Canon i9900 InkJet Photo Printer
Problem for Canon i9900 InkJet Photo Printer
Canon i9900 blinking three orange / jam
By SMATSMAN on Aug 31, 2007
Does ANYONE know how to fix a Canon i9900 that blinks 3 orange lights, indicating a paper jam. I have taken this thing apart and there is no paper in it. All the sensors are there and not broken.????? I performed the waste tank reset with no change.
Same Problem
Jun 28, 2008
-   When turned on the i9900 printer goes throught the start up routine. Then the jamed printer, blinks green and then blinks orange eight times, appears. I have read the manual and managed to feed only one sheet of 8 1/2 X 11 inch sheet of paper through which shows there really isn't a paper jam.
The -   Guest
Apr 29, 2008
-   Error No. 1300. Paper Jam. There is no paper in the printer yet it keeps saying this. Full ink tanks. ?????-   perryn07
Mar 27, 2008
-   How do I take the lid (cover off) to get to my ink cartriges? Is it possible the ink ran out and it stopped at the edge of the printer, where I can't reach it?-   naikedo
Mar 24, 2008
-   How do i change the ink waste absorber. Warning keep coming up and the only solution i have found is to press the button to feed it through (only a temporary solution),-   BVdarren
Dec 11, 2007
-   Paper gets jammed on right side where paper feeds out. How do I fix it? I also do not know how to do the ink waste tank thing.-   mrsabelard
Solution #1
posted on Sep 09, 2007
Somewhat Helpful)
lilacgerry
Rank: Wiz  Canon Expert
Rating: 79%, 504 votes
uninstall it and reinstall it, hopefully it will reset itself then.
Was this helpful?
Yes
No
Solution #2
posted on May 03, 2009
Helpful)
neilsousa
Rank: Apprentice
Rating: 94%, 4 votes
I had the same problem with my i9900 - 3 orange flashes on the the error light (Paper Jam) and yet I could slip a sheet of paper in and it would feed through OK. My problem is that the SPRING on the PAPER SENSOR had come off, leaving the sensor in the where it would be if there was a paper jam.
You have to REMOVE the main cover of the printer to find and fix this problem You have to find all of the release points (look for triangles on the plastic covers) where you insert a small tool/screwdriver to (1) press 1 release each side & remove the 2 silver end panels, (2) press 1 release to remove the control switch & carefully disconnect the two connectors inside. Start with the triangle rlease on the lower front left of the main cover, then 1 on the left side, 3 on the back, 1 on the right side, and finally 1 on the lower front right side and gently lift the whole cover off.
You can then look inside with a flashlight from the top rear just behind the left side paper feed roller and see a small switch which pivots when paper is fed through the printer. Feed a sheet of paper and see if the spring is returning it to the normal (no jam) position. I used a long pair of tweezers to reach inside and slip the spring back into its normal position which is behind the small slot on the far right side of the switch. No pictures, but it should be intuitive where the spring should go. Once reinstalled, the switch will move back to the normal position and your paper jam should be fixed.
This SAME MECHANISM is also used in a number of other Canon i & ip series printers so this general approach to fixing this in other models could be the same - (1) remove the cover, (2) locate the switch, and (3) put the spring back into the correct positiion.
Was this helpful?
Yes
No
3 people thought this was helpful
Popular Solutions for Canon i9900 InkJet Photo
Questions and Unsolved Problems for Canon i9900 InkJet Photo
Do you recommend Canon i9900 InkJet Photo Printer?
Answer
Answer
When I print out black and white pictures on plain typing paper they come out black and white. When... (More)
Answer
Printer doesn't recognize paper in the hopper. Printer goes through it's sequence of pushing paper... (More)
Answer
i9900 prints fine on plain paper but on glossy prints magenta and black. installed new cartridges
Answer
I want to print an envelope and don't know how to insert the envelope in the Canon i9900 printer
Answer
My printer just prints blank although ink cartridges show half full. Cleaning and checking nozzles... (More)
7 Other Users Have The Same Problem - Continued
Comment by comm, posted on Nov 30, 2007
I have a similar problem - is there any other solution.
Comment by Guest, posted on Nov 13, 2007
Canon Repair Shop could not fix it and they claim that they never had this problem with others and were puzzled that I am the only one?
I took the cover off permanently and the incorrect jamb error message never occurred again (6 months). I was tired of resetting the printer during batch printing (Dozens of times since the past year, 1st year no problem). The repair shop claims my machine might not be aligned and my machine is a one-of-a-kind problem?!! My printer is in a pull-out drawer to keep the dust off.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printers Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
