Question about Schlage BE365-CAM BE365CAM505 Lifetime Polished Brass Electronic Security K
Change combination I need to change the combo. How would you go about doing so?
Don't want anybodythat might know my original safe combo to get in it door open cover off know original safe combo have all other info of ownership can I change combo of 1250 sentry safe
If the door is opened..Then you would need to remove the cover to the lock at the back..You will see a screw on the last wheel of the lock..Move that screw into a different hole on the wheel..Then you can dial the wheels to the lever..Each wheel is a number..This will give you a new combination..My advice to you would be to locate a Safe Tech/Locksmith..Have them do it for you..
Apr 18, 2017 | Sentry Home Security
How do i change a turn signal relay on a 2000 Chrysler Concorde
The Combination Flasher, also referred to as the combo-flasher, is mounted to the in-line bracket which is located to the right of the Junction Block. The flasher can be removed by pulling in a rearward direction. The left under panel silencer duct must be removed to access the flasher. The combo-flasher is black in color for ease of identification.
The Turn Signal and Hazard Warning Flasher is combined into one unit called a Combination Flasher (Combo-Flasher). The combo-flasher controls the flashing of the hazard warning system and the turn signal system. An inoperative bulb or incomplete turn signal circuit will result in an increase in flasher speed.
Ref: http://www.10w40.com/questions/auto-repair-questions/where-is-the-flasher-relay-on-a-2000-chrysler-concorde
Good Luck
Mar 03, 2015 | 2000 Chrysler Concorde
How do I change combination?
You may have to contact manufacturer. Some safes do not change. If you need to find combo for Sentry safe you'll find a sticker with numbers by the hinge. You'll need to send ownership affidavit (from their website) with this number and a fee and they'll send you the combo code for this unit.
Dec 15, 2014 | Home Security
Need to reset pin on VX-FT21 aiwa tv/vcr combo how do you do this???
how do i change brightness/colour/contrast if i dont have the romote control for the aiwa VX-FT 21. video/TV combo. My screen has got really dark and I cannot find a manual pannel to change it form on the TV - me and all my friends have looked everywhere but there - if someone could email me at twistedsoraya@hotmail.com that would be great. Thank you
Jan 04, 2011 | Aiwa VX-T1470 14 in. TV/VCR Combo
How do change the combination on Brinks Home security saft Model 5074 serial #120.0401A
How do I change the electronic keypad combination on a Brinks Model 5074? This isn't quantum physics, but I sure can't figure it out. Can anyone provide the proper sequence to reset the combination? Thank you.
Sep 01, 2010 | Sentry Fireproof Safe
Need instructions on changing combo
PROCEDURES TO CHANGE THE COMBINATION OF
SIMPLEX 1000 SERIES CIPHER LOCKS
1.) ENSURE THE DOOR IS OPEN.
2.) INSERT THE DF-59 CONTROL KEY INTO THE COMBINATION CHANGE PLUG ASSEMBLY (ON THE BACK OF THE DOOR) AND UNSCREW THE CYLINDER BY TURNING THE KEY COUNTERCLOCKWISE.
3.) TAKE THE CHANGE PLUG ASSEMBLY COMPLETELY OUT OF THE DOOR.
4.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE ALL THE WAY UNTIL IT STOPS, THEN RELEASE THE KNOB.
5.) PRESS IN THE EXISTING COMBINATION FIRMLY.
6.) INSERT THE SPANNER WRENCH IN THE COMBINATION CHANGE SLEEVE. IT SHOULD INSERT AT THE NINE O’CLOCK POSITION.
7.) TURN THE SPANNER WRENCH GENTLY CLOCKWISE UNTIL IT STOPS AT THE 12 O’CLOCK POSITION. NOTE THE NOTCHES IN THE COMBINATION CHANGE SLEEVE MOVES AS THE SLEEVE IS MOVED.
8.) TURN THE SPANNER WRENCH COUNTERCLOCKWISE BACK TO THE NINE O’CLOCK POSITION UNTIL IT STOPS. REMOVE THE SPANNER WRENCH.
9.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE (ALL THE WAY, UNTIL IT STOPS), THEN RELEASE.
10.) INSERT THE NEW COMBINATION BY PRESSING IN THE BUTTONS. USE AT LEAST three numbers and a maximum of five.
11.) TURN THE DOOR KNOB CLOCKWISE ONCE, ALL THE WAY, UNTIL IT STOPS. HOLD IN THIS POSITION AND CHECK IF THE LATCH IS RETRACTED.
12.) RELEASE THE DOOR KNOB.
13.) TURN THE DOOR KNOB CLOCKWISE ONE MORE TIME TO THE STOP POSITION. AT THIS POINT, THE LATCH SHOULD NOT RETRACT UNLESS YOU USE THE NEW COMBINATION.
14.) REINSERT THE CYLINDER INTO THE BACK OF THE DOOR BY SCREWING IT IN CLOCKWISE WITH THE DF-59 CONTROL KEY (DO NOT OVERTIGHTEN!)
REMOVE THE KEY.
Aug 04, 2009 | Simplex Kaba Ilco Unican 1000 keyless...
How do I change an electronic safe combination?
hi, on mine if you open the door their is a red button press and hold for five seconds, then release put new code in then press again for 5 secs turn thelock to lock position do not close the door, put in the new code and see if it ulocks, if so, bingo, DO NOT CLOSE THE DOOR TILL YOU ARE CERTAIN THE CODE YOU PUT IN WORKS, hope this helps, mine only has a four digit code but i think its the same set up.
Feb 18, 2009 | Schylling Combination Steel Safe
Toshiba 13' tv dvd combo, Fios remote control need code
Greetings!
Here are the codes: take a deep breath:
0181, 1283, 0183, 1292, 0087, 0677, 0859, 0872, 1183, 1383, 1683, 1731
You may find that these don't work. Often, with combination pieces like yours, you will find you are lucky if you can get a universal remote to turn it on and change the volume and little more. The fact that Toshiba did not build this peice can compound the problem. My suggestion, if you can't get the universal to program up, is to use the original remote for the set. If you do not have the original remote it is available from www.encompassparts.com for around $15.00 plus shipping. The original part number for the Toshiba remote is 72796929.
Rob
Jan 14, 2009 | Toshiba MD13N3 13 in. TV/DVD Combo
Schlage BE365-CAM  BE365CAM505 Lifetime Polished Brass Electronic Security K Logo
Top Schlage Locks & Locksmithing Experts
JOHN LAPIER
ken skalski
Are you a Schlage Lock and Locksmithing Expert? Answer questions, earn points and help others
