Question about Titan Xl 335, xt 330 Airless Paint Sprayer
Need manual for titan 330 airless sprayer - Titan Xl 335, xt 330 Airless Paint Sprayer
3 Suggested Answers
SOURCE: TITAN 440 PAINT SPRAYER: PUMP WILL NOT START,
how can i get the gun to spray it is just dribbling out
Posted on Mar 09, 2010
  • 2428 Answers
Test the power switch check connections
The transducer in this mechine is controled by a circuit board a bridge but isn't that hi tech to give this problem with out a blockage in fuild flow .
Posted on Apr 19, 2015
Sprayer was working fine and ran low on paint and lost prime. could not get it to re-prime. now its still got paint in it and i can't get it to do anything. i need to clean it ont.
I haven't much experience with airless sprayers but I have heard the bad language from those who use them.
I expect there is still paint in the business end of the mechanism and an air bubble stuck between that and the new paint fill.
I think the sprayhead will have to be removed or dismantled so the air will be able to escape and allow priming to take place. I suggest spending a little time with the instruction manual.
Dec 05, 2015 | Titan Xl 335, xt 330 Airless Paint Sprayer
Hi my titan 400 its leaking from the oil cap area, I reduced pressure and still leaking?!
Hi Kamil,
Your Titan Advantage 400 needs to have its piston seals replaced which is why it is leaking into the oil cup. They are self-adjusting static packings. This is a classic airless wear situation; paint is abrasive. Its easy to do it yourself and if you do, you need to examine the piston; if it is worn or scored it must also be replaced otherwise it will wear out the new packings fast. All the parts to repack it can be purchased in a kit.
Jan 13, 2015 | Titan Advantage 400 Airless Paint Sprayer...
What type of oil does the 440 titan impact use
No oil! but you have to use throat seal at the pump piston
Jan 04, 2015 | Titan Airless Sprayer Owners-service-parts...
How to repack the sprayer
The packings are static and self adjusting. The repack kit includes the piston so it replaces everything. Just buy the kit and follow the instructions. Try Scott at American Airless on 770 4771337.
Aug 25, 2014 | Titan Paint Sprayer. Advantage 200 Airless...
Does a titan airless paint sprayer require oil
Yes throught oil to be filled at the top of the pistion read on mechine ware
May 03, 2014 | Titan Paint Sprayer. Advantage 350 Airless...
Titan advantage sprayer stops pumping
Yes im sure you see you need to clean the mechine and all filters after each use if you ever want to work again
Apr 11, 2014 | Titan Advantage 100 Airless Paint Sprayer
Titan 640i wont prime
If you still have a problem with a Titan 640i please give us a call. We introduced this sprayer to the UK back in 1985. Lion Industries UK Ltd 01543 251 560
Dec 31, 2012 | Titan 440 Impact Airless Paint Sprayer...
440i titan only pressure is between 0-200 psi no matter the setting
If an airless paint sprayer won't prime it's usually because one or both check balls are stuck. First try hitting the head where the pump is sharply with a hammer, hard enough to knock the balls loose but not so much that you do any damage to the pump. If that doesn't free them up you may have to take the pump apart and clean them and their seats.
If an airless paint sprayer won't develop pressure, it's usually because the packing rnigs are damaged or collapsed. The only way to check this is to totally disassemble the pump and check them. Also look for any damage to the piston and cylinder. They must be very smooth and shiney, if they are scored they will eat up any new packing rings you put in.
Jul 19, 2012 | Titan 440 Impact Airless Paint Sprayer...
Titan Xl 335, xt 330 Airless Paint Sprayer Logo
Top Titan Air Tools & Compressors Experts
JOHN LAPIER
Steve Pack
Steve Pack
Vernon Taylor
Are you a Titan Air Tool and Compressor Expert? Answer questions, earn points and help others
