Question about Belkin F1DL102P 2-port KVM Switch
Kvm switch won't stay on second computer, switches back
Hello. I have had this KVM switch working for a few years now, although I did have some issues like what I'm going to describe at one point and they seemed to resolve themselves. I just got a new pc computer and got everything set up again. When I click the kvm to go to my mac, it switches over and I can see the mac desktop. However, it only stays for about 3 seconds and then switches back again. Also, I am randomly hearing the sound that I hear when I do switch over -- when I have not hit the kvm switch.
  • 1 more comment
  • relish27 Sep 04, 2007
    thanks for the response! one thing i tried (which seemed to work before) was just shutting everything down for a bit, unplugging things, and starting from scratch. it seemed to reset things.
    however, it didn't work this time. i'm also wondering what the lights mean on the switch. when i'm on my pc, both lights are on, but the one on the left blinks on and off like every 3 seconds. when i hit it to go to the mac, only the left one is on, for about 3 seconds, and then when it goes off (as it does on the pc), no lights are on and it switchs back by itself to the mac.
    do the lights mean something? like, is it saying that the mac is not getting enough power?
  • Anonymous Jan 14, 2008
    Exactly as described. PC1 shows on the monitor, I can switch to PC2 then back again - all fine! Then for no reason I can't switch to PC2 - it bounces!! PC2 shows blank for a second then straight back to PC1.
  • Anonymous Jan 25, 2009
    I have the exact same problem with my Belkin.  Thing is it worked well for a month and then when I click to go to the second computer, it reverts back to the first computer.
I got a new KVM switch and it works great. TRENDnet TK-207K
Posted on Sep 07, 2007
  • 20 Answers
You might try disabling any power saving schemes in use on either computer. The KVM (I believe) gets its power through the ports and one computer may be shutting down power.
Posted on Sep 01, 2007
SOURCE:
Screen resolution keeps switching
If its a usb kvm, check usb connections, one computer should stay fixed, the one that doesn't is your problem
Nov 21, 2011 | Belkin F1DF102PEA 2-port KVM Switch
New IOGear GCS632U KVM inop
First, disconnect the KVM switch from the computer(s). Disconnect also the keyboard and mouse from the KVM switch, including speakers (if there is). Leave the KVM disconnected for 5 minutes.
Before you reconnect the KVM switch, make sure that the computers are turned off. Re-connect the KVM switch to the computers, and then reconnect the keyboard and mouse.
Turn on the first computer, followed by the second one. If you are still not getting any light indicator, then the KVM switch is dead.
You may contact IOGEAR through 866-946-4327.
Thank you for using FixYa!
Jun 08, 2010 | IOGear GCS632U 2-port KVM Switch
How do I switch between computers using old Belkin 2-port KVM?
if i remember right, hitting the scroll lock key twice, and then pressing 1 or 2, depending on which box is your xp box.
hope this helps
Feb 16, 2010 | Belkin F1DK102P 2-port KVM Switch
Have a GCS634U KVM that keeps failing to switch. acts like it lost the keyboard
This GCS634U was designed to work with USB keyboards and mice.
First, you need to make sure that your using a direct USB keyboard (no PS/2 to USB adapter).
Second, connect the keyboard directly to the computer and make sure that it's working correctly.
Third, check the connection between the KVM switch and the computers. Try to connect the USB cables of your KVM into different USB ports of the computers.
Last, try to use different USB keyboard to see if the issue is the KVM or the keyboard.
Try to power cycle the KVM switch. Disconnect the KVM from the computers and make sure that there's no even one cable connected to the computers.
Leave the KVM switch disconnected for 10 minutes, then plug it back in. Reboot one computer first and wait until it's fully rebooted. Turn on the second one untill all computers are fully booted up.
If same problem occur, then you need to contact IOGEAR and have them RMA the device.
Thank you and good luck!
Nov 12, 2009 | IOGear GCS634U KVM Switch
Switch stopped working
Have you tried tapping the Scroll Lock key twice and then 1 or 2 for each PC?
Apr 15, 2009 | Belkin F1DK102P 2-port KVM Switch
Kvm stopped working
Have you tried tapping the Scroll Lock key twice and then either 1 or 2 for each PC?
KVM unresponsive
Greg,
Try swapping the KVM cables from the 2008 computer into the Vista computer and see if the problem follows the 2008 computer. This KVM gets the drivers it needs from the OS and the IOGear web site does not show any support for 2008.
Jan 16, 2009 | IOGear GCS632U 2-port KVM Switch
TrendNet KVM Switch tk206i work with 2 macs?
It should work with any type PC. I have a KVM switching between a windows machine and a linux machine.
Dec 02, 2008 | Trendware (tk206i) 2-port KVM Switch
Manual for the Protec Bytelan KVM/4
The switches are used when cascading more than a single BYTELAN KVM. It specifies the scan rate, and which KVM unit the keyboard and mouse are connected to. For a single KVM, use the default settings. SW1 SW2 Scan Rate ---------------------- ON ON 2 seconds OFF ON 10 seconds ON OFF 20 seconds OFF OFF 40 seconds SW3 NOT USED SW4 ON For KVM unit with KB/mouse OFF For other KVM units w/o KB/mouse, If your power supply isn't adequate, it may cause your KB/mouse problem. It should be 9VDC with at least 500ma. Hope this helps.
Aug 20, 2007 | Protec Microsystems Bytelan KVM/4 KVM...
Open Questions:
D link router tEcH SupPoRt pHoNe nUmBeR:~{-l84433O2330}^-} USAsary D link router tech Support Number +1{84433O2330}}USALogin Repair service center to resolve all D link router customer service phone Number products. D link router ROUTER is an American multinational company which was founded by Michael D link router ROUTER using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, D link router ROUTER support number, and selling of computer-related services and products. D link router ROUTER Tech Support Phone Number Recently, D link router ROUTER has been named the number D link router ROUTER technical support advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, D link router ROUTER customer care number can be dialed to contact the certified technicians Contact Technical Support Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a D link router ROUTER Service Tag or a D link router ROUTER Get D link router ROUTER Technical Support Phone Number and Customer Services. D link router ROUTER is a US-based multinational tech organization having its headquarters located in Round Rock, Texas. This tech organization supports, repairs, sells, and develops technology products. Basically, the company offers computer related products and services.
Oct 21, 2019 | The Computers & Internet
See all Belkin F1DL102P 2-port KVM Switch Questions
Belkin F1DL102P 2-port KVM Switch Logo
915 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Ekse
Pamela Bates
Pamela Bates
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
