Question about Ovens
My kenmore 790.9532 will not heat - Ovens
I have a smooth top kenmore oven model #92172300 when you use the oven it gets to the temperature but then its shuts the heat off i had heating element tested and its good please help
The thermostat controls the heating element. If it comes to temp you know the element is OK. The thermostat can be tested. or just replace it.
Nov 18, 2016 | Kenmore Ovens
My kenmore slide in oven gets warm but doesnt get hot enough to bake anything
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Aug 25, 2011 | Kenmore Ovens
Kenmore Elite Gas range, model # 790.79363401 The range works but the oven does not seem to heat up. It appears to ignite, just not get hot.
the problem should be from the heating element of your Kenmore Elite Gas range. The heating element is either defective or may have loosed contact as a result of heat coming out of the Oven. The heat coming from the oven may have melted the wire connected to the heating element which might not make it heat up.
Disassemble the oven and check if its actually the wire connected to heating element that got melted, or its time to replace the heating element.
Good luck.
Dec 15, 2010 | Kenmore Ovens
My kenmore oven will not bake it only broils.
If your electric2_bing.gif oven is not heating then you probably have a bad heating lelement in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Jul 18, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Oven doesn't heat up
heatman101
May 06, 2010 | Kenmore 30169 Electric Single Oven
Kenmore oven door locked need help
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
heatman101
Asker's Testimonial " thanks i will have my husband look into that. " - 2gunsally
May 31, 2009 | Kenmore 30169 Electric Single Oven
Kenmore oven - will not heat on bake / will heat on broil
its your temp sensor. replace it and it should fix ur prob
F2=overheat
is your bottom element connected?
Mar 23, 2009 | Kenmore Ovens
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
