Question about Breville BBL600XL. 5-Speed Blender
I have the Breville Blender Model BBL600XL 5 Speed Hemisphere. I have taken immaculate care of it, always handwashing after each use then drying and putting it away. I've only had it a year. I've had cheaper models for years with less trouble. It has performed wonderfully until this last week. The problem I noticed is that it sounds a little different when I run it and there seems to be a residue of rust colored dust on the base under the bowl when I lift it up after making a smoothie. It wipes off on the finger the color of rust. Also I am noticing an extremely tight blade system. It does not spin very easily. If I continue to use this, I see that something (don't know what) is breaking down and probably the motor will burn itself out from the strain of trying to move the blades. I have not tightened any of the screws or nuts that hold it together. Thank you for your assistance. Dianne B. from TX
5 Suggested Answers
pappapumpdaf
  • 635 Answers
SOURCE: grease build up around blade and where it attaches to base
Grease can only creep into the blender vase if the oil seal has worn out, or the blenders blade shaft is worn and wobbling. Try cleaning all parts in alcohol to soften the seals. Rebuild kits and replacement blades can be found here (http://www.brevilleusa.com/breville-parts/blending.html)
Posted on Mar 09, 2010
EwingElect
  • 276 Answers
SOURCE: What is the difference between the BBL550XL 5 spee...
Basically, the more your pay the more you get. Extras are: Pre-programmed 'Ice Crush' and 'Smoothie' settings 1200W instead of 1000W. Heavy duty die-cast metal base LCD display counts up when a speed setting is selected or counts down for pre-programmed settings Hope this helps!
Posted on May 24, 2010
  • 24 Answers
SOURCE: Hello, I didn't see model #BBL600XL which is what
The jar has to be on for it to blend.
If you replace the jar first check the printing on your old jar. If your jar has blue print you will need a new jar and blade, Breville redesigned the jar and now the old blades don't work with the new jars. You tell the difference between the jars by the print color, old is blue, new is white.
BBL600XL/06A jar part number
BBL600XL/14A blade part number
Contact Breville at 1-866-273-8455 for service center locations.
Posted on Oct 05, 2011
SOURCE: My breville blender model#bbl600xl leaks every
It leaks if you over tighten it. So try to just do it finger tight. I was having the same problem, once I eased off on the tighten if stop leaking. I assume you are getting it correctly aligned as that can be the other issue.
Posted on Nov 02, 2011
I Need to Remove Fan from a Breville BBL600XL blender. I believe the fuse has blown -- I can get everything off but the fan... please, if anyone has done this -- how do I remove the fan so I can open it...
Hold the fan still and then turn the top and it will start to loosen the bolt you can see on the fan.
Side Note: If you need to remove the bottom completely then you also have to remove the screws hidden under the rubber feet.
Jun 05, 2011 | Breville BBL600XL. 5-Speed Blender
My breville blender model#bbl600xl leaks every time I put liquid in it, the gasket is in place and it is tightened as much as possible, what is the problem.
May 14, 2011 | Breville BBL600XL. 5-Speed Blender
Mar 23, 2011 | Breville BBL550XL 5-Speed Blender
I think I overloaded the blender. Seems like it over heated. now the light on controls goes on but blender does not run when I push buttons. I checked the fuse and its good. What else should I check?
If fuse is good and light is on, then you are getting power. Most likely and very very commonly the motor is fried. I have done it myself with 3 of these things.
Dec 31, 2010 | Breville BBL600XL. 5-Speed Blender
Breville blender won't turn on. The on light is flashing red instead of solid blue. Worked fine a few days ago.
FIXED IT - It's the screws on the bottom of the jar assembly, where the blades are attached. There are 4 Torx screws - star-shaped - and when these come loose over time the Blender will start to operate only sometimes. Eventually it will be never.
Tighten these four screws and everything will be fine!
Oct 02, 2010 | Breville BBL600XL. 5-Speed Blender
What is the difference between the BBL550XL 5 speed blender and the BBL600XL
May 21, 2010 | Breville BBL550XL 5-Speed Blender
Grease build up around blade and where it attaches to base
Mar 09, 2010 | Breville BBL600XL. 5-Speed Blender
Blender will not run. the power button is lite but
There is a 10 Amp thermal fuse (SF129E) that is supposed to create an open circuit when the motor windings exceed 133 C degrees. Although this fuse should close again when the motor cools down it can become perminantly damaged. Locate the fuse by following the black leads from the coltrol board to the motor brushes. It's inside a cloth insulating sheath secured against the windings with a metal strap and two ty-raps. I bypassed the fuse with a wire instead of replacing it. It would probably just blow again sooner or later. p.s. you need a T10 Torx screw driver to disassemble (screws under rubber feet) $3 at ACE hardware.
Jul 01, 2009 | Breville BBL600XL. 5-Speed Blender
Breville 600XL not turning on
My BBL600XL stopped working because of a blown fuse. You need to remove the phillips and torx head screws out of the bottom. Then remove the base. There you will clearly see a fuse on the circuit board.
It appears to be a 10A 250V fuse.
Jan 28, 2009 | Breville BBL600XL. 5-Speed Blender
Breville BBL600XL. 5-Speed Blender Logo
71 people viewed this question
Top Breville Blenders Experts
Mike
Joseph Hoffmann
Are you a Breville Blender Expert? Answer questions, earn points and help others
