Question about Refrigerators
I have a Kenmore COLDSPOT Model #106.9750312 that is dripping water inside the fridge lower unit. It appears to be something with defrost because I do not have water line hooked up for ice maker.
ctf1800
  • 4402 Answers
SOURCE: ICE MAKER NOT WORKING Kenmore cold Spot model# 106.55536400
there is some times a water relay that turns the water on and off the over heats, it located in the back where the water connects
Posted on Dec 08, 2007
  • 172 Answers
SOURCE: Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
Posted on Apr 30, 2008
SOURCE: water dripping inside fridge
OK, i see a lot of this, and on a fridge that is nearing 10 years old, its pretty normal. Now, we all know that water is leaking into the fridge section from up top because the drain is plugged that is under the evaporator.. now to fix the WHY it happened. most of the time this will happen because the fridge did not go into a DEFROST cycle for a while.. reason being one of two things... either the defrost timer has quit working, or the bimetal thermostat sensor that is clipped on the evaporator has failed. the bi-metal thermostat is usually located in the freezer behind the rear wall and looks like a round "clip on" with 2 wires coming off of it. one pic of one is here.
http://www.partselect.com/PartDetail.aspx?Inventory=371255&SourceCode=5&ModelNum=et18pk
instructions on how to test this is shown on the link.
(just replaced mine the other day, NO MORE WATER LEAKS! =) )
hope this helps!
Chris
Posted on Sep 07, 2008
  • 531 Answers
SOURCE: water dripping from the top (bottom of freezer) onto top shelf.
you have defrost problem
Posted on Apr 07, 2009
  • 93 Answers
SOURCE: We have a Kenmore Coldspot
It is probably your defrost cycle causing this. Obviously if you shut the water line off then it is not coming from there so there is only 1 other place it could be. Every 8, 10, or 12 hours depending on you defrost timer the refrigerator will defrost itself.......the frost melts into water and drains into a pan under the fridge. If the drain is plugged then it will just run into the refrigerator. If you have a freezer on top model then just remove the back wall inside the freezer, it will be a few 1/4 inch screws....If you have an icemaker then remove that too, it will be held on with 3 screws. Just look behind that wall and you will probably see ice at the bottom.....defrost the ice and pour a cup or 2 of water into the drain to make sure it is unclogged. If it is still plugged up then you have to find the clog....either in the back of the fridge behind the lower cover or in the refrig compartment near the back of the roof.
Posted on Sep 12, 2009
Water leak from my Kenmore Coldspot Frig Model 106. 59792990
U have a restriction in drain tube under evaporator coil. So every time it goes into a defrost instead of going down the drain tube it is running over and out the front of fridge
Mar 08, 2013 | Kenmore 53642 / 53644 Side by Side...
Water drips from the freezer into the fridge.Upon disassemble, there is ice buildup under the coils. kenmore coldspot model #71184101
The defrost timer or the defrost heater element has probably failed. Go to the link below and enter your exact model number; you should find a line-drawing illustration and parts list for your fridge that you can use to locate these items and normally also determine how to remove or install them:
Sears PartsDirect
Apr 08, 2011 | Kenmore 52632 / 52634 / 52639 Side by Side...
Hello, we have drips of water coming in to the shelves of our fridge from the top. its a kenmore 106.71182100 coldspot. how can this be fixed?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 11, 2011 | Refrigerators
Hi, I have a Kenmore coldspot top freezer, model # 106.70162990. it drips A LOT of water from the center to back in the top of the fridge, so much that it collects in the veggie and fruit bins and under...
Make sure the fridg. is level,(if it has been moved recently) there is a tube that allows the water from the evap. coils when defrosted to run to a drip pan. The tube is either frozen closed from prior defrosting or something is blocking the tube just below where it is leaking at. Turn fridg off and leave freezer door open (with a fan blowing in freezer if possible) for at least one hour and return to regular operation.
Aug 16, 2010 | Kenmore Refrigerators
Kenmore Coldspot model 106 - Snowing in freezer!
its not defrosting. check heater operations. bimetal near heater. check defrost timer
Feb 08, 2010 | Refrigerators
Kenmore fridge is leaking inside from light switch
The drip pan is underneath on the floor. You don't really need to see it. Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Sep 18, 2009 | Refrigerators
We have a Kenmore Coldspot Model 106 70102000 with the water and ice maker, it is now leaking inside the fridge itself and we have turned the water off to the ice maker and dispenser. What is causing the...
Sep 11, 2009 | Kenmore Refrigerators
We have a kenmore coldspot refridgerator model #62854100 Since we've owned this model we've had a leaking problem from whatever the part is at the top and back of the refridgerator. We go through three...
Sep 03, 2009 | Refrigerators
Refridgerator will not run
if it have a thermostat it can be your problem
Jun 16, 2009 | Kenmore 64802 Top Freezer Refrigerator
Refrigerators Logo
77 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
