Question about Zinsco GTE Sylvania Electrical Supplies
I can not fine a GFCI Sylvania 20 amp circuit breaker, model 390-205-09, can you find me one
tjt3
  • 44 Answers
SOURCE: gfci breaker for spa
gfci's are designed to trip if they receive voltage on there ground/neutral side, therefore my vote is for Smithbrother I would say there is probably a partial short somewhere in you system.
Posted on Mar 24, 2009
  • 302 Answers
SOURCE: I just tested the breaker and it won't reset. I
yes. If you still have the fault it will not reset. Disconnect the out going wire to isolate the breaker and try again. If it still doesn't reset then the GFCI breaker is bad and needs to be replaced. Hope this helps you, Jeepfxr
Posted on Jan 28, 2010
  • 4090 Answers
SOURCE: I have a Sylvania circuit box and need to replace
There are literally dozens of brand options on the market. All are to specified standards. Contact any electrical supplier to obtain one for your system.
Please rate my help++++Thyanks for using fixya
Posted on Mar 21, 2010
  • 760 Answers
SOURCE: i bought a new GE 20 amp GFCI circuit breaker and
You can buy an inexpensive GFCI tester for as little as $10-$12. A better one with several mv settings will cost you a bit more. This way you can test this circuit and even GFCI receptacles. Then you'll know for sure if your breaker is working.
Posted on Nov 15, 2010
SOURCE: How to replace a Bryant GFCB120 Circuit Breaker
If you have a Bryant load center, you can use other breakers in it, including the Eaton GFCB120 GFI since several companies unified their design. The GFI (ground fault interrupter) or GFCI (ground fault circuit interrupter), same thing, may be required for a device you are installing, such as bathroom, kitchen or outdoor fixtures.
The Eaton series includes very clear installation instructions, but if your problem is that they are missing, then all you do is install the breaker in a open slot in the breaker panel, but you have to attach the neutral [white] wire differently. On regular breakers, the neutral goes right to the ground lug in the panel. With a GFI breaker, it goes through the breaker, and then is connected to the ground lug.
Posted on Mar 20, 2012
Can you ptu 2 wires on a sylvania circuit breaker
Yes, it is fine to put two wires on the output of a circuit breaker, but the wire sizes should each be suitable for the breaker size. That is, don't use two 14 Ga wires on a 20 Amp breaker assuming they will share the load. Each wire must be suitable for the full load the breaker will allow.
Nov 29, 2012 | Sylvania Electrical Supplies
What model Leviton GFCL should I use? My wire is a 600 volt 12/2 with ground. Said wire feeds other GFCL outlets.
Any off-the-shelf GFCI sold today with work on 12-2 wire:
By code, 12-2 wire should be connected to 20 amp circuit breaker, but typically most switches and outlets wired to that circuit are rated 15 amp. Amp rating is printed on electrical devices.
Leviton 15 amp 7599-W:
http://www.amazon.com/Leviton-7599-W-Receptacle-Feed-Through-SmartlockPro/dp/B000VYO9MU/ref=pd_cp_hi_3
Leviton 20 amp 7899-W
http://www.amazon.com/Leviton-7899-W-SmartlockPro-Indicator-Wallplate/dp/B000N663PM/ref=pd_cp_hi_0
Wiring:
http://waterheatertimer.org/How-to-wire-GFCI.html
Jun 17, 2011 | Leviton R01-7299-0NI Switch And GFCI...
I bought a new GE 20 amp GFCI circuit breaker and installed it to a new outdoor curcuit with two separate outlets. everything seems to work fine - polarities ok etc. connnected the white gfci line to the...
Nov 14, 2010 | General Electric 20 Amp, 1 Pole Thick Type...
I have a 15 amp air conditioner, with afci plug on a dedicated line, on a 20 amp breaker. Why does it nuisance trip, and not allow me to reset it, is it because of the 20 amp breaker? DRJ
It's definitely not related to the 20 Amp breaker. You do mean GFCI, right? The kind built into the end of the cord on the air conditioner, right? The GFCI is either detecting a ground fault (which means it's doing it's job and there is something wrong with the cord or the unit) or you have a bad GFCI. If the GFCI is in the wall receptacle, that could be a different story.
Jun 24, 2010 | Solar 15 Amp Murray Afci Circuit Breaker
I replaced the light fixtures in 3 bathrooms that are all on the same connection and now when I turn one of the lights on it trips the gfci breaker.
You have a ground fault on one of them. Disconnect the fixtures one at a time until the rcd (gfci) does not trip. then replace or repair the bad one.
Mar 26, 2010 | Sylvania Circuit Breaker - Zinsco/ 50 Amp...
GFCI on refrigerator circuit cuts off.
Yes. Refrigerators should not be on gfci protected circuits. They should have a dedicated 120v circuit .If your kitchen is new enough to be wired with gfci breakers ,it should also have an outlet dedicated for the refrigerator.
Dec 05, 2009 | Amana ARB2257C Bottom Freezer Refrigerator
Everytime I plug in the power cord, it trips the breaker.
Refrigerators are not designed to run on a GFCI. Try a heavy duty extension cord to the fridge from a outlet that is not GFCI protected. If it still trips you probably have a short circuit in the compressor.
May 13, 2009 | GE GTS22KBP Top Freezer Refrigerator
Gfci breaker for spa
Mar 15, 2009 | Spa Parts Plus GFCI, Circuit Breaker, 30...
Blown breaker
It sound like all of those go through your bathroom GFCI. I would recommend moving your outdoor circuit breaker indoors if possible or enclosing it to make it water-proof. You may also do some rewiring from your main breaker box ( if you are handy) to eliminate the outdoor box completely considering you have 100 amp / 200 amp breaker box inside your house. If you still have an old FUSE BOX with 60 amp service, I would recommend replacing it with a 100 amp or 200 amp breaker box depending on the size of your house. I would separate the laundry room by itself with 12/2 gauge wire with ground on a 20 amp breaker. You can then take your bathroom (using 12/2 gauge wire with ground keeping your gfci ) and run it to another breaker in the house with a 20 amp breaker or add a new one if there is room in your main box. Now all you have left is the porch light. You can run that separate from everything to your main breaker box using 14/2 gauge with ground to a breaker in your main box by adding a new 15 amp breaker or adding it to another 15 amp breaker that does not have a very high load such as a bedroom. In general Kitchens, Bathrooms, Laundry rooms should be on there own separate 20 amp breakers. Most every other room can be 14/2 with ground on a 15 amp breaker... hope this helps....Joe
Dec 17, 2008 | Prime 10 Amp Circuit Breaker
Electrical Supplies Logo
331 people viewed this question
Top Zinsco GTE Sylvania Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you a Zinsco GTE Sylvania Electrical Supply Expert? Answer questions, earn points and help others
