Question about Dell Inspiron 8000, Inspiron 8100 and Latitude C800 15 inch SXGA+ LCD Display-LTN150P2-L01 (LTN150P2L01) CD-ROM Drive
Dell inspiron clear cmos password - Dell Inspiron 8000, Inspiron 8100 and Latitude C800 15 inch SXGA+ LCD Display-LTN150P2-L01 (LTN150P2L01) CD-ROM Drive
Liman preniqi
mysli for live-
Posted on May 03, 2014
2 Suggested Answers
bharat_s
  • 178 Answers
SOURCE: need password reset cmos dell+inspiron+1100
tell me full detail of your problem at (bharat_s@ymail.com) contact me at above e-mail id.. i will surely get rid of ur problem..
Posted on Sep 29, 2009
Dude, Can you send me a Bootable ISO CD of Dell Asset/Service Tag BIOS Reset Tool........Please
Hello, you can download this tool here:
http://www.cgsecurity.org/wiki/CmosPwd
Dell
The official method is to contact Dell Technical Support. Dell Technical Support will request the Service Tag and Express Service Code from the bottom of the Latitude. If the current user is not the original Latitude owner, Dell will transfer the used Latitude's registration from the original owner with only the Service Tag and Express Service Code from the tag on the laptop.
  • Dell Inspiron 5100: eeprom 93lc46, password in scan code at 0x310
  • Dell Inspiron 7500: eeprom 24c164
  • Dell Inspiron 8100: eeprom 24c02
  • Dell Latitude C600: eeprom 24c02, password in scan code at 0x00, 0x10 and 0x90
  • Dell Latitude C610: eeprom 24c02, password in scan code at 0x00, 0x10, 0x80 and 0x90
  • Dell Latitude C640: eeprom 24c04, password in scan code at 0x100 and 0x180
  • Dell Latitude CPI: eeprom 24c02, password in scan code at 0x00, 0x10, 0x80
  • Dell D600: eeprom 24c04, password in scan code at 0x110
  • Dell Optiplex: Remove the PSWD jumper
  • For most Dell Dimension desktops, the steps to reset a BIOS password and clear all CMOS settings are:
    • Locate the 3-pin CMOS password reset jumper on the system board.
    • Remove the jumper plug from pins 1 and 2.
    • Place the jumper plug on pins 2 and 3 and wait approximately 5 seconds.
    • Replace the jumper plug on pins 1 and 2.
Try the backdoor password: Dell
The another method is: by Using the Motherboard Jumper: In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off, and remove the battery and power cord
( if it is a laptop ) before you continue.
Here is a picture how it looks like:
The default setting is:pin 1 to 2, to clear cmos: 2 to 3.
Best of luck :-)
Feb 05, 2013 | Computers & Internet
Dell 1545 inspirion labtop bios pass word code
The most common way that most of us know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing a battery for 30 minutes from the motherboard.
Another way is to reset the clear CMOS jumper on the motherboard itself.
Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip.
So by cutting off the battery power, the BIOS/CMOS settings will be erased. cmos battery Under the keyboard or bottom of laptop -
If you are working on a laptop computer the location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment.
or you might give them a call
Dell Inspiron BIOS Password Recovery
Each Dell Inspiron has a master password that clears the BIOS password. Call Dell Technical Support at (800)624-9896 to get this number.
Dell Technical Support will request the Service Tag and Express Service Code from the bottom of the Inspiron.
If the current user is not the original Inspiron owner, Dell will transfer the used Inspiron's registration from the original owner with only the Service Tag and Express Service Code from the tag on the laptop.
To transfer a used Dell Inspiron's registration, fill out the Transfer of Ownership form on Dell's web
hope this helps
Jun 26, 2012 | Intel DG31PR Motherboard
How to clear the cmos of dell inspiron i can't get pass the password
you have to remove your CMOS battery from motherboard & than you start your laptop,
After that
Fix it as it was & than restart your laptop your CMOS password will be removed after this procedure
thanks
Jan 04, 2011 | Dell Inspiron E1505 Notebook
Hello i need the master password to clear cmos for laptop dell 1440 the service tag (s/n) is :4WMP7L1 thanks
I don't think there is such password.
You could contact dell and ask for the password if there is.
If not then best option is to remove and reseat the CMOS battery.
Contact Dell and tell them to provide you with the steps to remove and reseat the CMOS battery.
It will reset all the BIOS values.
Jun 18, 2010 | Dell Inspiron 1750 Notebook
My Dell computer never bypass bios password anyway * system authinitication password*
Best option is to contact dell support.
Ask them to provide you with a steps to remove and reseat the CMOS batterry,
This will reset all the passwords.
Jun 18, 2010 | Dell Inspiron 1525 Notebook
Unlock dell inspiron 1521 unknown bios pswd
Dell Laptop with bios or hard drive password set ? Unlock your dell laptop using the link below if it display a message that says "this computer system is protected by a password authentication system, you cannot access the data on this computer without the primary or administrator password, when you turn on the computer. This message is what you get if the BIOS is protected by a password. or you get system disabled
Go to: http://dell-inspiron-1521-bios-password.biospwd.com to get your dell bios password authentication and get full access to your dell computer, they can unlock almost all dell laptop such as dell inspiron, xps, latitude, precision, studio, vostro
Feb 12, 2010 | Dell Inspiron 1521-JB Notebook
Where is the location of cmos battery on dell 2650.
pulling the battery will not help it is hard coded in CMOS you need to send it in or take it to a service center that can re flash it for you i do not suggest you re flash BIOS on your own because that could cause a bigger problem
Mar 22, 2009 | Dell Inspiron 2650 Notebook
Dell? Inspiron? 8100
to clear the bios password you will have to remove the cmos battery located on your motherboard
Feb 14, 2009 | Dell Inspiron 8100 Notebook
How do you reset dell inspron 700 password reset
A cmos reset is the only way I know of to clear passwords. Remove the cmos battery for about 5 seconds then replace. This should fix the problem. Good luck.
Dec 06, 2008 | Dell Inspiron 700M Notebook
Dell Inspiron 8000, Inspiron 8100 and Latitude C800 15 inch SXGA+ LCD Display-LTN150P2-L01 (LTN150P2L01) CD-ROM Drive Logo
mukhtar21 shaikh
mukhtar21 shaikh
