Question about Mtd 22" Yard Machine Push Mower
I have a mtd lawnmower no prime no choke readystart just pull for power that wont start
  • 22 Answers
SOURCE: lawnmower wont start
Possible Causes Corrective actions
Unit will not start Control handle is not engaged Engage control handle spacer.gif spacer.gif
Spark plug wire is disconnected Connect spark plug wire spacer.gif spacer.gif
Fuel tank empty or stale fuel Replace with clean, fresh gas spacer.gif spacer.gif
Air filter filled with dirt or debris Replace or clean air filter
Posted on May 23, 2009
hunter19_46m
  • 7482 Answers
SOURCE: wont start and lost manual for a mtd yardmachine 8/26
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it run a few times like that and it will flush the gunk out of the jets...but most of the time you will need to rebuild the carburetor. If the mower is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit, because the diaphragm will get hard and that will cause it to be hard to crank. When you clean your carburetor and remove the jet screws, count the number of turns it takes to seat the jets from their original position. That way when you go to put the jets back in, you know how many turns they were in/out. Please rate me, Thanks Good Luck, I hope this helped
Posted on Dec 24, 2009
Testimonial: "thanks thats a great idea, I am planning on doing it asap. "
SOURCE: push mower starts, then dies, ad nauseum
i have a 21",4,5 hp yard machine with a briggs
Posted on Aug 26, 2010
  • 130 Answers
SOURCE: I have a MTD Honda Lawnmower that is having idling
Generally this indicates a "lean" condition in the carburetor and there are no adjustments. Depending on your abilities, the best fix is to remove the carburetor and clean all the metering passages/jets. In some cases you are better off just replacing the carburetor. I have seen some Honda carbs. as low as $15-$20. Hope this helps to some degree.
Posted on Mar 08, 2011
#1 Taper
  • 1040 Answers
SOURCE: MTD Briggs and Straton 22" Mower Wont Start Brand
You probably have dirt in the carburetor. Or, you may have water in the fuel. As long as you have spark, then there is nothing else that it could be. Unless you have taken it apart already; have you done this?
Jim
Posted on Aug 17, 2011
Where is the choke on a Brigg-stration model 580-752920 engine?
This particular model is called a readystart engine, they do NOT have a primer or choke, if you are having fuel troubles starting there could be a blockage in the carburettor or fuel filter.
Hope this helps
Brad
Jul 28, 2014 | Craftsman 2700 PSI Briggs Stratton...
Help, need to start a briggs and stratton 158 mower, and can't. not mine, so not sure of its quirks, also not a lawnmower person, use a brushcutter normally. lawnmower in good condition, got oil and...
after trying to start it a bunch of times, take spark plug out and see if it's wet with gas.
All mowers start with throttle High and with the choke on OR if it has a primer bulb, you have to prime it until you see gas in the bulb
Aug 28, 2013 | Briggs & Stratton Garden
How to start mower MTD 12A568Q118/700
Prime 3 times with choke on then pull and start.
May 31, 2012 | Mtd Yard Machines 158cc Briggs and...
I cannot remember how to start my tiller
This Could be a problem? Turn the fuel on, place throttle lever to choke, prime if available and pull cord. when running move throttle to run. Good Luck, your gonna need some!!!!
Apr 20, 2011 | Mtd Products Yard Machines 158CC Tiller
My 3 year old Yard Machine 139cc started (choke out), but then began running excessively fast after pushing the choke back in. A few weeks later, it still started (choke out) but now ran very fast even...
Check the carburetor see if all the bolts are tight.check the cylinder head gasket take off plug wire make sure it is away from plug so it wont start. Pull start rope can you hear air being pulled into the engine? if so the head gasket has ruptured or head bolts came lose. Ensure all parts are tight. Ensure fuel lines are not clogged. Check fuel level.
Sep 11, 2010 | Yard Machines 11A54MC006 21Inch 139cc MTD...
Is there a choke setting and throttle setting for best results in getting the MTD yarde amchine started?
Most of the small outdoor power equipment that I have used takes the following to start:
1. Prime 6-8 times, or whatever the manual calls for.
2. Choke the carb to full choke.
3. Pull starter rope. It may sputter and die.
4. After it sputters and dies, put the choke on 1/2. Pull a time or 2 more and should start. Run like that 10 seconds or so, then take choke all the way off.
Oct 30, 2009 | Mtd Garden
Lawn mower wont start
I have the same mower and I have the choke assembly complete, I will take a picture for you if you want to show you what should be there? Mine wont start at the moment wondering wether its the magneto
stu
Jun 27, 2009 | Garden
Tiller won't stay running
If you choke or prime the engine, it starts up for a second or two and dies, the carburetor need to be cleaned/repaired.
May 25, 2009 | Mtd Products Yard Machines 158CC Tiller
Lawnmower wont start
May 23, 2009 | Mtd 22" Yard Machine Push Mower
Mtd 22" Yard Machine Push Mower Logo
56 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
