Question about Numark PT01 Turntable
Power light and inconsistent speed
My "power" indicator light is flickering ever so slightly, and the speed of the turntable slows down ever so slightly as well, giving the record a warped sound. is this an electrical problem? what to do, what to do?
  • plsmith Jan 16, 2009
    same thing with the speed today for me! could it be overuse? i've only had it for 4-5 months, but i use it 8hrs/day for 5days/wk -- its my office turntable :)
    anyway, ill try unplugging, etc.
  • afhfahafsh Jan 25, 2009
    Yes I have the same issue. Not with the power light, but records fluctuate in speed. SO sad that I spent over $100 CDN and there is little support for it. What garbage this is.
  • 515 Answers
Ya, it does sound like a power issue. Unfortunately, for the cost of this model, it might not be worth getting repaired, although I am a big fan of recycling (let's reduce our waste!). As a service tech, I am forced to tell you that the cost of the repair will be around the $80 range, near the cost of this unit. Also, Numark does not provide much support for this unit. Parts are very hard to obtain from them, wait time is anywhere from 8-12 weeks. So, it's a matter of deciding what you want to do. Here are your options: 1) Spend the $80 or so (might be cheaper in your area - i'm in NYC) to get it fixed 2) Sell it to someone, tell them of the problem. Or better yet, give it to someone, and the cost of repairing the unit will be enough for them to have bought the unit. 3) Turn in to an elaborate paper weight! But please don't just toss it out. If anything, please drop it off at a plastic recycling plant. Lots of plastic in this thing!
Posted on Sep 01, 2007
  • TERMiNAL OPTiC
    TERMiNAL OPTiC Sep 02, 2007
    Something else came to me... you might also want to check the belt to see that it is not stretched, although this wouldn't cause the power issue with the light - unless they are 2 completely separate issues. But a stretched belt would cause a warped sound issue. The motor might also be bad, but again, this wouldn't cause the light to flicker.
    Lastly, I overlooked the obvious... as we all do... check your batteries (that is, if your running off the batteries).
I solved this problem by just stacking a few cds underneath the LP. The record was rubbing on the felty pads on the edge of the unit (weird call Numark :P), and making it slow down. the cds keep it up high enough to stop it from touching, even if I'm playing records that are a little warped. :)
Posted on Sep 14, 2012
  • 3 Answers
I have two of these units and it just seems to be a problem built in to the machines. However, I normally find that changing the power supply helps. My Ion PT01 was playing up today & I changed the power supply from the one that came with the unit to a 3rd party 12V transformer. Now it's playing fine.
Frankly - doesn't make much sense to me.
Posted on Feb 10, 2009
I had the same problem with my vinyl slowing down and what i found out what was slowing it down is the little felt pieces so i raised my vinyl with a little bit of sticky tac on the turn table and it raised it enough to play fine, this is my current set up but it is a pain because i have to re-set it every time and am looking for a more permanent solution. perhaps the solution will be buying a new table
Posted on Jan 31, 2009
Ok, it fixed itself. don't really know how, but after a couple of turns on and off, and a few unpluggings and head scratchings it's all better. i recommend this method.
Posted on Sep 03, 2007
Rear indicators work until headlights are switched on then they go dim
sounds like you have a sort in the electrics, check the connections and the bulb holder on the back lighting, and the wiring under the seat.
Dec 19, 2017 | 1997 kawasaki ZX-6R Ninja
My records that are 33 and 1/3 don't play at that speed on my turntable. they sound more like a 30 speed, what do I do
Hello Rosie,
Some turntables have a pitch adjustment feature which allows you to speed up or slow down your records. The adjustment controller is usually a slider or a wheel somewhere on the turntable and is usually labelled "Pitch" "Adjust / Adj" or "Pitch Adj".
Please check for this feature on your turntable then get back to me if you are unable to find it. Please include the brand and model number of your turntable.
Hope this helps.
Regards,
BElectric
Aug 17, 2011 | Audio Players & Recorders
Turntable is slow, especially noticable on 33 1/3 rpm
hi,
your turn table is a belt driven one. The speed turns down when the belt become expanded. you should replace the belt of your turn table. Also put some lubricant in its center shaft ( not from the top lubricate it slightly after removing the plater).
I have here added some video related to the replacement of belt for turntables.
Not the exact for your one,for all the belt driven turntable the procedure is the same
ok
Jan 17, 2011 | Crosley CR248 Turntable
I have a Sherwood PD - 913 R and the pitch seems to be spinning out of sync which makes the RPM"s not right for 33 or 45 speeds, any help on what could be the cause is appreciated. There is a pitch...
The turntable motor might be the problem, if the grease is old it becomes hard causing the turntable to run slow, by your description we can rule that out since you indicate it runs to fast. therefore it is the voltage that powers the motor with a regulator "keeps voltage constant" or the motor itself will be the problem. The pitch control allows a small change in speed when required.
Dec 30, 2010 | Audio Players & Recorders
Hi there. although my mk2 plays normally,sudenly i cannot hear it. i`ve checked wires and cartridge, what else it could be?
You need to check that the signal is getting to the amp. This can be done by removing the wires off the cartridge for the left and right channels. With the amp on touch the ends of the wires. If you hear a buzz the signal is getting to the amp and the cartridge is dead, but if you hear nothing and if the wiring is as you say good. Then the pre-amp in your amp for the cartridge has failed. This pre-amp will only affect the record deck and no other functions. If it has gone you can trace the wires from the sockets to it. Sometimes it will be on a seperate PC board. It's often a single IC that has failed. If you can replace it yourself be careful with the new one as these are often static sensitive chips.
PS the phono scokets on the amp sometimes buzz if you pull the plugs in & out!
Aug 08, 2010 | Technics SL-1200MK2 Turntable
Sound wavers (speeds up and slows down)
you need to replace the Pitch controls. I'm presuming it is a sliding pitch control. Use the Red start stop lights that reflect on the rotating wheel. put the pitch in center 0. does one row of the dots on the wheel stay completely still.now just turn it up op down a bit until it starts to move the dots slightly. now watch the dots now while there moving. Do they fluctuate they should be smoothe. do this on both decks to find out which one is fluctuating.
Jul 10, 2009 | Philips gemini XL-500 II Turntable
Turntable speed
There is no pitch control on this unit.
Apr 03, 2009 | Intellitouch Communications INTELLITOUCH...
Technics 1210 mk2 problem with pitch and lights
Check that your voltage settings are set correctly. This is located underneath your turntable platter. If you remove the slipmat, you will see 2 holes on the metal platter. Rotate the platter till you see the voltage switch, located @ the 9'o'clock position. Make sure it's set to your correct settings (N.America = 115V / Euro = 220V). If not, you will need a flat head screw driver to switch it. Before you switch it, make sure your unit is off and unplugged. After you swich it, it should be ok.
If your still having issues with the speed and the pop-up light, then there is something seriously wrong, and will need to be checked by a technician. Sometimes a resistor or IC will go bad, causing the speed issue, but for the pop-up light - that's usually faulty wiring generally caused by an incorrect replacement.
Did you buy this new or used? Have you had this serviced recently?
- TWEAK AV LAB
The ORIGINAL TURNTABLE Technicians
Nov 30, 2007 | Technics SL-1210 Turntable
Numark PT01 Turntable Logo
574 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
