Question about Electrical Supplies
Coleman pulse 1800ex manual - Electrical Supplies
4 Suggested Answers
SOURCE: Generator will not start
You say there is compression .What was the p.s.i. on the gauge. If below 100 p.s.i.. May have bad ring, valve out of adjustment or bad head gasket. Is there spark and what does spark plug look good, is gap ok . Is the fuel tuned on and kill switch on. Will need more info to help out more.
Posted on Mar 16, 2009
  • 6 Answers
SOURCE: i have a coleman powermate pulse 1800ex generator.
your main jet is plugged shut off fuel, remove bowl from carb(bottom of bowl) clean out small holes on screw with stranded wire .2 holes on side on in middle. be sure to put fiber washer back between main jet and bowl and use fresh gas jor
Posted on Feb 01, 2011
  • 122 Answers
SOURCE: I have a coleman powermate
try flipping the breaker or fuse this could be it or one of the wires came off the plug in or the plug went bad or the diod blew but all of these cane be fixed pretty easyjust need a meter to see what is bad good luck
Posted on Aug 03, 2011
I have a coleman 5317 RC series lantern that wont go into the dim mode what can I do
Hello. I've just looked at several Coleman lamps, some have krypton bulbs (mainly battery powered), some spiral fluorescent bulbs (mainly mains powered/charged). If this one is yours http://www.coleman.com/Parts/100/parts-lanterns/5317-702/remote-control-pack-away-family-size-lantern# then it appears yours has a spiral fluorescent bulb. Gas discharge bulbs commonly are fired up by an initial high voltage pulse then followed by a continuous ac medium voltage (say 80 volts or so) to give a FIXED LIGHT OUTPUT.
THIS DOES NOT ALLOW CONTROLLED DIMMING. Dimming can usually only be done on an INCANDESCENT TYPE bulb eg an older type tungsten filament bulb. These are however much less efficient.
So in summary, if you do have a fluorescent bulb, I don't know why your remote indicates you can dim it. You could try switching the bulb for an incandescent type, but this should only be attempted by qualified persons. Check over the user manual again. Good Luck.
Jun 17, 2014 | Coleman 5317-700 lantern - 8d square...
Coleman pulse 1750. Low volts
If you have checked the AVR you can disconnect the rotor brush wires and force a field in the rotor with a variable DC supply (note brush polarity) if the AC voltage comes up, then the problem is in the voltage regulator, if not you may have a rotating short in the rotor.(Only present with centrifugal force) I assume you have checked the resisitance of the stator and rotor windings
Feb 21, 2013 | Coleman Pulse 1750
I have a coleman powermate pulse 1800ex generator w/subaru engine. It runs and produces no electricity.
Aug 03, 2011 | Coleman Powermate Powermate 5000W...
I have a coleman powermate pulse 1800ex generator. It stutters when put in the run position. when in the choke position it doesnt stutter.
Jan 11, 2011 | Coleman 1850 Watts Generator Each...
Need manual for coleman powermate 1850 generator
google it! use the specific search terms, Coleman power pulse 1850 - it worked for me!
Jun 05, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
Mar 15, 2009 | Coleman Sport 1850 Generator
I want use oil for my coleman(powermate pulse 1800(subaru))
SAE 5W30 will do well unless you're in a very hot place, then 10W30
Carl
Mar 02, 2009 | Coleman Electrical Supplies
Electrical Supplies Logo
60 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
