Question about GN Netcom GN 9120 Professional Headset
Incoming alert I do not get a ring in my headset when I have an incoming call. Other than that the headset is fine. Can you help?
Generally you will get a ring in the headset when a call is detected by the lifter that you use or if you don't have a lifter then you would have to use the little microphone that comes with the unit and affix that to the speaker on your phone so that your GN 9120 knows when to alert you of a call.
Posted on Jan 08, 2008
SOURCE:
Incoming call alert
You will need the Plantronics HL10 handset lifter in order to have the CS55 ring, indicating an incoming call. The HL10 also allows you to answer remotely on most phones and hang-up remotely.
Plantronics HL10 Handset Lifter
Good Luck from Headsets Direct!
May 17, 2011 | Plantronics CS55 Wireless Headset
I use the handset lifter for the phone I have (Polycom SE-225). When am sitting at my desk neat the phone, I speak anything above a low normal into the bluetooth headset, like when I am laughing or people...
Unfortunately no. The phone ringer has to be a certain volume for the lifter microphone to pick up the ringing vibrations. If you put it to low, you will not be alerted to the incoming calls. When you're at your desk and can see the incoming calls, maybe then you can lower the telephone ringer volume for some relief.
Good luck from Headsets Direct!
Jan 03, 2011 | Plantronics Voyager 500A Deskphone Adapter...
How do i put phone on silent
User profiles
This is used to set up the different ways of incoming call prompts in various situations. Use
the up/down key to choose this option and click the left functional key to enter. There are
many modes of setting available and the default setting is the general mode.
To switch to a new user profile, use the direction key to select the target mode and click
“OK” to enter. Then select “activate” and click “OK” to confirm. Your phone will give an
“activated” prompt, indicating that the user profile is active. The “headset” mode does not
require activation; your phone will automatically switch to the “headset” mode if a headset
is connected to your phone, and back to the previous mode when unplugged.
You can also customize each user profile setting for your preference, the following
operations are available:
(1) Ring tone settings:
Incoming calls: Enter “user profile”, select “personal setting”, and set up the ring tone.
Power on: set up the music for power on.
Power off: set up the music for power off.
Message: set up the message ring tone when a new message arrives.
You can also download ring tones online.
(2) Volume
This allows you to set up the volume for ring tones and keypad tones. There are 7 grades
available. Enter this function and use the up/down key for testing and adjusting.
(3) Alert type
This is used to set up the alert type for incoming calls. Please select the suitable alert
types in different situations.
Mar 25, 2010 | Cell Phones
Our incoming calls are not ringing?
wen i receive incoming calls there is no ring or message alert
Dec 10, 2009 | Uniden Cordless Phone
For my LG Xenon...alert to ring rather than incoming caller
Go to menu>Settings>Applications>Voice Command>Call Alert>Ring only
Aug 30, 2009 | LG Xenon GR500 Cell Phone
CS70N Wireless headset
The earpiece will make 3 short beeps when a call is incoming. Also the phone will still ring if you are within distince to hear the ringer. Hope this helps! SM
Sep 10, 2008 | Plantronics CS70 Wireless Headset
Pairing motorola hs810 with sony ericsson k800i
unless it is a stereo bt haeadset is the only way you would hear a mp3......
Aug 18, 2008 | Sony Ericsson K800i Cellular Phone
H700 Problem
I have a Motorola v557 and have to turn up the key volume in order to get the ring tone in my ear. Hope this helps
Dec 20, 2006 | Motorola Mobility H700 Wireless Headset
GN Netcom GN 9120 Professional Headset Logo
627 people viewed this question
Top GN Netcom Radio Communications Experts
Steve Morris
Steve Morris
Level 1 Expert
Tom Chichester
Alan Palmer
Level 1 Expert
Are you a GN Netcom Radio Communication Expert? Answer questions, earn points and help others
