I HAVE A MSI MS-7131(915GVM-V) M/B PROBLEM IS NO DISPLAY,PROCESSOR HEATING NORMALY,RAM AND CLOCK ON B16 ARE OK .NOT RESET SIGNAL ON A15,WHICH IS GENERATING RESET SIGNAL AND HOW TO SOLVE THIS PROBLEM.........?
Yes
Posted on Aug 01, 2013
SOURCE: MSI MS-6754 mother board won't boot and beeps when I swap processors
Ya know. I was trying a 533 FSB processor I see now that my motherboard only supports 400! Standby. Let me get a 400 and see if it cures my ills! Ahhhhh............
Posted on Sep 09, 2008
ziraffa
  • 827 Answers
SOURCE: need drivers for MSI P4MAM-V (MS-6787 v2.0)
Try here for LAN and chipset. Here for sound.
Hope this helps
Chris (ziraffa)
Posted on Jan 16, 2009
proton77
  • 1183 Answers
SOURCE: reset bios on MSI ms-7301 motherboard
Kindly visit the following site
http://www.msi.com/index.php?func=downloadindex
Select the correct model number for your mainboard or motherboard and download the user manual for the same. It has details on how to reset the cmos or the board using the jumper settings
Thanks for using fixya
proton
Posted on Aug 15, 2009
  • 86 Answers
SOURCE: MSI PM8M-V Motherboard cpu support
Hi There
The list of compatible processors is here:
http://global.msi.eu/index.php?v=1&func=prodcpusupport&prod_no=205&maincat_no=1&cat2_no=&cat3_no=#menu
The E5200 is a WolfDale processor and unsupported.
Many of the supported CPUs are hard to find but Newegg has one here:
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116027
Posted on Aug 29, 2009
Testimonial: "Thank you for information, JK"
Geekman
  • 32281 Answers
SOURCE: I Want Display Driver of this Motherboard (MSI
You can download the drivers from MSI WEB support site, select your model motherboard to download :-
Posted on Sep 01, 2010
I HAVE A MSI MS-7131 M/B PROBLEM IS NO DISPLAY,PROCESSOR HEATING NORMALY,RAM AND CLOCK ON B16 ARE OK .NOT RESET SIGNAL ON A15,WHICH IS GENERATING RESET SIGNAL AND HOW TO SOLVE THIS
Hello here is some info about the mainboard:
http://www.motherboards.org/mobot/motherboards_d/MSI/915GLM-V%2B%2528MS-7131%2529/
More info and drivers visit the MSI homepage.
The fault could be the ram module ( wrong mhz size )
The ram module must be DDR ram, other type of ram will not fit the mainboard.
The mainboard does not support more than 2gb of ram, if more insertet the mainboard will not boot up ( no display ) and maybe a beep code will come when you try to boot.
The fault could also be the power supply, or a intenal fault on the mainboard, maybe bad capacitors or the graphic chip is burned.
Try to boot with only one ram module, and try also with another power supply you know is working.
Try also to reset the bios by removing the cmos battery for like 10 min.
The power cord must be disconnected when you do this.
Also try with a intenal AGP graphic card.
Hope you get it running
Jul 31, 2013 | Computers & Internet
Can i chage my processor pentium 4 to core2duo my motherbourd is(MSI PM8M-V H (MS-7104 v2) thnkz
No, you cannot upgrade to a core 2 duo with that motherboard because it is a socket 478.
Jun 04, 2012 | MSI Computers & Internet
I have MSI N 1996 MS 7312 VER 1.0 K9MMV motherboard and SEMPROM 1.8GHz processor . But I want to take AMD ATHLON x2 5200+ processor . And I want to take 2GB DDR2 800FSB ram. so please help me can I take...
If you have already bought the other components that you would like to add then this should be fairly easy. To replace the processor first you need to remove the original one. Start by taking off the heat sink, a large piece of metal near the RAM. This should be done by either screws or push pins. Once this is off pull the metal lever near the processor to the side. Bring that lever up and remove the old processor. Put the new processor in. There should be markings as to which corner goes where. Next you need to apply some thermal grease on top of the old processor. If you don't have any you can buy some here (http://www.newegg.com/Product/Product.aspx?Item=N82E16835100302&cm_re=thermal_paste-_-35-100-302-_-Product). Apply about a pea worth of thermal grease on top of the processor. Make sure the heat sink is clean before putting that back on. Normally it is a good idea to clean it off with a paper towel then some rubbing alcohol. Then reattach the heat sink and be sure to plug in the fan if there is one. Replacing the RAM is much simpler than the processor. Push down on tabs containing the old RAM and it should come out. take the new RAM and place it into the slot the old RAM was in and push down until the tabs come in and lock the RAM into place.
May 11, 2011 | MSI K9MM-V Motherboard
No display but power on ram ok cmos battery ok cpu fan and cpu ok
first check ur display cable for breakr if you have built in display disable it in bios and and if you have addon display card remove them insrert a new addon diplay card if you have display the display section in you motherboard is faulty or diplay add on card is faulty if it still dont work the clock and reset section in your motherboard is fulty to find the at the above section if you have a multimeter check the pci slot A15 means the pci pins facing the processor must have 5v if this is ok your motherboard is ok and the problem is with your display card
Oct 07, 2010 | Intel D845GVSR Motherboard
Is the MSI-K9N SLI-Platinum (MS-7250) capable of running an HD capable video card?
I would recommend upgrading your RAM to 2GB or even 4GB before investing into HD video card. It might be jerky. Your processor should be ok for it as it is.
Jul 21, 2010 | MSI K9N Platinum Motherboard
Motherboard model number
you can see on the motherboard.watch carefully...
Mar 09, 2010 | Computers & Internet
Why my mouse and keyboard hangup when i attach my flash
It sounds like you could be low on memory or your processor is working super hard.
To fix this, first, check and see how much ram you have by right clicking on "My Computer", then click "Properties". Your processor speed and ram will be shown in the window. If you have less than 256 MB of RAM, or a processor less than 1.2 GHz, then you might need to upgrade your processor or RAM.
Apr 16, 2009 | MSI 848P Neo-V (MS-6788-040) Pentium 4...
HOW TO CHECK RESET SIGNAL ON PCI SLOT OF MOTHERBOARD
you can find out on A15 pin for reset and B16 for clock .
reset singnal have around 5 volt and clock have 1.7 vlt
Mar 15, 2009 | Computers & Internet
No display on IBM motherboard
replace your ram as wwell as cmos battery
Mar 13, 2009 | Computers & Internet
Upgraded computer and won't come on, no bios.
disconnect all and reconnct it.something jammed .may be *********** bord circuit is ground.
disconnect hdd ram then try.
to reattch one by one.
try with only smps ,mother bord and ram.
also check processor sitted correctly.
Nov 24, 2008 | MSI MS-6734-10 (-6734-010) Motherboard
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
