Question about Denso Computers & Internet
Will expansion valve #447500-9052 replace #447500-0031
4 Suggested Answers
SOURCE: replace expansion valve
Hi Tresap,
The only expansion valve that I can think of that you may like to replace is on the air conditioning unit....This valve is found usualy mounted onto the AC unit....You'll have to remove the dash board and centre consul....This is qute a job....You should then see the expantion valve on the cabin side of the AC housing....where the pipes go thru into the engine compartment....NOW HOLD EVERYTHING.....before you can remove the valve you need to depressurize the AC unit....That should be done by an expert....The gas is dangerous and you must wear safety googles at ALL times....Once you have removed the valve, you must seal the system so that as little moisture as possible enters the system....If it is left open, you'll have to replace the dryer unit too....when you've finished your replacement, assembly is the opposite as disassembly.....You'll then need to have the system recharged....Don't try to engage it until that has been done....It wont work even if you tried ,as there are pressur switches which will inhibit the opperation....If you have had practice, it will take about three quarters of a day......if not, three or four days
Hope that this helps you
Best regards Johngee10
Posted on Sep 01, 2008
michigan man
  • 3533 Answers
SOURCE: Replace the A/C exansion valve
i am not really sure on this but try these websites fix & troubleshoot heating & A/C its www.automedia.com and the other one is car A/c repair www.directgardening.com if you have a autozone near you there you can rent the special tools you will need take them back and get your money back try www.autozone.com
Posted on May 25, 2009
emissionwiz
  • 75807 Answers
SOURCE: What is procedure for replacing expansion valve on a 2002 Honda Accord?
It looks like the blower unit needs to come out, you need a recycling machine and a very accurate evacuation and charging setup to make sure the amount of R134 is correct, as well as the correct oil type and amount that will need to be added to the system once the part is replaced.
Even a couple of ounces off can make the car not cool correctly
Posted on Jun 14, 2012
Where is the expansion valve?
Next to the blower motor,in a box,the freon has to be removed to replace expansion valve,took my Nissan truck to Midas to have one installed.Here's a link to a new one. Expansion Valve at AutoZone com Best Expansion Valve Parts for Cars Trucks... Here's another link,find the cooling unit,it's in their. SAVE 20 GET 10 GIFT CARD ON ONLINE SHIP TO HOME ORDERS OF 100 OR MORE
Sep 17, 2015 | 1997 Nissan Sentra
Where is the expansion value located?
Here's a video from Scotty showing you how to replace your expansion valve,had mine replace not long ago,had Midas do mine. Replacing An Expansion Valve In Your Car ,hERE'S A NEW PART. Expansion Valve at AutoZone com Best Expansion Valve Parts for Cars Trucks...
Jul 26, 2015 | 2001 Hyundai Tiburon
Where is expansion valve located
The Expansion valve is located in the evaporator box
On this year Nissan it's not to bad of a job. The dash doesn't need to be removed like the newer cars.
  1. To replace the expansion valve, you will need to discharge the AC system. Remove the two AC lines from the evaporator.
  2. Then you will need to remove the glove box
  3. Then you will need to unbolt the evaporator box
  4. Tip it back and remove.
  5. Once you have the evaporator box removed, then you can replace the expansion valve. I would also clean the evaporator box as well since you will have it removed.
May 20, 2015 | 1998 Nissan Sentra
How to replace expansion valve on a 2005 rx8
1.) Discharge air conditioning.
2.) Remove dashboard
3.) Replace expansion valve.
ive never seen an expansion valve in an rx8 go.....
usually its the climate control head. The blend knob stops working...
May 18, 2014 | 1999 Mazda 626
Expansion Valve
Follow the a/c lines to the firewall. The part they are attached to is the expansion valve. Once the a/c system is evacuated the lines can be removed from the expansion valve. The expansion valve can then be removed from the EVAP core.
Jul 13, 2013 | 2004 Nissan Maxima
Where is the expansion valve located on the 2004 KIA Sedona
Kia Sedona expansion FRONT valve located under dash, behind glove box, fan and coil. Evacuate freon first. Disconnect Freon lines from firewall., Lay right front seat back to flat horizontal position and lay on top or totally remove the seat for easier working access. Remove under dash cover, fan, glove box, coil housing, remove coil mounting bolts, remove old expansion valve. (Inspect old valve, if debris inside, blow out coil before installing new valve. If visible debris best to consider replacing REAR expansion valve and DRIER/FILTER in front of radiator too and blow out all lines and coils while servicing.) Use compressor oil to lubricate "O" rings on new FRONT or REAR expansion valve, install valve bolts, reinstall coil bolts to FRONT firewall or REAR frame, reconnect freon lines to firewall in engine compartment. Evacuate AC system, install freon (35 1/2 ounces, nominal 3 pounds), check system for leaks, check for proper operation, enjoy.
Sep 12, 2012 | 2004 Kia Sedona
How much does it cost to replace a expansion valve on 2000 camry
I think It costs $45 plus to replace a expansion valve. Here you can find more quality expansive
valve http://www.carpartswarehouse.com/part/ac-expansion-valve.html
Aug 16, 2011 | 2000 Toyota Camry
99 Toyota Tacoma a/c reads high pressure on low pressure side
Does the compressor run?
Low side could be high without a running compressor.
A running compressor?
The expansion valve itself is about $50 and bolts in.
You will have to remove the 134a gas before installing a replacement expansion valve and vacuum the system before recharging.
Sep 07, 2009 | 1999 Toyota Tacoma PreRunner
Where is the expansion valve on a 95 Lexus es300 and from which direction does one access it in order to replace it? Just purchased new compressor, drier and expansion valve, no problem with the first two...
It is attached to the back wall of evaporator. You have to remove the glove compartment, blower unit and evaporator to get access to the expansion valve.
Jul 04, 2009 | 1995 Toyota Avalon
Computers & Internet Logo
59 people viewed this question
Top Denso Computers & Internet Experts
David Payne
David Payne
Are you a Denso Computer and Internet Expert? Answer questions, earn points and help others
