Question about HP PhotoSmart 1215 InkJet Printer
Ink system failure code on HP Photosmart C6150 all in one printer
SOURCE: HP photosmart C6150 all-in-one error
Been on an online chat with HP in INDIA for over an hour. Given that you would "think" the error might have to do with the inside or "ink" you would think they would have me open the machine. If there is enough room you've got to read this online chat. WORTHLESS and I will never buy another HP printer ever again. This All-in-one was 372 days old and for them to not even consider going inside but to immediately tell me to buy another one. I hope you can see all of this. If not email me at SusanVette [at] ya hoo dot com and I will share it with you. Doesn't all fit so here is their bottom line:
Sequoia: I wish to inform you that HP is providing an option to exchange this defective unit with a new released All-in-One unit.
Susan : How much?
Sequoia: Let me also explain the complete process in detail so you can pick the model that suits your requirement.
Sequoia: You can upgrade the defective printer for a upgraded printer. Under the upgrade option, you have the option of buying a upgraded printer at much lower prices.
Sequoia: It means, we will send you with the another printer with a minimal cost (which is equivalent to the service charges for repairing your defective printer) then we will take your defective printer.
Sequoia: Moreover, the shippment charges will be borne by us.
Sequoia: Would you be interested in looking at these options?
Susan : yes how much
Sequoia: We have HP Photosmart C7280 All-in-One Printer, Fax, Scanner, Copier.
Sequoia: You can use the same cartridges with this model.
Sequoia: The features of this model are:
• Built-in wireless and Ethernet connectivity
• Easy two-sided printing
Sequoia: The Actual price of this All-in-One is $299.99 *
Sequoia: However, under upgrade option HP is offering for $157.99
Susan : how do I proceed when i am ready as I want to read all the reviews on that particular model
Sequoia: I am afraid this offer is not applicable in hpshopping.com or from stores, as this offer is only applicable online from us.
Sequoia: If you would like to go ahead I shall arrange a call back for you so that you can order the printer directly from our call back team.
YADA YADA YADA... Write me at above email for full chat.
Posted on Sep 03, 2008
SOURCE: HP Photosmart c7180: "Ink System Failure" error code Oxc18a0306
I get the ink system failure message on my hp c7180 as well as an error code of oxc18a0306.
Posted on Nov 21, 2008
SOURCE: HP Photosmart D7360 - Oxc18a0001 Ink System Failure
I had the same problem and this is how I fixed it... It is hard to get the cover off (and it's not the top cover, but the one on the right side as facing), but once you do follow the directions below.
- Turn off power and unplug from power source.
- Open right side of printer (looking at the front).
- Disconnect by pulling gently, both white flat ribbon cables off the main circuit board.
- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
- Unplug power source.
- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
- Plug in power source and turn printer on (Printer preparing occurred).
Posted on Jul 11, 2009
SOURCE: Ink System Failure HP C5180
-------solution 1---------
HP C5180
Hidden tech menu For resetting and repair, FIX UIAUX
Fixes error 0xc18a0507 error ink system fail
press <left arrow> then press <setup> button together
then press <ok>once support R0631m comes on screen
right arrow 2 times to the System configuration menu
then <ok>
then <ok> to select and ok to confirm reset error.
then <cancel> to escape ( all of witch are onscreen instructions.)
presto restart and no further error
http://www.thecomshack.com/hpc7180.htm
------------- solution 2 ----------------------------------
HP C5180 All-In-One Printer HARD RESET:
Hold down HELP + OK button and unplug printer
Hold down HELP + OK button again as you plug the printer back in.
Then power it on, if it doesn’t power on automatically.
Be Safe: keep holding the buttons until the printer turns itself off. (It took mine less than a minute.)
Now you can release the buttons and simply power it back on.
I got an error message about “improper shut down” since I unplugged it w/out powering down. After I clicked “OK” the printer was just fine and didn’t mind anymore. And now I can print.
Posted on Sep 21, 2009
MUKHTAR
  • 2017 Answers
SOURCE: HP Photosmart C6180 Ink System Failure Message
just follow this steps may help you out otherwise you need to change it.
Check to see if the installed cartridge is the correct one for the printer. . If the cartridge is the proper part number, remove the ink cartridge and make sure all the packaging tape has been removed from the copper circuitry strip on the backside of the cartridge. Reinsert the cartridge and try printing again.
If the error continues, remove the cartridge again and clean the copper circuitry strip on the backside of the cartridge, and the contacts inside the printer, by following the instructions below:
1. Use a clean, dry, soft, lint-free cloth. Locate the copper-colored circuitry strip on the back of the cartridge.
2. Wipe the copper-colored strip with the dry cloth. Use an upward motion, from the nozzle end to the top of the cartridge. Do not wipe the nozzle end of the cartridge or touch the nozzle plate. Wipe the contacts only once.
3. To clean the printer contacts, carefully look for fibers or contamination on the electrical contacts inside the carriage assembly, but do not wipe the printer contacts with any object. The contacts in the printer can be damaged if too much pressure is applied during a wiping process. Try to remove any visible attached debris within the carriage assembly by gently pulling the debris off with your fingers. If the carriage contacts show noticeable damage, contact the HP Customer Care Center listed in the printer's User's Guide.
Reinsert the cartridge and try printing again. If the error continues,then you can go for repair or buy a new one .but i advise you to dont go for repairing bcoz it is 3 year old .
Have a nice day and do not forget to rate please...!
Posted on Feb 02, 2010
Hp photosmart c6150 all in one error oxc18a0206
hey, with this document you will be able to fx the printer if you ever got a message like ink system failure 0x...
on hp printers
http://rapidshare.com/#!download'253l34'140957209'Assert__Ink_System_Failure_Actions_for_PhotoSmart_Six_Ink_Products.doc'258
Mar 03, 2011 | HP Office Equipment & Supplies
HP c6150 all in one error message Oxc19acff Ink System Failure. Replaced Yellow ink cartridge an still receive error.
Turn off the machine using the power button, unplug the power cord from the back of the machine, remove the ink cartridges, wait 2 min, plug the power cord back in, press the power button to turn on the machine, wait until the printer prompts that the ink cartridges are missing, then replace the ink cartridges. If this doesn't fix the problem you may have to re-prime ink through the system. There are instructions for doing this at http://www.ccl-la.com/blog/index.php/hp-photosmart-ink-system-failure-1/.
Jan 30, 2010 | HP Photosmart C5180 All-In-One InkJet...
Black ink will not print on Photosmart C6150; Ink
I'd do the reboot of the printer.Turn it off,unplug for 60 seconds,plug it back in,turn it back on and see if the black will work.After plugging back in it should clean the print head and then you can do a test page to make sure.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00728224&cc=th&lc=en&dlc=en&product=1153494
This site will show you how to print a test page.
Jan 24, 2010 | HP Photosmart C6180 All-In-One InkJet...
Ink system failure was working fine the I stopped
Found on HP Web The link is below. If you find this helpful, pls rate me.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00723815&dlc=en&product=1153494
This document applies to the HP Photosmart C6150, C6170, C6175, C6180, C6183, C6185, C6186, and C6188 All-in One.
Issue
An 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The all-in-one cannot copy, receive faxes, or print.
Solution
  1. Press the On button to turn the all-in-one off.
  2. Unplug the power cord from the back of the all-in-one.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the all-in-one.
  6. Press the On button to turn the all-in-one on.
  7. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the all-in-one.
Good Luck.
Jan 04, 2010 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart 8250 Ink System Failure,error code Oxc18a0007. I've tried HP site for solutions with no success. Also tried re-installing software,replacing ink (all genuine HP) but no luck!
Ink system failures is a very serious problem on HP printer systems. If you have this problem you should be ready to replace your printer. However there are still troubleshooting steps that you can do to try to resolve this problem. try this Ink System Failure Trouble shooting guide.
Jun 17, 2008 | HP - HP Photosmart 8250 printer
0xc19ac3ff error code
Same deal. Message "ink system failure". I restarted the printer, it works fine
Mar 07, 2008 | HP Photosmart C7180 All-In-One InkJet...
HP PhotoSmart 1215 InkJet Printer Logo
20 people viewed this question
Seeker5211
Seeker5211
