Question about Philips (33-01-031) Headphones
My Philips hc8545 headset will only pick up one channel from my Kogan TV. Even when I disconnect the cable from the TV it still recieves one channel.
arclight1217
  • 208 Answers
SOURCE: Philips SAA 7130 Not Picking Up All Cable Channels
USUALLY WHEN AN OPTION IS GRAYED OUT IT MEANS YOU HAVE TO BUY A PREMIUM VERSION OF THE SOFTWARE TO " UNLOCK " THE GRAYED OUT AREAS. CHECK WITH YOUR TV TUNER CARD FOR UPDATED SOFTWARE OR ASK THERE TECH SUPPORT IF THIS IS THE CASE. IF YOU NEED MORE HELP, REPLY TO : ARCLIGHT1217
Posted on Nov 16, 2008
lovejoy91
  • 691 Answers
SOURCE: II cannot get the autoprogram to pick up any
You will find the digital channels with an antenna on the air side, scan until finish
Posted on Dec 06, 2010
krb55
  • 604 Answers
SOURCE: my philips magnavox tv will not pick up cable even
what is your cable provider? they are the ones to contact with this issue. you are paying for cable service and you should have them come and make sure the signal is strong enough for you to get a pure and clean signal. If you have another source for your tv signal you didn't mention it in your question
Posted on Mar 14, 2011
  • 121 Answers
SOURCE: HAVE PHILIPS FLAT TV 42" WITH BUILT IN FREEVIEW
Try this web site http://www.support.philips.com/support/html/index_us_en.html
Posted on Sep 26, 2011
blogcnm2345
  • 469 Answers
SOURCE: Philips flat screen TV auto channel program will not pick up any channels
  • Designed specifically for iPad Pro 12.9 inches iOS 11 Tablet. Easy access to all features and controls.
  • Ultra slim and lightweight hard back design adds minimal bulk while protecting your precious device.
  • Premium PU leather exterior and microfiber interior.
  • No bezels around the screen allowing for unobstructed gesture swipes.
  • Easy clip-on application. Easy clip-on application. Automatically wakes or puts your device to sleep when the lid is opened and closed.
AmanStino Ultra Slim Lightweight Smart shell Stand Cover with Auto Wake...
Posted on Nov 24, 2016
Kogan
Check signal cable if it's properly fitted
May 29, 2017 | Televison & Video
The picture looks like it's moving in slow motion...
Ur tv incomming broadcasting tv channels signals are pick up and using are Free over the AIR broadcasting tv channels pick up are by a Antena signal wright?Not signals by a pay cables or satalites tvs incomming broadcasting input signals?Yes?This tv causes are low and weak ranges of a tv Antena incomming recieving broadcasting tv channels signal.Buy a better design Antena like a Digital Antena and used it will solved this problems.Plug it in ur Digital Antena and rescan ur Free over the AIR broadcasting tv channels again.
Aug 15, 2011 | TruTech PVS31170S1W 17 in. LCD Television
My philips magnavox tv will not pick up cable even though it allows the search of channels i still get static
Mar 14, 2011 | Philips Magnavox 51MP392H Rear Projection...
My sister has just bought me a Sanyo 26 inch TV (LCD-26XR9DA) but it won't pick up SBS and ABC jumps all over the place. I have an outdoor antennae and had no problems picking up the channels on my old...
Go to the TV setup menu and autodetect all channels. This should fix it. This is assuming your Sister is not using a set-top box.
In that case, you neet to leave the set on either channel 3 or 4, or use the video/audio input jacks and leave the set on VIDEO IN. The best picture with a non-HDMI set-top box will always be with the AV OUT from the box going to AV IN on the set [the white/red (audio left/right) and yellow(video) connections].
If she is using a set-top box with an HDMI output, connect an HDMI cable to the set and select HDMI IN for the absolute best picture.
Jan 29, 2011 | Sanyo Televison & Video
Sharp digital tv cannot receive digital signal
This television would benefit from an hdtv indoor outdoor amplified antenna not obstructed by trees, aluminum, bricks, and etc. Make sure the signal type is air and not cable and complete a channel scan during primetime tv hours after connecting to this antenna. Buy a large one that you can mount to the wall usually in a large flat box on the shelf in the store. Philips has one sold at Walmart.
Jun 07, 2010 | Sharp LC-26SH10U 26 in. LCD Television
I have a Philips DVDR 3575H. using Comcast's
Try this set up-
Use an RCA audio/video cable for this set up (Yellow/Red/White).
Connect from the Video out (Yellow) connection on the back of the cable box to the Video in on the back of the DVR.
Connect the audio (Red/White) cables from audio out connection on the back of the cable box to the "Audio in" on the back of the DVR.
This should still get you a decent picture but not a true HD picture for your recordings.
When you set the timer to record set it to record either E1 or E2 depending on which input you connected the cable box to and ensure that the cable box is tuned to the channel you wish to record.
*** NOTE: If you keep the HDMI cable connected as you have for the cable box and watch normal TV through the HDMI input on the TV you will get HD programming for your general viewing but still have the option to record with the DVR at a lower quality. ***
Good Luck and please rate this solution....
Jan 07, 2010 | Philips DVDR3575H/37
Channel tuning 1994 Magnavox 27'' TV
U the remote to turn to the channel 3.
Nov 18, 2009 | Philips Magnavox 27MS343S 27" TV
No UHF channels
Sorry, looking up the Phillips PTV100, it does not support over the air broadcasting. Supports, cable and satellite reception.
The reason you are picking up The VHF channels (2-13) is they match cable channel frequencies up to this point. The UHF frequencies are not the same as the cable frequencies, even though the channel numbers seem the same.
Some other models or brands of TIVO may have this ability.
Feb 12, 2008 | Philips PTV100
Hdmi issue
This may sound silly, but are you changing the channel to the HDMI channel (one of the AV channels)
Oct 12, 2007 | Philips 42PFL5332D 42 in. LCD Television
Philips (33-01-031) Headphones Logo
26 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
