Question about Verizon Communications G'zOne Type-V Cellular Phone
Display screen inside the flip is upside down and backwards
All the writing is backwards on screen of model LC-15B4U-S, how do you reverse it?
On the remote,
1 Press PIC. FLIP to display the
PICTURE FLIP screen.
2 Press PIC. FLIP to change the
setting.
It rotates through several options -- normal, mirror (where you are), rotate, upside down. When you get the picture looking right, stop and the screen will disappear in 3 seconds. See Page 28 of your manual for another option, using the Menu screen.
It I
May 02, 2017 | Televison & Video
Dopo tablet screen backwards
I have the same problem with my dopo td1010 i used it on the city bus one day then put it in the case as i was walking home and took it out when i got home turned it on set it on the table went to us the broom came back and the screen was flipped upside down and backwards. I have had it for a year and a half with the screen like this and cant contact customer service because they wont pick up.
Dec 27, 2013 | Toshiba SD-P1200 Portable DVD Player
On my LG vx8360 the inside display is upside down & mirrored. It just did that one day when I went to read a text. Went to Verizon they were compleatly useless
Hi,what causes upside down display on phones is when the cellphone your using has a flax problem.
A Flex is a thread like object that is located inside the phone. It is connecting both the upper side of the flips and the lower side of the flip phone...
The flex makes the cell phone screen to display...and when the flex is getting damaged, possible signs are upside down display.
To correct the upside down display, you will need to replace the flex inside the cell phone..
For assistance on how to replace the flex, you can go to an expert in phone repair for help..
Hope that helped..
Take care......
Feb 07, 2011 | LG VX8360 Cell Phone
Projector displays reverse image also has grayish purple color
Use the remote to go into the menu and change the screen position. There are 4 to choose from, flip left, flip right, flip upside down left, flip upside down right. It may be tricky to navigae the menu backward though.
Dec 31, 2008 | BenQ PB6100 Multimedia Projector
My screen is upside down N95
Try a firmware (software) update, you can download the NOKIA Software Updater from the NOKIA web site.Do the update even if it is the same SW version that is already on your fone
MAKE SURE YOU BACK UP YOUR DATA 1ST, EITHER WITH THE NOKIA PC SUITE OR ONTO YOUR MEMORY CARD
Dec 27, 2008 | Nokia N95 Cellular Phone
Television screen is showing mirror image not the actual image.
There's a button on the original remote control that does exactly that:
(Please vote or comment if my solution helped you!)
Adjusting PICTURE FLIP Settings
You can set the orientation of the picture.
Directly setting the PICTURE FLIP
setting.
Setting the PICTURE FLIP on the
MENU screen
Press MENU to display the MENU
screen.
2 Press a/b to move the cursor to
PRESET, and press ENTER.
3 Press a/b to move the cursor to
PICTURE FLIP, and press
ENTER.
4 Press c/d to select the desired
picture flip setting, and press
ENTER.
5 Press MENU to return to the main
screen.
NORMAL MIRROR ROTATE
UPSIDE DOWN
A•
The PICTURE FLIP screen automatically
disappears in 3 seconds.
• [NORMAL]: normal image
[MIRROR]: mirror image
[ROTATE]: rotated image
[UPSIDE DOWN]: upside down image
Oct 22, 2008 | Sharp LC-15AV7U 15 in. LCD Television
LG SCREEN RUNS BACKWARDS
in your menu there is a couple of options, one for use with mirror that flips the picture, another that flips the pic for mounting upside down. and another for flipping it upside down with mirror.
please select normal in this option as your prob just mounting it on a desk or table.
good luck
Apr 25, 2008 | LG RU-52SZ51D 52" Rear Projection...
Flipped\upside down screen on my compaq
http://forums.techguy.org/tech-tips-tricks/336002-windows-xp-flipping-screen-upside.html
Windows XP: Flipping the screen upside down and back again
Once, at University, someone had flipped the screens of all the public computers (running on Windows XP) of the English Department upside down. The wallpaper, desktop icons, fonts, mouse-cursor and even the start-up screen...everything was displayed or moved upside down. People could not check out their e-mails or surf or do anything.
To reverse the upside down screen mode, press ctrl, alt and the up arrow (arrows console) at the same time; the screen will probably go blank. Turn off the monitor, turn it on again and the display will be normal again. If you possess a sense of humour or are antisocial, press ctrl, alt and the down arrow simultaneously, turn off the monitor, turn it on again and everyone (excluding the culprit) will be desperate --> upside down! Works for Windows XP Home and Prof.
Mar 31, 2008 | Computers & Internet
Picture reversed and upside down on screen????????
just happened to me, phoned customer support and solution is to press the Ctrl key and Alt key and Up arrow together and it should solve the problem
May 02, 2007 | Toshiba SD-P1200 Portable DVD Player
Verizon Communications G'zOne Type-V Cellular Phone Logo
27 people viewed this question
Top Verizon Communications Cell Phones Experts
Computer Repairing
Computer Repairing
ismael castillo
Are you a Verizon Communications Cell Phone Expert? Answer questions, earn points and help others
