Question about Gateway MX6956 Notebook
Sager 8880 wont run on ac adapter or charge battery, has new battery and ac adapter it does work with battery but now the battery is almost completely discharged and now i get battery light blinking and no ac adapter light showing connected, do i have to look for another mother board or is there anything else i can try. thanks for any help.
  • 386 Answers
Hi Kenneth,
Have you checked to see if the charge connector on the laptop is loose when you plug the charger into it? You can see if it is by plugging it in and wiggle it around a bit. The charge light on the laptop might stop blinking if its moved and contact is made.
Thanks,
Gary
Posted on Aug 01, 2013
Whisperwolf
  • 110 Answers
SOURCE: Gateway 450 ROG will run only on battery.
If it's still under warranty, it's definitely worth repairing. If not, get them to quote for the repair they say it needs before agreeing to it. If their quote is anything close to the current price, I would say it's not worth it.
Posted on May 26, 2008
Kegtapper
  • 94 Answers
SOURCE: MA2 laptop, not charging battery, changed burnt 4407 chip, no LED now.
This unit had a RED CHARGE error. Replaced PQ38 solved the problem.
If you get an error on the charge circuit after replacing the PQ38 you should also replace PQ38 because it too may be blown. Make sure Pin 1 where the dots. Also check the MOSFET on the other side of the COIL too.
Posted on Feb 19, 2009
  • 58 Answers
SOURCE: Gateway laptop AC adapter not working
Fixable? Maybe
Sounds like a problem with the power jack on the Motherboard. If so, it is possible to remove the board and replace the jack but this requires soldering skills and is probably not something the average person would want to try.
You might try another adapter to be sure but if it is a motherboard problem the best solution is probably to junk it and buy a new laptop.
Posted on Mar 14, 2009
  • 211 Answers
SOURCE: Intermittent dc jack connection for Gateway mx3215
Here is how to disassemble Gateway laptop,
Here is replacement DC socket (needs soldering),
Here is DC board (no need soldering, but expensive).
Hope this helps.
Posted on Mar 17, 2009
SOURCE: Gateway laptop will not charge battery.
I have a new gateway laptop with windows 7 and today it said plugged in not charging 8%. I tried everything and nothing worked so I turned it off and unplugged it and took the battery out and put it back in and it started charging...hopefully this works.
Posted on Jan 09, 2010
Asus ASUS A53U-ES21 wont power on
In order for the AC adapter to work the battery must be in good condition, why? Because the system runs of battery the AC adapter just keeps the battery charged up while in use, if the battery is open or defective the computer will not run on just the AC adapter.
Jul 12, 2012 | ASUS Computers & Internet
My advent battery would not charge so i bought a new one and it still wont charge having to run my laptop from the mains
You may have a DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
Mar 12, 2011 | Advent Netbook
My sons Dell Vostro 1500 has a problem with the AC adaptor. It will run the laptop but wont charge the battery. Any help will be appreciated. Thanks,David
If it will run off the AC Adapter but won't charge the battery then odds are it is the battery that won't take the charge and not the AC Adapter's inability to charge anything.
Google "dell vostro1500 battery" and change to shopping. You will see many available knock off battery's starting at 20 dollars.
Although AC Adapters go out too. They last a lot longer than batteries do. Today's batteries just don't last. I would say average life span is a year to a year and a half.
Jan 28, 2011 | Dell POWER SUPPLY Power Supply
Dell 2650 wont charge
run system diagnosis with dell cd. it will start when u boot ur dell 2650 with driver & diagnosis cd
Apr 01, 2010 | Computers & Internet
Toshiba Laptop Wont Boot.
yes,if the battery doesn't charge with the ac adapter or turn on with it pluged in.it is common on comuters for the power adapter on the motherboard to go bad after a while.downfall of the laptop is that it is very hard to replace it(desktop easy because it is not built into the motherboard)you can either buy a new motherboard or a new laptop.if you got any more questions feel free to email me at gamecrazy944@yahoo.com
Aug 03, 2009 | Computers & Internet
Bought a new battery and it wont charge, says on AC power
Take the Battery back Its defective , New batteries should charge for 18-24 hours, and the computer should tell u that it wont run till the battery is fully charged.
Jul 22, 2009 | HP Compaq Presario V2000 Notebook
When using ac adapter to my Tecra 8000 the power light is yellow
Try a new battery and if the new battery wont charge then its either going to be a bad ac adaptor or a bad motherboad. If the new battery charges then you'll know that the old battery went bad.
Mar 29, 2009 | Toshiba Tecra 8000 Notebook
Toshiba satelite A100 rejects AC... often.
Just to humor me, are you using any peripherals with your laptop when this happens, such as a wireless mouse, USB connections such as digital cameras? Try to take these away when recharging.
There seems to be 2 issues here.
1) Recharing batteries: To prepare the batteries for long-term use (I do not know how long you've had the batteries...try draining the batteries (both of them), and then recharging it to full 2x before using them without the AC Adapter. This should clear the problem.
2) AC Adapter only works every other day: When you swapped the power pack, was it with a new AC adapter, or another used one? Also, have you tried using a different outlet than the one you normally use? Let me know how this turns out.
Nov 17, 2008 | Toshiba Satellite A100-S8111TD Notebook
Toshiba satellite a100 wont take on power or boot
the battry is not charging and check the model of the battry whether its the same
Nov 16, 2008 | Computers & Internet
Gateway MX6956 Notebook Logo
171 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
