Question about Sport & Outdoor - Others
My hummingbird wide vision screen is very dim
Used boat had a hummingbird wide 128 don't know how to operate
Owner's manual. No owner's manual, try manualslib.com
Apr 09, 2015 | Boating
How do hummingbirds fly backwards
A hummingbird can rotate each of its wings in a circle, allowing them to be the only bird which can fly forwards, backwards, up, down, sideways or sit in sheer space. To hover, hummingbirds move their wings forward and backward in a repeated figure eight, much like the arms of a swimmer treading water.
Hummingbird Facts at Hummingbirds Forever
Feb 18, 2015 | Citrix UPG PRES SVR PLATINUM ED FR/ ENT...
Humminbird
My 787c2 screen just shows lines across it does anyone know were to get a new screen for it hummingbird says they don't stock them anymore try Humminbird Fishfinder Depth Finder Humminbird GPS Chartplotters...
Jun 14, 2013 | Humminbird Boating
I need a manual for a 1997 wide 100 hummingbird fish finder
This manual is not listed so you will have to contact customer support by clicking here and filling out the form.
May 15, 2009 | Humminbird Smartcast Rf 35 Dual Display...
Depth finder comes on then goes off
It sounds like some power saver feature on the battery or in the unit. Check with hummingbird, they should have an 800#.
May 12, 2009 | Boating
I have a hummingbird matrix 67 gps chartplotter fish finder. It developed a problem with the screen. The outer edges are legible, but the center is damaged. Is it worth repairing. Are there any other...
Hummingbird will refurbish that one for around 150US dollars, better then 500+ for a new one. If the screen is subjected to direct sunlight and heats up it can go out. This is why they discontinued the 67 model and replaced it with the 767.
Apr 21, 2009 | Humminbird MATRIX 67 GPS Receiver
Bushnell night vision binoculars
They do stay on for a while after switch, that is OK. Dim and out of focus may indicate that the output voltage is low. If replacing the battery does not fix it, then the problem may be in the power supply circuit.
Nov 08, 2008 | Bushnell 26-0400 Binocular
Older HUMMINGBIRD DEPTH SOUNDER LCR-3D . WAS WORKING FINE WHEN I PUT IT AWAY, NOW WONT POWER UP. HAVE CHECKED THE INPUT POWER AND IT IS OKAY. I DO NOT SEE A FUSE IN THE UNIT. ITEM IS OLDER UNIT BUT IS...
We have an old Hummingbird Depth Sounder (Wide 100, 94 model) and it turns on but must be on test mode or smething cause we can not get it off. Does anyone know or have a manual to solve this problem. Please help.
Aug 07, 2008 | Hummingbird GPS
Sport & Outdoor - Others Logo
21 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
