Question about NEC Lands Phones
Nec phone initialize
I moved the phone to a new location, plugged it in and it says "initialize", no dial tone etc
SOURCE: Phone line/phone jack problem
The wiring on the jacks is set up for a 2 line phone.
If you take the jacks apart, you will see either:
A) red, green, and black, yellow
B)white blue/blue white and white orange/orange white
You need to swap the pairs.
If there are red/green/black/yellow wires. remove the yellow/black and move them to where the red/greens are. Then put the red/green wires, where the yellow/black used to be.
OR, you need to swap the orange and the blue wires.
Posted on Dec 22, 2007
  • 146 Answers
SOURCE: Brother CTS=410=es quattro corded phone no dial tone on line #2
Check out the connections, here is the link to the user manual
http://www.westlakecom.com/KXT7700-User-Guide.pdf
and http://www.tmilimited.co.uk/kx-tes824_installation_notes.htm
Posted on Jan 09, 2008
SOURCE: GE portable phone model # 26928GE1-D No dial tone-installed new battery still no tone
what does it mean what your phone is out of range
Posted on Sep 06, 2008
wealthwise
  • 111 Answers
SOURCE: No dial tone
That seems very strange, I can't think of why a phone would screw up your line and dial tone, it may just be a coincidence, the best advice I can give you is to check for voltage on the line, to do this you need a multi-meter and access to the connecting wires on the wall or the line box, short of that sounds like you need a phone tech to take a look at your lines. sorry
Hope this helps.
Posted on Dec 06, 2008
  • 5 Answers
SOURCE: My cordless phone says No link to base Move closer
This is the usual message that the phone gives when the battery has died and it has lost connection with the base unit. The usual fix is to remove and reinstall the battery, then place the unit on the charger for a full charge. This will usually fix the problem that you discribed. If after a full charge, you still get that message, you will most likely need a new battery. Good luck...
Posted on Nov 06, 2009
Handset doesn't have dial tone. says check TEL line.
For this type of problem, you need to isolate the issue. It could be the phone, the inside wiring, or the outside wiring. I like to use an old rotary phone for testing but any basic corded phone should work. Get a new RJ-11 phone cable as well.
Unplug the base unit and plug in the test phone to that jack. Check if you get a dial tone. (Try a new cable if the initial one doesn't work.) If your test phone has a dial tone, then the problem is isolated to the cordless phone. (If the test phone works with the new cable, do check if Uniden works with that cable.) Modern phones are not designed to be fixed by the consumer. If the phone is under warranty, contact Uniden Customer Service. (Otherwise decide if the costs are worthwhile for you; there will be a significant delay before the phone is returned/replaced.)
If you do not get the dial tone, you need to track down the wiring issue. Next move to another jack on the phone line and check if there is a dial tone on your test phone. If there is a dial tone, you have isolated the problem to the jack or the wiring to the jack.
If there is still no dial tone, find where your telephone service comes in to your building. If you can, open the box. Determine the type of connection used there. If you are lucky, you will find a RJ-11 jack for your phone line. Plug in your test phone and check for a dial tone. If there is no dial tone, contact your telephone provider. They will fix this outside problem for free.
If the connection is not a RJ-11 jack, you will need to call the telephone company so that they can determine if the problem is inside or outside.
If you do have a dial tone, then the problem is with the inside wiring. Inspect the visible wires for damage. Open the faceplates for the jacks and check for loose wires. There are two types of connectors. Screw type connectors need the wire stripped back a little then wrap around the screw and tighten. The other type is a punchdown jack. To repair a loose wire in this, you will need a punchdown tool. These are often available in hardware/home improvement stores in the wiring section. http://www.lanshack.com/wire_phone_jack.aspx has clear pictures of the wire color to pin pattern.
You may want a professional to check the wires inside the walls. Your telephone provider will do this for a fee.
I hope this helps.
Jun 21, 2011 | Uniden Cordless Phone
I replaced my desk phone with a wireless and I lost dialtone on all the phones
Are you saying you have a wireless desk cell telephone? Or is this a regular land line telephone with a wireless hand piece? If it is a cell phone with no dial tone, you must see your service provider - this is HIGHLY unusual. If this is a land line telephone with a wireless hand piece - be aware that the dial tone cones from your base transmitter, where ever it is located, (Normally this base should be withing 300 feet of the hand piece) and that base unit MUST be plugged into an active telephone outlet. In the USA, the standard jack is an RJ 11. I suggest you take your old telephone and plug into the outlet where your new base unit is located. Do you get a dial tone? (proves the line is good) Check all wiring - same type of contacts (for your country)? Still no dial tone? Take it back to the store and get them to demonstrate its operation for you - does it work at their store? ... if not, get a new telephone or an adjustment.
Jun 04, 2011 | Cell Phones
L7780 cannot get dial tone on 2-line outlet. Are there any work arounds to this problem?
There is a problem either with the Line Interface Unit (LIU, also known as the fax/phone line connector) or the fax hardware, because the unit is having problems sending or receiving faxes. The unit may hang on "Initializing." This document explains how to troubleshoot the LIU and fax hardware. SOLUTION: Please perform the following: Front panel hangs on "Initializing"
  1. Pull the power cord connector from the back of the base unit to recover from the error.
  2. Unplug the LIU from the back of the ADF. It is located on the left side (facing it), and is where you plug in the telephone lines.
  3. Plug the power cord back in, power it up, and see if it hangs without the LIU inserted.
  4. If it does not hang without the LIU inserted, power the unit down, plug the LIU back in, and power it back up. If it hangs, the LIU is faulty.
  5. If it does hang without the LIU attached, unplug the ADF from the base and see if it hangs. If it does, the base is faulty.
Testing the LIU The primary test for the LIU is whether or not you get a dial tone. Sometimes, you need to re-seat the phone line several times to get a good connection. If after trying the things below, there is still no dial tone, or initialization hangs, the LIU may need to be replaced.
  1. Verify that the phone line is connected directly from the wall jack to the plug in the LIU that says "To Wall Jack."
  2. Verify that the LIU is plugged securely into the product. If it is not, there will be a message at power-up saying the LIU is not connected. If it is, the date and time will display.
  3. If the LIU was re-seated, cycle the power on the unit. The unit should display the date and time.
  4. Unplug all other accessories, like a telephone answering machine or modem. If the LIU appears to work fine after unplugging them, these accessories may be interfering.
  5. Place a document in the Automatic Document Feeder (ADF). The display will flash "Document Loaded."
  6. Press Start Fax to verify there is a dial tone. If so, try sending a fax.
  7. If there is not a dial tone, unplug the product from the wall jack, and plug in a regular telephone to verify there is a dial tone at the wall jack.
  8. If there is no dial tone on the telephone, the wall jack or phone line may be faulty
Oct 26, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
Phone keep initializing
I had the same problem (constant initializing with dropped lines, no dial tone, etc) with my RCA Visys 2-line phone (model 25205) after owning it about 3 months, and could not find a solution on the Web, so I called RCA customer service. They said this problem is not user-fixable and they gave me an RMA# to return it. They will send a replacement phone as soon as you fax the receipt, your name, problem with the phone, etc.. Then when you get the replacement phone you send them the bad phone.
Aug 31, 2010 | RCA ViSYS 2-Line Speakerphone
Dial tone on speaker-phone but no dial tone on line 1
Either button mapping or no dial tone at the system cabinet. If your desplay sas CO1 and you have no dial tone, go to the sytsem cabinet ans swap the modular plugs for CO1 and CO2. If the No Dial Tone moves, "mus be sumpin wrong wit yo lines".
Carl
Aug 13, 2010 | Panasonic KX-T7730 Corded Phone
I want to move a phone. What do I need to do?
All you need to do is find the phone jack nearest to where you want the phone and plug it in. If the phone cord is plugged in properly, and the interior wiring of the house is in good shape, you should hear dial tone.
If not try moving the phone to a different phone jack until you do get dial tone.
Jan 22, 2010 | NEC Electra Elite 32D-1 Corded Phone
DO NOT HAVE DIALING TONE TO EITHER HAND SET
Purchase an old school princess or similar phone at a garage sale or thrift store.. the kind with a corded receiver. Check for dial tone. The first place to check is outside where the INTERFACE is located.. NID (network interface device) is the initial cross connect between the telephone company and your inside wire. The box is usually located near the electrical meter box. If in an apartment complex, contact your manager.
Nov 18, 2009 | Lands Phones
My phone is stuck on rotary dialing. My handset had all the options but the dial mode. After caller id setup it went straight to languages and then started back over with ringer volume.
1) When the phone is in the standby mode, press menu/mute.
2) Press - to move the pointer to “Dial Mode”.
3) Press select/ch and the display will show the current setting.
(The initial setting is Tone.)
4) Press + or - to change the selection.
5) Press select/ch and a confirmation tone will sound.
6) Press end to exit.
Customer Help line for UNIDEN 1-800-297-1023
May 30, 2009 | Uniden TRU 448-2 Cordless Phone
Dell AIO 962 can't get a dial tone
There are 2 phone jack ports on the back of the 962.
One for line, one for phone.
You want to plug the phone line into the port that says "line" or "Fax".
If it's plugged into the wrong one, your fax machine will not get a dial tone.
Jul 31, 2008 | Dell 962 Photo All-In-One InkJet Printer
Lands Phones Logo
150 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
george  peters
george peters
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
