Question about Welding Tools
Century welder website
I have a century Part #84231 Model 110-114 AC DC welder. I set the amps at like 150 and when i start welding the lever will fall down to 110 amps.How do i stop this from happening?
4 Suggested Answers
Delage guy
  • 167 Answers
SOURCE: was welding and welder quit acking wire feed and
Check earth wire has not become dislodged,
Pop the cover and check for burnt terminals, often overheating of the transformer can cook a terminal, easily cleaned up and replaced.
Posted on Mar 31, 2010
SOURCE: lincoln electric ac/dc arc welder model ac/dc
my welder doesn't weld but my electric meeter goes wild.
Posted on Sep 06, 2010
eugbug
  • 479 Answers
SOURCE: We need to know how to get an owners manual for
This manual is available for download for $8 at:
http://www.centurytool.net/Century_82021_25_Amp_Plasma_Cutter_Owners_Guide_p/811-656-000.htm
Posted on Feb 15, 2011
Ranger 10,000 has low weld output and ac output
This is not a simple question. Take this magnificent machine to a service shop.
Aug 25, 2014 | Lincoln Electric Ranger 250 GXT AC/DC Arc...
Lincoln electric ac/dc arc welder will not arc
Check the dial indicator. Sometimes if someone changes the amps while welding, there will be a break in the coil. It will work at a different setting as long as you are away from the break.
Jul 17, 2014 | Lincoln Electric K1297 AC/DC 225/125 Stick...
The settings for welding aluminium using a Tig200P AC/DC inverter
If you are using a remote then you would set the machine in standard for controlling output and also to AC output, HF tig, contactor and control in remote position. I don't know if this helps or not but I pulled it from an owners manual.
1/16" (.062) - pre-flow .1 sec., hot start 20, amperage 70, Hz 100, balance 20%, post-flow 6.0 sec.
For pulse settings - set pulse width 60%, peak current 100, background current 30, Hz 1.0
1/8" (.125) - pre-flow .1 sec., hot start 20, amperage 150, Hz 80, balance 20%, post-flow 6.0 sec.
For pulse settings - set pulse width 60%, peak current 150, background current 50, Hz 1.0
3/16"-1/4" - pre-flow .1 sec., hot start 20, amperage 185, Hz 60, balance 20%, post-flow 8.0 sec.
For pulse settings - set pulse width 60%, peak current 185, Background current 125, Hz 1.0
Mar 14, 2014 | ARC Thermadyne Inverter Stick/TIG Welder...
I have an ancient 125 amp AC arc welding machine on which the current is varied by moving the negative lead from to different terminals. However the terminals are in pairs and joined by slotted metal...
Hi:
Since you did not mention here brand or model of welder; I'm pretty sure that your machine it's an AC/DC machine, the series of slotted plates means that the machine will output 50 amps in AC or 80 on DC. 60 in AC or 125 in DC.
If you want to work with lowest amps available, just put the selector on AC and connect your cables to the 50/80 amp side.
You should have a selector lever to switch back and forth from AC to DC in front of the unit.
Hope this work for you.
Jun 26, 2011 | Welding Tools
"I was welding with a
Your generator is a welder?? Yikes, the 220 volts coming out of the genny is not the same as the 220 volts running a welder, it is, but it isn't, the 220 volts used to run the welder are transformed into DC, in the 50 -150 amp range, the 220 volts coming out of your genny is 220 volts, AC, at 30-40-50 amps. Now exactly how were you welding with 220 volts AC? Remove anything plugged into the genny, check the oil, check the gas, make sure it is fresh, check the breakers, check the fuses, get it running, now don't try to weld with it again. Unless you have a big welder to plug into it and I wouldn't even do that because of the generator spikes. I might be wrong, but I have never seen a genny with a welder on it for home use.
Feb 06, 2011 | Coleman Powermate Powermate 5000W...
How too set up a tig welder for welding thin steel?
DC current, electrode negative (DC Straight, DC-), High frequency for start only (really don't have to use high freq at all for steel but it helps establish the arc without scratching), 1 amp per thousandth of material thickness is a good setting to start, adjust from there for the job. 1 amp/thousandth also applies to aluminum- it has a lower melting point than steel but conducts heat much better so power to weld is very nearly the same.
Use a sharp tungsten, don't ball it at all (as you would for AC work).
lp
Dec 01, 2010 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
My AC225c welder will start a 7018(new) rod at the proper setting but then quit. Acts like setting is too low but no matter how I run up the setting nothing changes. All 6011,6014 rods weld perfect. Do I...
JAMES B,
FIRST OF ALL THE 7018 WELDING ROD IS REALLY A DC REVERSE POLARITY ROD. IN THE PAST 7-10 YEARS AGO 7018 AC/DC RODS HIT THE MARKET. THEY WELD LIKE ****! YOU DID'NT SAY WHAT DIAMETER YOUR USING,BUT THE ONLY WAY YOU CAN USE THESE RODS IS TO HAVE A BIGGER MACHINE. THE AC225 JUST DOES'NT HAVE ENOUGH POWER TO WELD IN THE AC MODE. WELDING WITH THIS ROD IN DC REV. IS ABOUT 150 AMPS FOR 1/8 DIA.AND ABOUT 110-120 AMPS FOR3/32 DIA. THIS ALSO DEPENDS ON THE BRAND OF MACHINE YOU HAVE. THE 6011-6014 RODS ARE MADE AC -DC,AND YES THEY RUN VERY NICE ON AC. HOPE THIS HELPS EWE OUT,I WAS A WELDER/FAB FOR 35 YEARS AND LOVED EVERY MINUTE! GOD BLESS AND GOD BYE.
Nov 14, 2010 | Garden
Lincoln electric ac/dc arc welder model ac/dc
Jul 25, 2010 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Welding Tools Logo
125 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
