When iam going to on my hp color laserjet cp4525 printer it goes upto 6/6 on count after that it should be initialized but now it is not going to be initialize.... please help me
SparkGap
  • 363 Answers
SOURCE: hp laserjet 4550dn, how do you initialize thehard drive?
Try taking the disk out and format it on a PC first.
Posted on Nov 28, 2007
713printech
  • 32 Answers
SOURCE: HP color LaserJet 2600n stucked on Initialzing
Well we can check and see if the printer is able to run an engine test. This is how you can run this test;
  1. Turn the printer around so the back of the machine is facing you.
  2. Remove the Engine etest button acess door. This is located in the bottom center of the back.
  3. Push the botton once while the printer is on. The printer should print a page with colored horizontal lines.
If the printer is able to print this page there is a very good indication the problem revolves around the PCA formatter board.
The Firmware might be outdated and causing this problem. Worst case scenario the board might be faulty, in that case your better off buying a new machine, since the cost to replace the board will be higher than that to replace this machine.
Posted on Nov 19, 2008
SOURCE: eror message 49.4401 on hp clj 5550
Eror message 49.4401 on hp clj 5550
Posted on Dec 31, 2008
  • 19 Answers
SOURCE: HP 4600 Color Printer stays in "Initialize" Mode
If you are using a jetdirect network card it could be the cause of your problem. Pull the network card and restart the machine. Seen it a couple of times
Posted on Jul 28, 2009
SOURCE: no display in control panel
Had this problem after a power hiccup. The firmware on my HP 5550 / 5550n has been a problem in the past, needing updating or currupting, but this time I was getting the power on, a backllit control panel but no menus or text, and steady on READY, DATA and ATTENTION lights. At any rate I saw a solution on the Internet and owe that poster a beer if I can ever find him.
All things led to a corrupt Firmware. Problem and most beleieve you have to send for a new Firmware FlashCard and that takes time and big $$$. I found that if you can find another working 5550 / 5550n you can pop it's firmware FlashCard, make an image of it, and restore your own firmware to a working state.
The 5550 /5550n printers firmware resides on a 32MB Compact FlashCard on the printers Formatter Board. (The formatter board is held into the printer by 8 screws, and also has the JetDirect card on it.). This Firmware FlashCard when removed, will fit in a standard Compact FlashCard reader, and can then be attached to any Windows Machine for manipulation.
NOTE that this Compact FlashCard containing the printers firmware involves a proprietary HP created partition that a Windows PC cannot even read. Thus when connected to a Windows PC you'll see nothing, and may well be challenged to format the card!!! --- Obviously... DON'T DO IT !!
There is a FREE program called SelfImage available. Just Google: download SelfImage. The pesent version of SelfImage as of this writing is v1.2.1. It can and will see the contents of the FlashCard, and thus can make an image file of the FlashCard for use down the road. Should the firmware on the CompactFlash Card ever get corrupted, you can restore it from any image file by simply using the SelfImage program in reverse.
I made two image files of a good firmware flashcard from a working 5550 / 5550n because when you choose to make the backup image in this SelfImage program, you can do either the entire physical drive, or just a selected partition of a physical drive. In the case of this printer's firmware FlashCard, the drive and partition appear to be one in the same, as will be evidenced by the exact same file size of the resulting images. I made copies both ways (drive and partition) just be sure all possibilities were covered.
I now make copies of that Firmware everytime it's upgraded.
Posted on Jul 03, 2012
What does a fuser look like? hp cp4525 color laserjet? How to clear the error?
A 50.2 fuser error will on most cases require replacement of the fuser assembly. It is located on the right hand side of the printer. Same side as the manual feed tray. Open the door and look for two blue handles near the top of the opening.
May 09, 2015 | Rhinotek Digital Imaging Suppl HP Color...
How to fix hp color laserjet cp4525 error code 49.4B03
Disconnect all usb and network cables and cycle the power. If the printer comes to ready then chances are you do not have a "hardware issue". Most common cause of 49 errors is out of date firmware. If you search the tips I have posted there is a detailed one on how to upgrade firmware.
Sep 02, 2014 | HP "color laserjet enterprise cp4525dn...
HP CP4025N 59 CO EROR
Hi
probably this fuser unit is faulty, the other issue this machine uses the electric current 110 v or 220v
Jun 13, 2014 | HEWLETT-PACKARD 110v Fuser Kit Fuser Unit...
I JUST NEED ORDER NUMBERS FOR ALL THE COLOR LASERJET CARTRIDGES FOR CP4525 PLS. THANKS,
You can find the user's guide here which lists all the parts and supplies. Here's the cartridge information from the manual:
  • HP Color LaserJet black print cartridge Standard black cartridge CE260A
  • HP Color LaserJet black print cartridge High-capacity black cartridge for CLJ4525 models only CE260X
  • HP Color LaserJet cyan print cartridge Cyan cartridge CE261A
  • HP Color LaserJet yellow print cartridge Yellow cartridge CE262A
  • HP Color LaserJet magenta print cartridge Magenta cartridge CE263A
You can use the HP numbers to look for original or after-market replacements.
Apr 29, 2011 | Office Equipment & Supplies
Hello, I have a HP Color Laserjet CP4525. After it starts, it gets an error 59.CO error. Can you offer any advise to rectify this problem? Thank you
Its a 3 step process follow it it will fix your issue
1. Turn the printer off, and then turn the printer on.
2. Check and reseat the fuser and toner cartridge to make sure they are not hindering gear movement in the drive train.
3. Check the main motor's cable to ensure that it is seated properly. 4. If the error persists, replace the main motor.
Feb 28, 2011 | HEWLETT-PACKARD 110v Fuser Kit Fuser Unit...
HP LaserJet Color Laser Printer 4650dn printer displays 49.5001 Error
Try this....power cycle the printer. When the memory count starts Press and hold the MENU button.
Release the MENU button when all 3 LEDS are lit.
Press the < button
The display will show INITIALIZE DISKS if you did the above correctly.
Press the green CHECK button and wait for the printer to come READY.
Sep 08, 2010 | HP LaserJet 4650 Color Printer Manual...
Hp 9500hdn has error 8388D4 EIO devise 3 disk not funtional
Try the following steps to reinitialize the HDD:
1 Turn the printer off.
2 Turn the printer on.
3 Press and hold PAUSE/RESUME (LJ 9500) or START (LJ 9500mfp) on the control panel during the
memory count.
4 Hold PAUSE/RESUME (LJ 9500) or START (LJ 9500mfp) down until all three error lights illuminate
steadily.
5 Press (the 5 button on the MFP) until INITIALIZE DISKS appears on the display panel.
6 Press (the 6 button on the MFP).
7 The printer begins initializing the disk (this might take a moment). The control panel displays the
HP event logo and eventually displays READY.
Oct 02, 2007 | HP Color LaserJet 9500HDN Printer
81 people viewed this question
jasbo
jasbo
