GE wireless mouse 98543 Mouse wont connect? Driver
GE wireless mouse 98543 Mouse wont connect? Driver isn't installing/driver is completely unavailable on the web...
SOURCE: Microsoft Wireless Notebook Optical Mouse 1023 Need Driver
i wanna know about Microsoft Wireless Notebook Mouse model 1023, is there any driver software need to that mouse, please tell me sir
need a driver, mouse works but USB doesn't light up
Posted on Sep 03, 2008
worldvet
  • 859 Answers
SOURCE: Unresponsive mouse XP unable to initialize device driver for Logitech LX8 laser mouse
Your best course of action would be to use System Restore, based on your response above. Go back to the point where everything worked for you and don't attempt to update your driver again. If it works, don't fix it.
After that if there was something you wanted to accomplish, let us know and we can help you.
Regards,
Worldvet
Posted on Oct 17, 2008
SOURCE: wireless mouse wont connect.
Posted on Nov 04, 2008
rickyostrom
  • 274 Answers
SOURCE: GE wireless mouse not linking
Did you press the reset button under the mouse?
Posted on Nov 25, 2008
SOURCE: Microsoft wireless notebook optical mouse 1023 - not working!
If you know that the battery is good then try this next. There is a VERY tiny shark-fin shaped spring-loaded button on the bottom of the mouse that is pressed in, when you insert the receiver, while the mouse is not in use, that turns off the mouse to save the batteries. If you haven't used the mouse in a while, it can get stuck in the in position, so that when you pull out the receiver, it doesn't spring out and turn the mouse on (indicated by the red light on the bottom). If you notice that the light isn't coming on. Just try manually pushing in the little shark-fin thing a couple times to make it spring back out. After a couple times, you should be able to get it unstuck and the red light should come on.
Posted on Apr 04, 2009
I have a GE mouse 98543, it has been an issue since day one, it seldomly works and ive about had it, the laser does not turn on the bottom, and I have tried switching the batteries but still does not work,...
It could well be a duff mouse. I have had several GE Wireless mice, and a few just failed to connect up correctly however much you push the connect buttons.
But, it is worth trying different batteries. 2 or 3 of my mice refused to work. Like you, I tried everything, including swapping out batteries. After so may attempts I gave up, but then, by chance, tried a different type of battery (may be not Alkaline). Don't use re-chargeables. They have too low output voltage. If you have a test meter, find a couple of batteries that are putting out at least 1.6v each - more if poss. Then go through the press connect on USB plug, then on mouse (within 2 seconds) and if lucky, the LED on the USB plug will go off as soon as you press the connect on the mouse, and you will be in business. If not, may be just a dead mouse!
Aug 21, 2013 | GE Wireless Optical Mouse
My USB and windows vista does not recognize my new optical mouse from GE SKU# is 98543, my motherboard is an ASUS M2N-MX SE, my other optical mouse works fine but when i plug the RF receiver into the usb...
first check the battery inside the mouse make sure it is fully charged and well seated
make sure you have the right mouse selected click start control panel mouse hardware you will see which mouse is selected
you might have to uninstall the mouse then restart your computer then reinstall the mouse and its drivers
make sure the battery is good (has full charge)also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot also you can select properties under driver you will have options to update driver,rollback driver or uninstall and under hardware you can troubleshoot
also click start control panel administrive tools computer management device manager scroll to mice and other pointing devices you might see a yellow exclamation mark !or question mark ? or a red x right you will have options to update driver software,disable,uninstall,scan for hardware changes and properties hope this helps
Apr 01, 2011 | ASUS M2N-MX Motherboard
How do i connect my hp wireless mouse to the computer
The first step is to install its driver, after taht you can connect the wireless dongle into a free USB port of your computer, then put the batteries inside the mouse and turn it on, in the most of cases, the wireless dongle and mouse sinchronize automatically, if they don't, there's a small botton in both devices press it in each one to synchronize them manually.
Feb 25, 2011 | HP Wireless Optical Mouse
Wont connect
in xp
hope this helps
Jan 22, 2011 | GE Wireless Optical Mouse
I got My GE wireless optical mouse awhile ago and now i dont have the directions.how do i install it on my laptop now?
You plug in the wireless antenna (probably a USB stick) and then turn on the mouse (assuming the batteries are fully charged). Then turn the mouse over and make sure it's turned on and press the "connect" button. var fctb_tool=null; function FCTB_Init_cf01f6850bfb477897151238082b50fe(t) { fctb_tool=t; start(fctb_tool); }
Dec 29, 2010 | GE Wireless Optical Mouse
New wireless mouse will not connect and move on the screen. GE 98564
You have to press the button underneath the mouse to turn it on. If it is on a red light should show. You must also install the driver that came with the mouse.
Sep 11, 2010 | GE Wireless Optical Mouse
How to connect a dynex wireless optical mouse w/my windows xp?
Hi, connecting the Dynex Wireless Optical Mouse is easy. First, you need to install the driver for the mouse. It should have come packaged with the mouse, on the CD-ROM. If you don't have the CD-ROM you can download the driver from the website and install it:
http://www.dynexproducts.com/productSearch.html?query=wireless+optical+mouse&mainSearchButton=
Scroll down to "Dynex Wireless Optical Mouse" and click "English" next to "Driver:" to download it, then unzip it and install it.
Once you've installed the driver, all you have to do is put the two AA batteries in the mouse, flip the switch on the bottom to On, and insert the USB receiver into your computer. Your mouse should be usable right away!
Apr 10, 2010 | Dynex Wireless Optical Laptop Mouse
I have a dynex wireless optical mouse but my laptop will not recognise it
Have you installed the driver for the mouse? Did you install it before actually attaching the mouse's USB receiver? The driver should be installed first. You can download it here:
Scroll down to "Dynex Wireless Optical Mouse" and click on "English" next to "Driver:" in order to download it.
If you've already installed the driver and your computer still won't recognize the mouse, press the Connect button on the receiver, wait for the light to flash, and then press the Connect button on the mouse. The light should stop flashing and the mouse should be ready to use.
Nov 23, 2009 | Dynex Wireless Optical Mouse
98811 mouse wont work
The GE 98811 ergonomic Wireless mini mouse is a HID compliant mouse you will need to change the setting to use this mouse. This is what I would suggest:
Go to device manager
Go to the unknown device
Manually pick a driver
Mice and other pointing devices
***Change to a HID compliant mouse***
Then press the connect buttons on both pieces of hardware and the mouse should work
Hope this helps, it took me over two hours to get the mouse working. Very frustrating!!
Sep 03, 2009 | GE Wireless Optical Mouse
Philips freeline wireless keyboard and Mouse
Have you tried re-installing the software for the keyboard & mouse. It sounds like a driver is missing and the best way to solve it in most cases is to re-install the software from the disk that came with the Keyboard & Mouse. Hope that helps. Bud
Jan 05, 2009 | GE Wireless Optical Mouse
Computers & Internet Logo
David Payne
David Payne
