Question about Bosch WFMC 3200 Front Load Washer
Tub Seal needs to be replaced
Bosch sent a replacement seal and clamp, but the 1 page instruction is horrible! I am a pretty handy do-it-yourselfer on most things, but this looks Greek (or German!) to me. It was literally hand written. Anyone have the directions from the tech repair manual? Thanks Paul
  • Anonymous Nov 07, 2007
    door seal no longer seals! Nead a better install instruction sheet!
  • the hud Dec 07, 2007
    wfmc 3200 what is part no for that front loader seal that has a couple chunks ripped off, leaks. how do you get one and do you know if extended warranty might cover?
  • Bosch Master
  • 744 Answers
This video will show you how to replace the Bosch washing machine door seal with step by step guide on the process
Posted on Jul 19, 2013
    Champion:
  • 249 Answers
This is fourth door seal problem tonight, they are hard to put on no matter what manual you have ,just keep trying, it took me 6 years to get it right IRELAND never read a manual may be thats why it took so long
Posted on Nov 25, 2007
SOURCE:
When the washer goes unto spin cycle, it makes a loud roaring noise and is leaking from the bottom
It sounds like the tub seal is leaking, allowing water to leak out of the tub and damage the drum bearing. Unfortunately you need specialized tools to replace the seal and bearing, so you may have to get a maytag service agent in to look at it. If you're handy with a welder you may be able to make up a tool yourself, it basically consists of a flat hexagon with tabs on the inside to fit the drum nut, and some handles on it. You'll need to remove the front panel and top panel. Then remove the cap around the top of the tub. The agitator is held on by a small screw near the base of the agitator, loosening it will allow you to remove it. Now you can see the tub nut, this is reverse threaded, so it's loosened clockwise. Then you can lift out the drum. Next on the shaft is the top part of the mechanical seal. Remove the grub screw out the side. Now you'll need the same tool you used for the tub nut to undo the seal, rotating in the same direction. Remove the outer tub by undoing the 3 bolts that fix it to the stays, and disconnect the level tube and drain hose. From here you should have printed instructions that come with the new parts to replace the seal and bearing. Please feel free to get back to me if you have any further questions.
Jul 28, 2011 | Maytag Washing Machines
How do I replace the door seal to a Bosch Front loader washer Maxx Classic WAE18060AU?
To change the seal the easiest way is to take the front of the appliance off. Remove the kick plate at bottom and you will see some screws holding the front panel on remove these Then open door and remove the screws holding the door lock on and unlip the seal by releasing the clamp on the front. The front should now lift off, if it doesnt then pull out the soap drawer and behind that at the bottom of the drawer is a screw holding the front on remove this then push the front panel down then it will lift off You can now take the clamp holding the seal to the tub off. Fit the new seal, fit the clamp to the seal and tub. From here, rebuilding is the reverse of the strip down.
Feb 18, 2010 | Bosch Classixx WFO 2466 Front Load Washer
Leaking water from what appears to be the tub-can I replace these parts, perhaps o-rings or seals?
YES !! if youre handy with tools . looks like its a seal, you have to disassemble the washing machine , but its doable. AJ
Nov 11, 2009 | Computers & Internet
Wire clamp that holds seal
The wire clamp that holds the seal for the tub just inside the door has popped off this video will show you how to put it back on
This video will show you how to change a door seal on this Bosch front loader washing machine
we have all bosch repairs in our channel
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 16, 2009 | Bosch Washing Machines
Replacing the tub seal
it is a rather large job to do and unless you are very mechanically minded you would be better off taking it to the repairman
May 09, 2009 | Washing Machines
Door seal needs to be replaced
For most front-loaders:
Plug off the wall mains. Remove the plastic clamp holding the seal to cabinet & peel off the cabinet. Push downwards on the seal close to the tub & the seal will come off - it's just held by a spring on the periphery.
Lubricate the slot which fits over the tub with washing-up fluid. Starting at the top, press the seal so the flange of the tub enters the slot on the seal. Work your way round the using thumbs to force the slot on the tub flange. When slot is on the flange all way round, fit the spring which holds it on. The spring goes into a slot on the outside of the seal. This is quite difficult and you may need another pair of hands. Fit the outside of the seal to the cabinet - this is easy and fit the plastic clamping ring.
Test for leaks before using. Use rinse to test as the water level is higher.
(There is no glue anywhere, only clamps,etc)
Pl rate me nice for the free help!
Apr 27, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
I NEED TO CHANGE THE DOOR SEAL ON A HOTPOINT WF 250 WASHING MACHINE. I HAVE THE SEAL BUT JUST NEED SOME DIRECTION THANKYOU
turn off at mains
undo clamp that holds seal to cabinet and peel seal away from cabinet.
take worktop off
undo clamp that holds seal to tub and seal will then come away
on new seal, lubricate the slot in the seal that goes onto lip of tub with washing up fluid
starting at top, insert slot in seal onto lip of tub and work you way round in both directions till seal is entirely on tub.
replace clamp
fit seal to cabinet (this is easy) and refit outer clamp.
test on rinse cycle as water level is higher. water will foam till washing up fluid is washed away
Sep 09, 2008 | Washing Machines
BOSCH Washing Machine -Door Seal
1) remove the tension ring under the rim of the seal at the front
2) flip the whole seal into the drum so that you can get at the inside of the seal
3) remove the tension ring hold the seal to the outer tub
4) reverse of the process to put in the new seal
Its as simple as that.
Mar 09, 2008 | Washing Machines
Wfmc how to put new seal
hard to explain easy to do. my advice is remove old one, but new on in reverse order its not easy first time ,but i have faith in you .motto do not give up. close ireland good luck
Nov 28, 2007 | Bosch WFMC 3200 Front Load Washer
Door seal
i will tell u step by step 1)open the door undo the clamp that holds the front of the seal on it is around the lip push door seal back so its out of your way into the drum 2)take the lid of look to the front were your seal is fastened onto the outer drum this is held into place with a screw clamp unscrew it and u should be able to ease the door seal of from around the drum reverse these actions to replace the new 1 i have sent these instructions too 3 other people they have found these instructions easy to follow and do
Jun 24, 2006 | Hotpoint Aquarius WF000 Front Load Washer
Bosch WFMC 3200 Front Load Washer Logo
157 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
jimorris77
Dw Wooten
Dw Wooten
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
