Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
Machine starts to fill then shuts off and starts beebing
    Champion:
  • 242 Answers
And displays a fault code.. check motor and RPS for corrosion.
Posted on Dec 21, 2013
Washing machine doesnt work kelvinator smartdrive 085 0.5kg
you have to check 1- water pressure switch (wps) , 2- the hose which fixed between wps and drum may disconnected or broken.
Jun 12, 2017 | Kelvinator Washing Machines
The dial tone is going beeb, beeb,beeb,beeb,but the phone is working ok,its like there is messages but it does not have answering machine
You may be subscribed to a voicemail system provided your telephone company. This system records messages when people call while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Jun 15, 2012 | Lands Phones
Hi there, I have a MW059NZ Smart Drive 9 Pride washer that has decided to stop working. Turn machine on (lights up ok) press start but nothing happens. Then a friend said to press power button and advance...
under the top of the machine on the right there is a reed switch which is actic=vated by a magnet in the lid remove the two bungs and screws so you can lift the top up a bit and you will see it there one screw to remove it if its corroded or swollen its faulty either repace it or as a easy fix cut both wires off it and join them together and tape up, this should do it
Mar 18, 2011 | Fisher and Paykel GWL11 Top Load Washer
Laptop beebs
if it starts then beeps then shuts off, turn around your laptop and take off the back plate and see if the fan is loose.
Dec 04, 2009 | Gateway 450ROG Notebook
Looking for a relay board #82127 Decor
Contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service wit your brand and model number and we can get the parts out to you right away!
We want to get you cooking again soon.
Nov 05, 2009 | Ovens
After filling, stops, lights up cold temp and beebs
are you using the pre soak cycle ? if so it wil start up after the soak time cycle is up.otherwise skip this function.
Jul 03, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Smart drive washing machine not filling properly?
sounds like you do have a solenoid problem undo hoses from back of machine check the filters are not blocked also check at the tap end to see if filter are cleare if all filters are clear most likely you will have to replace you inlet valves assuming there is no problem with pcb board.
Mar 29, 2009 | Fisher and Paykel GWL11 Top Load Washer
The machine does not work
Ok this fault is telling me you have a faulty RPS(Rotor Positioning Sensor) in this machine. The RPS sensor is located in the motor Stator. To replace you need to remove the motor rotor then the motor Stator. you want to be careful with this part when fitting it as they can break.
Please rate my advice.
Cheers
Steve
Mar 06, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
27 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
