Question about Euro-Pro EP922H Canister Steam Vacuum
Just stopped working, no steam or heat - Euro-Pro EP922H Canister Steam Vacuum
Suddenly stopped steaming, tank filled steam light stays on, no steam but heats up? Problem solving in manual just states the obvious? Can you suggest anything else or will I have to contact Hoover
Perhaps Element not heating to full temperature to generate steam.
Temperature sensor may be faulty if element is ok.
1 Element or 2 ????
Sorry... No magic fix button
Open it up and start testing things.
a multimeter comes in handy here.
or
back to Hoover repair centre
Good Luck
Feb 03, 2016 | Hoover Vacuums
Mop was working when plugged up & then stopped heating, can this be fixed?
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the
Shark Manuals that you need.
heatman101
Jan 30, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My Shark steam cleaner just stopped working - doesn't make steam anymore. Is there a way to fix it.
I have the same problem - just heard from the support tech to soak the "device" in 1/2 vinegar and 1/2 water. Read on line a customer used vinegar in the device itself, heated it up until it made steam, then emptied it and used distilled water and it was fine. I haven't tried it yet, so we'll see if either solution works . . .
Mar 17, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark steam mop heats up but stopped putting out steam.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
heatman101
Mar 08, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Stopped shark steam mop was plugged in and stopped working, it was working fine and just stopped in is only 7 mos old used 1 time weekly
The heating element may have died or there is an obstruction...
heatman101
Feb 15, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Purchased Feb. '09 and has stopped steaming. Mop
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Here also is a link to get any of the Shark Manuals that you need.
heatman101
bt
Nov 02, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
NO STEAM EVEN THO THE DIAL GOES RIGHT UP TO THE RED
Hi i've had the same problem Put a phial of Kal stop into 1000 or 1500ml of water into the tank, let it heat up and it should break down the limescale of the solenoid. It's worked for me. Have a good evening;-)
Dec 10, 2007 | Polti Vaporetto 2400 Canister Steam Vacuum
Euro-Pro EP922H Canister Steam Vacuum Logo
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
