Question about Toshiba 50H81 50" Rear Projection Television
Wavy junping horizontal lines
My screen is covered with wavy and jumping horizontal lines. It started out when I first would turn it on, and it would take five to ten minutes to stop. Now it never stops. I can watch it after about an hour of being turned on, but it does not stop completely any more. Sure would appreciate a solution. Thanks
  • Anonymous Nov 27, 2007
    I'v had the same problem but if you push that button on the remote the splits the tv into two screens then the second screen is clear.... freaky
Requires the hyper board to be repaired . Has to be sent to Toshiba, unless you can change around 15 surface mount capacitors, They usually charge around 420 to 450 Canadian
Posted on Aug 31, 2007
SOURCE:
Wavy lines 2007 philips
try repositioning the board into it's slot
Apr 25, 2014 | Philips Lj41-04218a For 50pfp5332d/37...
My samsung projection tv has blue wavy lines on top of screen, I adjusted convergence, the blue will not line up horizontally, is there a inexpensive solution?
It means one of the chips has a bad section inside it, both chips and maybe a resistor near them will have to be replaced, involves soldering as each has about 18 pins soldered in
Check with TVrepairparts.com who sells some kits for this by brand and model number
Dec 09, 2012 | Televison & Video
Horizontal wavy lines on picture
Sounds like the convergence has failed. This video gives more details
Apr 12, 2012 | Mitsubishi WS-55513 55" Rear Projection...
Screen covered with wavy lines what can I do ?
if you are technical then open the monitor and see the primary filter big high voltage capacitor is expanded replace it problem will definatly solved
Mar 09, 2010 | Computers & Internet
TV screen turns totally green and has a wavy line
try remove the casing of ur tv go on the yoke, u see small board connecting to the yoke the try resolder all the part.Look on the main board some part are only lost look for it then resolder.Most especially the of chroma section wherein the colors are blending here i recommend to resloder properly sure to it that it will not jump to other pin.
Jun 18, 2009 | RCA 24F512T 24" TV
Wavy lines
Are the wavy lines horizontal or vertical? If they are horizontal and up near the top of the screen it could be 60HZ interference from a power cord running over the cable from the DVD player to the TV. There could also an internal breakdown of the shielding by the power supply of the DVD player. If the lines are vertical it is likely the cable or maybe the input jack on the TV. Could be a number of things.
Nov 09, 2008 | Sony DVP-S500D DVD Player
Mitsubishi VS-45607 45" Big Screen
Good Day, Delano1981;
It may cure the problem but I would suspect the 9 Volt source
CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND
IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH
ARE ON THE SIGNAL PCB.
This should resolve your TV"s condition.
Good Luck, big IRISH.
May 27, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Playback problem on SP Tapes - Top 1/3 of screen wavy lines
there are guide posts that the tape goes around, they need to be adjusted if your good at that stuff take off cover and while playing tape be careful you could damage video head.with flat srew drive . adjust right post buy turning clockwise or counter clockwise. this could be hard i hope i helped , When i first started ny video shop 1987 we started doing only vcrs.
The video head also could be bad. thanks doctor video
May 04, 2008 | Sony SLV-D350P DVD Player/VCR
Sylvania 6427FF TV displays wavy verticle lines at top of the screen.
I would suspect defective filter capacitors in the sweep circuits as well as the power supply source voltages.
Aug 07, 2007 | Sylvania 6427FF TV
Wavy Screen on Startup
I gather from your post that wavy can mean two possible things as the TV comes on, you see the picture flow like ocean waves? In this case you may have 60Hz hum modulating with the picture, this is actually unlikely these days, but I have heard it happens sometimes. The other thing it could be is light horizontal tearing. This happens when the horizontal frequency is too high or too low. You are not going to like my solution because I feel that for problems like this the set must be analyzed not just subjected to "shotgun troubleshooting", so here I go, Take the TV to a repair shop.
Feb 28, 2007 | Toshiba 50H72 50" Rear Projection...
Toshiba 50H81 50" Rear Projection Television Logo
273 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
