Question about Xerox Office Equipment & Supplies
Error message on Docucentre II C2200 reads 004-346. What dores this mean? We can't copy or print.
4 Suggested Answers
micromaster
  • 3614 Answers
SOURCE: Have a Fuji Xerox Docucentre
hi there,
first try to reset all the setting has been made...
and also it seems that the error codes was on the power supply area, check the fan blower on that are if still functioning,,,
Posted on Oct 24, 2008
SOURCE: Can you tell me what
hi
regarding your error go to following link
http://www.copytechnet.com/forums/xerox/36062-xerox-docucentre-ii-2055-error-016-315-a.html
Posted on Jul 24, 2010
  • 100 Answers
SOURCE: i received a message on
You likely have a few failed capacitors on your printer's logic board. I have a HP C6180 all in one printer that started displaying this exact message. Powering off then on again clears the error and you can operate as normal for a few minutes to hours until the error re-appears. I suspect your printer will eventually power off then on by iteslf every 15 seconds or so, making the printer unusable. Take the logic board cover off (on the C6180 is is on the right end of the printer), remove the logic board and look for failed capacitors (they will be puffed on the top (see image). If this is the case, you will have to have them replaced (easily done with a soldering pen). The replacementparts are inexpensive (less than $1.00.
Posted on Sep 19, 2010
DocuCentre-II C3000 win 8.1 Troubleshooter
From Windows 7, all firms who have a certification, to let their hardware run under Windows, get their drivers on Microsoft. They don't need to deliver the drivers to the costumers. If the driver is not in Windows 8.x, the firm will not have any certification. So trying to install an old driver, will not work. The driver does not have correct entries to the bios nor to windows. And although the website is recommending to download the XP drivers, they don't give any warranty they will work.
Try to contact your dealer or service centre, so they can solve the problem.
My guess? The advice you to go back to a stand alone PC with Windows XP.
Jun 15, 2014 | Xerox FX DocuCentre-II C3000 PCL 6
How to set up Iphone app to print using FX DocuCentre-II C3000 PCL 6
You must have a wireless PC with iTunes + Airprint loaded - to provide a "shared printer" for IPhone.
Nov 19, 2013 | Xerox FX DocuCentre-II C3000 PCL 6
How to set up Iphone app to print using C3000
you need an airprint enabled printer, here is the official list: http://support.apple.com/kb/ht4356
is it an app you are using already? if not, try print n share, this will work even to a non airprint printer
Can you tell me what error code 124-315 means on Xerox Docucentre-II 2055 ? and what the recommended fix is. (Multifuncton printer). Thanks, Gajj
hi
Jul 24, 2010 | Office Equipment & Supplies
On canon iR 1020, i cannot print and make a copy
Do you mean that you have blank copies/prints, or that there is some message on display, or just blinkig red led...?
If yyou have blank copies the problem is in laser shutter.
If you have error message send detailed description.
May 21, 2010 | Canon NP 6035 Copier
I get an E140 error message when I turn on the copier
Hello sir; The error code you display it means optics fan not working you have to replace it.
Aug 28, 2009 | Panasonic FP-7735 Black and White Copier
Error 1203
hi..
error 1203 means either or both cartridges have short circuited and needs replacement..
You will need to perform the following steps to find out which cartridge is defective:
1. With the printer turned ON, open the front cover and remove both cartridges from the printer.
2. Power the printer OFF and unplug the power cable for 30 seconds. Plug the power cable back in and turn ON the printer.
3. If the error message is now cleared from the printer, please perform the "Self-Test" by following the steps below:
1. Make sure the printer is in “Copy Mode.”
2. Press the “Menu” button once.
3. The screen will display “Copy Menu: Copies”.
4. Press the left arrow button once. The screen will display “Copy Menu: Tools”.
5. Press the check button once. The screen with read “Tools: Maintenance”.
6. Press the check button once. The screen with read “Maintenance: Ink Levels”.
7. Press the right arrow button until the screen reads “Maintenance: Print Test Page”.
8. Press the check button once. This will start the Self-Test. Once the page has printed, the printer will stop. The test is not continuous.
If the printer has detected a "Cartridge Missing" error, then please follow the steps given below:
1. Turn the power OFF.
2. Open the front cover.
3. Turn the power back ON. The print cartridge carrier should move to the install position located in the middle of the printer. If it does not, close and reopen the cover:
4. Reseat both cartridges in the printer and check for the error.
5. If the error still displays, then remove the color print cartridge.
6. Close the cover.
7. If there is no error indicated by flashing lights, the color cartridge has short-circuited.
8. However, if you continue to get an error, repeat steps 1-3, and then go to step 9.
9. Remove the black print cartridge and reinsert the color cartridge.
10. If there is no error indicated by flashing lights, the black cartridge has short-circuited.
11. If you continue to receive an error in both cartridge scenarios, both print cartridges have short-circuited.
Apr 23, 2009 | Lexmark X5470 All-In-One InkJet Printer
Front cover dore open or cartridge missing
Try reseating the ink cartridge and see if the cover door is firmly closed.
Mar 27, 2009 | HP LaserJet 1020 Printer
Printer message: Unable to Print
5A means that the purge cam stopps abnormally when it is in use. This could be of a broken cam shaft. You have to replace the whole purge unit. This is a service job to do!
Aug 27, 2007 | Brother MFC 420CN All-In-One InkJet...
99 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
