Question about Mitsubishi WD65737 65" DLP TV
New device found mitsubishi wd60737 - Mitsubishi WD65737 65" DLP TV
2 Suggested Answers
  • 1572 Answers
SOURCE: HELLO i HAVE THE mITSUBISHI wd60737 AND IT WILL NOT TURN ON. IT BLINKS THREE GREEN LIGHTS LIKE IT GOING TO TURN ON BUT THEN IT BLINKS RED ONCE AND TURNS OF. i TRIED THE HOLD FOR TEN SECONDS RESET THIN
First make sure the filters and vents are clean and the filter cover(s) are properly installed.
Try once more (DO NOT RESET). As soon as the TV shuts down, press the ACTIVITY/ENTER button and the CH Down button on the TV (not the remote control) and hold them for 5 seconds. The Status LED will start blinking an error code. The "normal" code is 12, which would be one blink, pause, then two blinks and a pause. The code is repeated five times. Post your results in the comments; I can look up the code for you.
Posted on Jan 03, 2015
What is the correct part# for a DLP: Mitsubishi WD60737 60", Serial#139599 Made June 2009?
If your set worked well (no lines, maybe only white or black scattered pixels) before you replaced the DLP chip, then your problem could be that the DLP chip did not get seated properly or the cam screws were not tightened enough after replacing the chip. The DLP chip must be seated properly in its socket or else line and column lines will be seen. There is also the possibility that the DLP chip is defective or suffered static damage while being handled during the installation. Hope this helps.
Jul 11, 2016 | Mitsubishi WD Televison & Video
Jan 03, 2015 | Mitsubishi Televison & Video
Wd60737 mitsubishi 60"
how long has it been since you replaced the Lamp in the unit
Oct 20, 2014 | Mitsubishi Televison & Video
My mitsubishi wd60737 has black 2 inch stripe
Try pressing along the edge of the frame surrounding the LCD. Look for a disturbance in the "black line". If that shows up, you have lost the bond from the electronics to the LCD. Try using a piece of inner tube between the plastic frame and the chassis where you pressed to hold the connection together.
Sep 18, 2014 | Televison & Video
I have a Mitsubishi WD60737 TV! TV powers on and then powes off! Red light is blinking! HELP PLEASE!
Try to check the lamp if already faulty replace same type of lamp and be sure to reset lamp hour meter after replacing lamp good day and best regards.
Sep 04, 2011 | Mitsubishi Televison & Video
The "new device found" screen keeps popping up
Inspect for damaged pin on INPUT 1 socket. (left most of the three HDMI connectors)
A quick pull on the cable can damage the pins.
=== If you see mis-aligned pins then please power off the set before making corrective action. ===
============== Here's a textbook instruction from Mitsubishi
If the New Device Found Screen Displays No HDMI Control Option If the New Device Found screen shows no option for HDMI Control, one of these conditions applies: • HDMI Control is turned off in the menus of the new device Action: a. Highlight EXIT and press ENTER to close the New Device Found screen. b. Display the device's setup menus and enable the device's CEC capabilities. c. Wait for the TV's New Device Found screen to appear again. d. If the New Device Found screen does not appear, power off the device. Power on the device and wait for the New Device Found screen to display with the HDMI Control option.
Next time you see the NEW DEVICE FOUND screen pop up.
Toggle the CEC field (on the right side of the pop up) to OFF.
Jan 05, 2011 | Mitsubishi WD65737 65" DLP TV
Mitsubishi wd60737. It will turn on. Remote does work. Sound does work. But, the video won't show. It just stays black. There is a solid red light when it is off. Tried to reset it and it still did the...
make sure u set ur output to AV u will find this on ur remote control or on front of ur tv set
in regards ur tv will not show a picture since ur last adjustment try to go to menu and follow instruction how to set the tv back to factory setting......this may give u ur picture back......if not call mitsubishi service centre and tell them about ur problem u have......i am sure they will help u
Nov 28, 2009 | Mitsubishi WD-60737 60 in. HDTV
Mitsubishi WD65737 65" DLP TV Logo
18 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
