Question about Yamaha RX-V665 Receiver
Video Input I have a Yamaha RX-V665 receiver. I am running an Xbox 360 and a PS3 HDMI in to the receiver then from the receiver HDMI out to my tv. Everything works fine. Why is it that I can not get any video from a Nintendo 64 when using the red white and yellow connectors on AV6 as input?
avenger77
SOURCE: Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Solved problem with Yamaha HTR-6040 AV Receiver. My daughter had inadvertently changed the program to "Direct Stereo" mode which allows sources to bypass the decoders and DSP processors so you can listen to 2-Channel PCM and Analog sources. Nothing to decode digital audio in this setting!
Posted on Aug 10, 2008
quang123
  • 107 Answers
SOURCE: problem hooking up my Yamaha RX-V461 to my PS3
When you connect the optical cable to the ps3 you must change the output to optical on the ps3. To do this, startup your ps3 then go to settings then audio output settings and change it to Digital Out (Optical).
Posted on Dec 01, 2008
SOURCE: no picture from wii
The RX-V800 switches the various video signal types separately.
Since you are feeding S-Video to the TV the composite (yellow) input from your Wii is not going anywhere.
If you cant get S-Video output from the Wii then I'd suggest a simple Composite to S-video adaptor plug ($5 say). It worked for me with a Game Cube.
Cheers
BJ
Posted on Apr 27, 2009
smarthome2
  • 1114 Answers
SOURCE: Yamaha RX V 657 - No Sound Output, and No input detection
Bad DSP chip. The only other possibility is if you have the "Direct" on. On the front of the receiver it's a small button. Also make sure your "Speaker Select" A/B is "on" You will see it on the display, it's also a small button on the front of the receiver. If all this is correct and you still have no audio, it's a bad DSP chip. Not worth repair, it's 400-500 repair. Not very common in a Yamaha RX-V series, but I have seen it. I'm a Yamaha Dealer. If you need further help, post a comment and I will be glad to help you further.
Posted on Aug 23, 2009
SOURCE: I have a Yamaha HTR-6130
I have this same problem! Mid_ager, how'd you solve this?
Posted on Dec 25, 2009
How do i connect my xbox 360 to my yamaha rx-v665 receiver
If you are gonna connect the x-box to the yamaha directly you would have to connect the red and white cables to one of the inputs on the reciever and the yellow to the video on your tv.
Feb 16, 2010 | Yamaha RXV665BL Receiver
I have my PS3 plugged into my RX-V365 via HDMI then i have my RX-V365 plugged into my Sony Bravia, the problem is i get no Audio through the HDMI input on my Amp but it still comes through the TV how can i...
Run optical or digital coaxial from your PS3 to the receiver and HDMI from the PS3 directly to the TV. Your receiver's version of HDMI will not work, it's 1.1 and cannot be updated. That's the fix, if you want more info on HDMI problems google HDMI issues or problems and you will find thousands of posts and forums on this issue. Short answer though is, you either need a receiver with version 1.3b HDMI or run optical or digital coaxial for audio to your receiver. Hope this helps
Dec 25, 2009 | Yamaha Rx-v365 A/V Home Theater Receiver
How do i connect my cable tv to my yamaha rx-v665? i do not have a cable box
If your tv has an audio out jack attach a rca cable from that to your receiver any audio input.
Dec 19, 2009 | Yamaha RX-V663 Receiver
I have my xbox 360 connected via hdmi to my yamaha rx-v363 receiver, and the receiver connected to my sony bravia lcd tv via hdmi as well. The xbox picture comes through to the tv fine, but the sound will...
Connect Xbox via HDMI to DTV/IN, Connect HDMI from out to Sony Bavia's HDMI/IN. Connect TV's Optical out to amps DTV/Optical in.
2X HDMI cables and one Optical are required.
Enjoy great sound :)
OH: choose the DTV input then stereo and then dolby 5.1 etc .. cheers
Sep 04, 2009 | Yamaha RX-V363 Receiver
No sound from cable via V665 receiver
Can't pass HDMI thru this or any other receiver with version 1.1,1.2,1.2a,or 1.2b. HDMI is riddled with issues! it's not Yamaha, it's HDMI. The current version 1.3b is working "so far" If your receiver is still under warranty, Yamaha will update the software and hardware at N/C. If it's out of warranty, Run HDMI directly from source to TV and Audio to your receiver via optical or digital coaxial. For more info than you can process, google "HDMI forums" and there are over 73,000 posts/sites/etc. If you need further info, post a comment and I will be glad to help.
Aug 22, 2009 | Yamaha RX-V463 Receiver
How to hookup yamaha rx-v730 receiver to projector & cable unit.
hook up hdmi cable from cable box to receiver hdmi input 1 then from hdmi out to your projector or tv,i don't know what kind of inputs you have on your projector .whatever you have run from projector to receiver input example component red,blue,green then run from both say to the av input 1 then set your receiver to av1 and you should get picture.
Jan 25, 2009 | Yamaha RX-V730 Receiver
Xbox 360 dashboard will not show using Yamaha RX-V663
I had this issue once before, recheck all the conenctions on the tv, and make sure that the HDMI plug in for the TV * if its the older model * make sure it is placed to HDMI not TV.
Please let me know how it goes,
Thanks
Justin
Please rate me
Jan 07, 2009 | Yamaha RX-V663 Receiver
Problem hooking up my Yamaha RX-V461 to my PS3
Dec 01, 2008 | Yamaha RX-V461 AV Receiver
Yamaha RX-V665 Receiver Logo
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
