Question about Toaster Ovens
KitchenAid oven, function switch FZ31-9 cannot be bought
KCO223 toast function not working
I too have the same KCO223 countertop toaster oven, and the toast function is not working. All other functions work fine, but the blue light won't come on in the TOAST mode setting.
Apr 09, 2014 | KitchenAid 12" Convection Toaster Oven...
Euro pro to241r
follow this steps and fix it. God bless you
If the oven doesn't work at all, make sure the circuit breaker or fuse is on at the electrical panel and test the electrical cord.
If the oven doesn't work on its toaster and oven functions, test the main switch . As needed, check the fuse.
If the toaster function doesn't turn off unless the door is open, test the solenoid, the switch and if necessary, the thermostat .
Location of the typical toaster oven's thermal fuse.
If the toaster oven stays on when the door is opened, check the main switch . If the oven doesn't heat, test the heating elements
Oct 10, 2013 | Toaster Ovens
Bake no longer works
Kitchen aid will not help, will not sell the part and will not give you a part number for ordering.
the part that goes bad is one of the 2 piggy back function switches. it gets hot from electricity and deforms the plastic causing the connection inside to fail.
I traced all the wiring and made a schematic to use for testing. Kitchen aid refused to even talk about it, so what I share is from my own experience.
By the way, I could not find this part (fz31-9) other than in china and it has a specialized cam inside and 5 connectors. there are 8 that match and not knowing witch cam, makes it very difficult to guess.
the attach diagram worked for me, but it man made and could contain errors.
Mar 11, 2012 | KitchenAid KCO222OB Toaster Oven
Kitchenaid Toaster Oven Parts
FZ31-9 rotary for KC O -111CU, could not be bought
Jan 17, 2012 | Toaster Ovens
Where do i find a replacement knob for timer on the kitchenaid toaster oven model # kc010058
I contacted kitchenaid at 1-800-541-6390 and they graciously sent me a new one at no cost.
Dec 01, 2009 | KitchenAid KCO1005OB 1400 Watts Toaster...
The knobs is broken on my Kitchenaid KCo1005 toaster oven
I had a similar problem a while back and contacted Kitchenaid at 1-800-541-6390 and they mailed me a new one at no cost.
Nov 24, 2009 | KitchenAid KCO1005OB 1400 Watts Toaster...
Kitchenaid kco1005 toaster oven broken timer dial/knob
My kitchen aid toaster oven when set on baking the light is not coming on.
Aug 20, 2009 | KitchenAid KCO1005OB 1400 Watts Toaster...
How do I get a broken function knob replace
Assuming you are referring to a Kitchenaid countertop oven, I would advise you to call Kitchenaid Customer Service. They will be able to send you a replacement function knob at no cost.
Their toll-free telephone number is 1-800-541-6390.
Jun 25, 2009 | KitchenAid Toaster Ovens
I bought a refurbished kitchenaid countertop toaster oven for a super great price and it works like a dream. The only problem is the broken timer knob. I've searched on the internet and I can't find a...
I would suggest calling Kitchenaid Customer Service. They would be able to replace that broken timer knob for you at no cost.
May 10, 2009 | KitchenAid Toaster Ovens
Toaster Ovens Logo
332 people viewed this question
Top Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dave
Dave
Are you a Toaster Oven Expert? Answer questions, earn points and help others
