Question about Ovens
Chef balmain fan forced wall oven
How do you get at the tension springs holding the oven door closed
4 Suggested Answers
SOURCE: I have an old Chef Balmain fan-forced wall oven.
just reset it and it'll stop flashing the help sign. i am just wondering if you still kept your ovens specifications, if you did, would you be able to help me as to the dimesions of this oven. i have the same oven and it died yesterday. i want to buy a new one and wants the measurement so that the new one that i'm looking for woiuld fit exactly in the old one's spot. thanks,
Posted on May 20, 2009
  • 1531 Answers
SOURCE: Wall oven door hinge springs
YOu will have to replace the door hinges.The part number you will need is 318024714 should run about thirty dollars for the set.
Posted on Dec 14, 2010
SOURCE: manual for chef select fan
David, I had the same problem. Try viewing this video - it worked for me.
best regards
Bob
http://www.ehow.com/video_7508261_remove-oven-door.html
Posted on Jan 01, 2011
I recently had a small spring go on the oven door, but before I could put it in, the left side started sticking towards the open position. It is getting harder to open and close now, even with the spr
I would look for something more like a larger spring that the small spring was regulating. The door being askew would suggest that there is some tension that is no longer in place.
Jan 14, 2015 | Blodgett Ovens
I have a Bakers pride y-600 oven . What is the best way for top door to be taken off ??
On the left side, remove the knobs and cover. The spring holding the door closed needs to be removed. Have someone hold the door closed while removing the door spring. Now let the door open and you will see two screws holding the door to the door rod assembly on the left side. These screws are usually 9/16. After removing the two screws, the door will pull off the door pin that is located on the right side.
Oct 24, 2013 | Bakers Pride Y-600 Gas Oven
Hi the right hand hinge of the door has popped out whilst I was trying to move the oven using the door handle as leverage. The door is now wonky when closed as the hinged has popped out. Help!
All oven door typically lift off the hinges by design. If you open the door to what is referred as the broil position. You know when the door stops about 4 to 6 inches open at the top. Then do the following.
1. Lift the door up completely off the opposite hinge still in place and remove. Set the door aside carefully as if has glass window, you do not want to break.
2. Then set both hinges at the broiler stop position. If one is all the way in to door fully closed position pull it out with your hand or with pliers till it stops @ broiler position. If all the way down as if door was fully open, lift hinge until it stops at broiler position. CAUTION- THE HINGES ARE SPRING LOADED AND CAN SNAP BACK INTO FULLY CLOSED POSITION. You can use a heavy glove or if you have an oven mitten, that can work to protect your fingers. DO NOT GET YOUR FINGERS BETWEEN HINGE AND OVEN OR CAN PINCH FINGERS.
3. Now carefully lift the door over the hinges set at the broiler position. Careful not to bump them when doing so or can snap closed. If does, reset hinge to broiler position and repeat. Works best to hold door at angle that door is when in broiler position. Once you have them started evenly, you should be able to fully slide down back onto both hinges.
4. If one of the hinges no longer has spring tension you have to reattach the spring. You can usually access spring if needed by removing the bottom drawer.
Aug 27, 2011 | Ovens
We have a classique oven and it wont close properly. It stays open about 25-30mm can you please give us advice? thanks
I presume the gap you are talking about is at the top of the oven door. If so, this means that the door springs are worn/lost their tension. The only way to fix this is to get the springs replaced.
Feb 13, 2011 | Ovens
Unable to remove oven door for cleaning
Click on the link below to watch a video that explains how to remove the oven door on most modern ovens.
Jan 10, 2011 | Ovens
Oven door won't close completely
You will probably have to replace the springs I doubt if they can ve fixed. you can open the door all the way and you will see a hole in the spring just inside the door. you can stick a nail in that hole, both springs that will hold the door open and you can lift the door out and check the springs I will tell you to have patience its not easy.
Apr 21, 2010 | Kenmore 47702 / 47704 / 47709 Electric...
The door hangs loose. so much so that it feels as though the heat is escaping
You need new door closing hardware. The springs that hold tension
against the door to keep it closed are worn and need to be replaced.
Feb 10, 2010 | Ovens
The lower door does not close firmly. It seems like the spring load is weak. Is there a way to improve the spring tension? I have model CM302ZS (Microwave/convection oven on top and convection oven on...
There is no provision made for adjustment of springs,
I'm afraid the only solution is to replace both door springs.
Trust this helps solve your priblem.
Dec 21, 2009 | Thermador SC302T Electric Double Oven
I am unable to have the door close fully
Sometimes those springs hang on a hook with "notches" so that you can increase the tension by moving to a higher notch. If they don't have any adjustment on them, and you just put a replacement spring on I'd start looking other places for the problem first. If you got the closest springs they had at the hardware store, then you can increase the tension by curling down (thus shortening) the hook ends of the spring with long nose pliers. On a strong spring like an oven spring this will be kind of difficult.
Make sure there isn't any rubbing or other problem going on with the hinges... sometimes just a couple drops of 3 in 1 oil will do the trick.
Nov 14, 2008 | Jenn-Air JJW8130D Electric Single Oven
Ovens Logo
27 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
