Question about Watches
How to pull out crown/button from sekonda water proof watch?
  • Watches Master
  • 18,411 Answers
Unscrew it first then pull out after you have adjusted time push back in and screw in
Posted on Aug 01, 2013
Testimonial: "How do I unscrew it? In the instructions it says for screw-down crown turn it anti-clockwise (im assmusing thats turning it upwards when facing the watch towards me?) I tried that and it just keeps turning nothing happens"
  • Aaron Aug 01, 2013
SOURCE: rmoving the corwn from a new sekonda watch
all Calibers are different. If you look on the plate where the stem protrudes from the movement you should see a small button that has a dimple in it to prevent your tweezers from slipping when you push it down to release the stem.
Donald McPherson C.W.
www.finewatchmaking.com
Posted on Dec 05, 2007
escapement
  • 2334 Answers
SOURCE: Brand new watch and second hand is not ticking.
Yes, unfortunately the seconds hand, or, to be more precise, seconds wheel is faulty. There is nothing you can do yoursef as this fault requires attention and knowledge of watchmaker.
Find your nearest watch repair shop and ask for help.
Rate me, please.
Posted on Mar 25, 2009
cmcduncand
  • 714 Answers
SOURCE: my sekonda pocket watch is stamped au 10
My pocket watch is stamped Elgin.
We are sure yours is very nice.
Posted on May 14, 2010
mcdevito75
  • 1970 Answers
SOURCE: how do you pull the crown out on and invicta watch
mcdevito75 here, Your invicta may have a screw down crown that adds water proof protection to your watch, try to un-=screw the crown when un- screwed then pull up to set time.
Posted on Jun 27, 2010
mcdevito75
  • 1970 Answers
SOURCE: how do i remove the back on my sekonda mens watch
mcdevito75 here, Generally thr back is simply pryed off useing a sharp knife (steak) or with a case opener, or at times the back is screwed on, little square holes around the back of the watch require a special tool, or there may be 4 screws holding down the back to the case, even if you get the back off you may need Jewelers screwdrivers to remove / replace the battery. BEST BET, look for a small watch repair shop in your area.
Posted on Jul 12, 2010
Need a new glass for men's seconds watch
I assume you mean a Sekonda watch.
Watches from large scale manufacturers like Sekonda come with a wide range of glass sizes. 30mm diameter is a common one, but you would need to remove the glass in one piece to measure it. Watch glasses are commonly in 0.5mm steps (e.g. 30.0mm, 30.5mm,31.00 mm etc.) and may have rounded or bevelled edges so it is often very difficult to determine the exact size without removing the glass.
Additionally, there is the thickness of the glass to consider.
Finally, the 'glass' may be plastic, mineral glass or sapphire crystal.
All in all, you will have to know how to remove the back of the watch, how to remove the crown and stem in order to remove the movement, how to remove the glass in one piece, how to fit a replacement glass, how to refit the movement, how to refit the crown and stem and how to refit the back.
Alternatively, take it to a watch repair centre - you'll still have a working watch after they've finished with it.....
Oct 18, 2017 | Watches
Sekonda 1036 watch hands not turning, is there a set-up procedure that I'm missing ?
As long as the battery is OK, pull out the crown, go forwards and back a few minutes and press the crown back in.
Feb 07, 2017 | I'm Watches
I've lost the instructions and can not reset it
Mate I googled the sekonda web site and this is the link-->
http://www.sekonda.co.uk/index.php?fuseaction=Static.faq
It's on the frequently asked questions page and if you click on the 10th question down (How do I use and adjust my Sekonda watch) a message drops down saying click HERE to download the sekonda instruction manual..... I hope this helps......CHEERS..
Mar 12, 2016 | Watches
How do I change the day, date etc on a GENEVA 7391 watch
read the instruction manual, Geneva Watches with Two or Three Hands
  1. Pull the crown out until you feel a click.
  2. Turn the crown counterclockwise until you have the correct time.
  3. Push the crown back in to set the time.
Geneva Watches with Two or Three Hands and a Date Window
  1. Pull the crown out until you feel two clicks. This second click position allows you to set the time.
  2. Turn the crown counter clockwise until you have the correct time. Push the crown all the way in to set the time.
  3. Pull the crown out until you feel one click. This first click position allows you to set the date.
  4. Turn the crown counterclockwise until you have the correct date. Push the crown back in to set the date.
Multi-Function Geneva Watches
  1. Pull the crown out until you feel two clicks. This second click position allows you to set the day.
  2. Rotate the crown counter clockwise until you have the correct day. Push the crown in to set the day.
  3. Pull the crown out until you feel a second click to set the time or the 24-hour hand.
  4. Turn the crown clockwise until you have the correct time, then push the crown in to set it.
  5. Pull the crown out just one click to set the date. Turn the crown clockwise until you have the correct date, then push the crown in to set it.
Geneva Chronograph Watches
  1. Pull the crown out two clicks. This second click position allows you to set the time.
  2. Turn the crown clockwise until you have the correct time, then push the crown in to set it.
  3. Pull the crown out just one click to set the date. Turn the crown clockwise until you have the correct date, then push the crown in to set it.
  4. Stop and start the chronograph by pressing the PA button, located above the crown.
  5. Reset the chronograph by pressing the PB button just below the crown. The PB button returns the chronograph second and minute hands to their original positions of zero.
Automatic Geneva Watches
  1. Wind the mainspring by turning the crown 15 to 20 times clockwise.
  2. Pull the crown out until it clicks.
  3. Turn the crown counterclockwise until you have the correct time, then push the crown in to set the time.
Tips & Warnings
  • Do not set the date or time between 8 p.m. and 3 a.m. to avoid damage to your Geneva watch. The gears sit too close together during these times.
  • If your Geneva watch becomes wet, wipe it dry as soon as possible. Keep your watch away from saunas and hot tubs, as the extreme heat diminishes the watch's water resistance.
Read more : http://www.ehow.com/how_6134550_set-date-time-geneva-watch.html
Jul 13, 2015 | Geneva Watches
Manuel for yacht timer 700 please. Best regards P.Hessner
Could not find a download for instructions on this watch, but I did manage to find some basic instructions for the Sector brand. I hope this helps as this is the best I can come up with.
Good luck.
Sector Chronograph Watch Instructions
  • Most chronograph watches have screw-down crowns for water resistance. You must unscrew the watch crown before you can make any changes to the watch time. After time is set screw the crown back in. To utilize the chronograph dials, use the buttons on the side of the watch. One button will be for the second timer. Press once for the second hand to start timing. Press again to stop it. Another button will be to reset the second hand timer back to zero. Sector Chronograph watches may have different dial functions (see link in References).
  • Sector Dual-Time Watch Instructions
  • Because Sector watches are known for their sports capabilities, the Dual-Time watches have screw-down crowns. For Dual-Time timepieces, unscrew the crown counterclockwise. Pull the crown to middle position to set the date. Pull the crown out to its fully extended position and rotate it to set the day of the week, hour and time. Press and hold in the crown and turn clockwise to seal the crown back in to the watch.
  • Sector Ana-Digi Watch Instructions
  • Sector Ana-Digi timepieces have analog hands plus digital timekeeping functionality. To set the time, unscrew the crown counterclockwise and then clockwise to the appropriate time. The digital functionalities are programmed by the buttons on the side of the case. Depending on the style of the Sector watch, you can set the digital time with one button, set the date display, 1/100 seconds chronograph timer, altimeter, thermometer and alarm functions.
  • Aug 12, 2010 | Sector 700 2653700025 Watch
    Hi, I got a pre owned cartier watch roadster chrono, i dont how to wind the watch, it has some type of screw like button. Thanks, Ron
    mcdevito75 here, That may be a screw down crown to help maintain water proofing, Best Bet, look for a small watch repair shop in your area for help with your Cartiers functions, you can also try to contact Cartier online, Cartier watch.com
    Jul 03, 2010 | Cartier Roadster W62019X6 Wrist Watch
    How do you pull the crown out on and invicta watch
    Jun 26, 2010 | Invicta Subaqua Noma Iii S
    No instruction manual
    For Compass Adjustment search on Google or FixYa
    For Temperature calibration:
    1. Pull the crown to most extended position (2 notches)
    2. Temp hand moves to a default position
    3. Move hand in + or - direction by pressing temp or tide buttons (above and below crown button)
    4. When done, push crown to 0 position
    (I used melting ice water to calibrate and fix to 0 deg C)
    For Tide calibration:
    1. Pull crown to middle position (1 notch)
    2. Move hand in + or - direction by pressing temp or tide buttons (above and below crown button)
    3. When done, push crown to 0 position
    Hope this helps
    Sep 17, 2009 | Timex E Tide Temperature Compass Watch...
    Rmoving the corwn from a new sekonda watch
    Dec 05, 2007 | Watches
    Watches Logo
    190 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
