potential at different grounding points in an audio/video system. (All the grounds in an A/V system should ideally be at "0" potential.) A ground loop typically adds a loud low-frequency hum or buzz as soon as you plug in any of various audio or video components, including subwoofers, cable-TV outboard boxes, satellite-TV feeds, TV displays, amplifiers, A/V receivers or turntables. The buzz/hum is a byproduct of the multiple power supply cables and a ground voltage differential within your system and its network of interconnecting cables.
Here are some methods to help you get rid of ground loops. Try these first and don't waste money on a power "conditioner" which, in most cases, won't help. (There is no need to "condition" the AC power for your system. Your receiver or amplifier already has a power supply with its own filters and transformers. No further filtering is normally required.)
If you get your system up and running and hear an audible buzz or hum, the first culprit to look at is either the powered subwoofer or your cable-TV or satellite-box feed at the entry point to your system.
First, the subwoofer: unplug the coaxial cable that connects to your powered subwoofer to see if the ground-loop hum disappears. If it does, it's likely coming in through your cable/satellite TV feed.
Reconnect your subwoofer's coaxial cable from the subwoofer input to your receiver's subwoofer output and disconnect the cable-TV feed (or satellite feed) from your outboard set-top cable box or satellite tuner. Be sure and disconnect the cable before any splitters. Now see if the hum/buzz from your subwoofer stops.
If that eliminates the hum, you can install one of these inexpensive in-line ground isolators from Parts Express or Bass Home. Note that these transformer-based ground isolators will work fine with analog cable-TV feeds, but depending on their design they may interfere with or block reception of HDTV signals via a digital cable or satellite dish feed.
Install the ground isolator between the cable-TV feed and the input of your outboard cable-TV box or satellite tuner (or the TV display's antenna or cable input if you have a set with a built-in TV tuner or a cable-card ready set). In many cases, the ground isolator will "break" the loop and remove the annoying hum or buzz by isolating the TV-cable ground.
If a hum remains with the TV cable completely disconnected from your system, or you don't want to risk degrading reception of HD signals from a cable or satellite system, then you may have to add a ground isolator like this Radio Shack Model 270-054 between the line-level coaxial subwoofer cable from your A/V receiver and the line-level input jack on your powered subwoofer.
In all cases, if your subwoofer has a ground-lift screw like some of Axiom's subwoofers, try first removing the screw (or replacing it) to see if it increases or eliminates the hum. It may or may not make a difference.
If you do not have easy access to the aforementioned ground isolators, here are a few more tips:
Try plugging the subwoofer into a different AC outlet in the room, one that isn't supplying power to your components (A/V receiver, TV, cable box, etc.). That might fix it.
Try reversing the AC plug for your A/V receiver or the powered subwoofer. If it's a 3-wire plug or a polarized plug, which has one prong wider than the other, you won't be able to reverse the plug. For safety, do not use a "cheater plug" to bypass the 3-wire plug.
With the power OFF, reverse the AC plugs one by one of any other components that have a standard 2-prong AC plug that isn't polarized. Each time you reverse a plug, turn on the system with the attached component and your subwoofer and see if the hum disappears. In some cases, reversing one or more plugs will eliminate the hum.
If you have a turntable, try connecting a separate ground wire to a chassis screw on your preamp or receiver and see if the hum disappears. If you already have a turntable ground wire, try removing it from the preamp. One or the other may eliminate the hum.
Finally, here is another solution that worked well for a member of our message boards who decided to discard his ground-loop isolator on his subwoofer: "I took off the ground-loop isolator I'd been using and connected a plain 14-gauge wire to chassis screws on the sub and the receiver then powered everything on. Although hum was still there, it was far lower than before. Next I unscrewed the ground-loop screw on the back of the sub and that took care of the hum completely."
Almost certainly sounds like an earth loop to me, but can be caused by a poorly made transformer or phase shifts on the mains supply. Visit some power conditioner web-sites like Isotek or Isol-8 (or google "earth loop") where there's plenty of advice on how to reduce/eliminate earth loops and other causes of mains-induced hum (transformer problems etc).
Hum on the speakers usually indicates that there is a DC voltage on the speaker line. DC voltage on the output lines would be caused by a shorted output transistor.
Have a nice day...
Feb 16, 2011 | Cambridge Soundworks BassCube 12 Speaker
Sunfire MK II Subwoofer hum. I have a Sunfire MK II subwoofer that hums when it is plugged in (it even hums when no signal is connected). I've tried multiple outlets on different circuits, but hum...
you have a ground loop issue you could purchase a ground loop isolator, jensen makes them for about 40 bucks.I have discovered that if you have cable tv, unplug the incoming cable in your cable box and see if hum disappears.
Nov 25, 2010 | Sunfire True Sub MK II Subwoofer
My husband has a Pioneer 5.1 surround sound but the subwoofer is having an issue and not working. I think something got broke inside the plug. I am wanting to get him a new subwoofer but I am not sure if I...
So the unit that you are currently using is a blue tooth device or is not directly wired up and takes a signal from the amplifier ? If the subwoofer is wired up to other speakers that has the blue tooth receiver unit installed then you should be able to install a different subwoofer but if there is no wires that connect them together then the subwoofer must have a receiving device installed to pick up the signal
Nov 10, 2017 | Pioneer SFCRW230S System
There is no sound coming out of the subwoofer
I assume it's an active subwoofer, since it hums. Did you activate sub in the receiver menu? Did you turn up the volume on the sub?
Jul 08, 2010 | Yamaha HTR-5840 Receiver
Sub has started humming with amp turned off. just turned on at wall switch.nothing running
If the hum is from the back of the unit around the amplifier, it may be the transformer. It could be that the mounting is loose.
It could also be that the transformer is going out.
Disconnect all the inputs to the unit, Still hum?
If the hum stops you have something causing noise to the input.
If you have it on a switched circuit, try moving the power plug to a different outlet that is not on a switch. If hum stops, then you have something on that circuit causing the problem
if all inputs are disconnected and it still humms good chance it is the transformer.
Nov 12, 2009 | Velodyne CHT-8 Subwoofer
Sunfire Subwoofer 110 Noise on input plugin
A few more questions-
Does the sub hum without anything plugged into it except for power? If it makes a real loud hum almost a squeal then I think the rca cable between the receiver and the sub is dead shorted and needs to be replaced. If it's more of a low level hum, then it's a ground hum caused by many things, ie........the receiver and the sub being on different power circuits in the house.......sometimes diconnecting the cable tv feed as it enters the room while the sub is connected and humming to see if it stops........the easy fix sometimes is using a 3 to 2 prong ac adapter but lifting the ground on such a powerful amp could be a fire hazard.
Sep 25, 2008 | Sunfire True Sub MK II Subwoofer
Sony STR-DE835 Receiver Logo
76 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
