Question about Brother ML-100 Typewriter
I CAN NOT TYPE THE
I DID NOT FOUND THE USER´S MANUAL FOR BROTHER ML100. THE PROBLEM IS I WANT TO USE MY TYPEWRITER IN SPANISH , BUT I CAN NOT USE THE " ? " LETER.HOW CAN I TYPE IT.
    Scholar:
  • 43 Answers
Hola JuanJose,
User Manual en espanol.
http://rapidshare.com/files/84607955/UM_ML100_SP.pdf.html
FixYa!
Posted on Jan 17, 2008
SOURCE:
Brother ML100 typewriter. How can I type a Spanish n?
The tilde is a special character not available on a standard typewriter keyboard.
Feb 16, 2016 | Office Equipment & Supplies
My typewriter will not type the correct letters I have replaced the wheel twice any suggestions?
Make sure that ps pitch is not selected. check if ribbon or corr. tape is in printwheel
Sep 26, 2014 | Brother ML100 Daisy Wheel Electronic...
How to make a brother typewriter/ wordprocessor 680 to type in Spanish?
Go to BROTHER.COM clicl on support you will find a manual there if your T/W has that feature it's there.
DickyO
Apr 13, 2012 | Brother EM-530 Typewriter
Typewriter ,brother ML100 STANDARD : I CHANGED THE DAIZY WHEEL AND PRINTING REBBON. THE PRINTER IS NOT COORDINATE WITH TYPING KEYS WHEN I TYPED. EXAMPLE , IF I TYPE B , A DIFFERENT PRINT INSTEAD .
Turn the machine off and allow it to rehome itself. If that doesn't help the printwheel homing pawl is probably broken. you will need a tech.
DickyO
May 04, 2011 | Brother GX-6750 Typewriter
How can I get printer ribbons for this Brother ML 100 typewriter? Can you give me the code #?
The Brother ML100 uses the BRT 1030. There are several supplies available like the lift off tape, the daisy wheel and of course the printing cassette.
check it out:
Brother ML100 Typewriter Supplies
Good luck and if you need anything you can always call or email.
Duane ONeil
www.FJAproducts.com
800-982-9989
bc.cbi?cbdid=423141670777502444&wdid=1041068402873934082 8 to 5 (pst) Mon-Fri
Sep 15, 2009 | Brother ML-100 Typewriter
Olivetti ET Personal 56
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_ML_100_EN_216.PDF
Try this. If it does not work, you can find it like this.
http://www.brother-usa.com/ Download and support is in upper right hand corner. Next page, open box to typewriter, and then second box to ML100. Next page should be the English Pdf. link.
Sep 06, 2008 | Olivetti Office Equipment & Supplies
Different letters despite what I am typing...
look for kb1 and kb 2 or your pitch is selected at ps instead of 10 or 12
May 19, 2008 | Brother GX-6750 Typewriter
Brother ML100 Typewriter:All of the sudden, it just won't type. It seems the 'hammer' doesn't hit the daisywheel. We've replaced the daisywheel, corrective tape, ribbon and still it goes through the...
Ok,there could be two possibilities ,1, The daisy wheel may not be seated in properly. Of course I assume that the print side of the daisy wheel is facing the platen and that when the typewriter is switched on the print unit makes its customary re-setting motion and that the daisy wheel spins around at the same time. if this does not happen make sure that the lock-in lever for the daisy wheel is pushed home.. I am sure that you do all these elementary things so the only other possibility is the the hammer seleniod is not fully functioning and would have to be re-placed....Good luck!
Nov 14, 2007 | Office Equipment & Supplies
Make sure that the correction tape is place in the guides one on each side small metal guides, remove ribbon to see, it should be behind ribbon guide (closes to you). Dry lift-off tape only(#3015)
Dec 05, 2006 | Brother ML-100 Typewriter
Brother ML-100 Typewriter Logo
246 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
