Question about Motorola Mobility H700 Wireless Headset
Motorola D&B H700 Version... i cant remember the password...
I recently changed my phone from an MDA to an HTC. My previous phone was the one i had my bluetooth set up on and i recently tried switching to my HTC but i forgot the password it came with (came with the box and box is already thrown away...) Is there a generic password i can use so i can finally use my bluetooth or is there anyway to connect without having to put a password... or any alternatives...?
  • jroker Nov 21, 2007
    it work with my older phone and the password was 9999 now i try to enable it with another phone and it doesnt work
  • Anonymous May 29, 2008
    password
I have a Touch HTC sprint want to connect my h700 bluetooth
Posted on Jul 01, 2008
  • Johnmar Jul 01, 2008
    can any one help me..
You could always try 0000 as the pssword
Posted on Sep 02, 2007
H700 reset or default password for MDA tmobile
Already found the solution. Followed an instruction that was verbatum VERY AWESOME! Thank you!
Sep 05, 2009 | Motorola Mobility H700 Wireless Headset
Pass key
h700 passcode is always 0000 4x the zeros unless it has been changed by a previous user then it is impossible to guess what it has been changed to. This was sourced directly from www.motorola.com
May 04, 2009 | Motorola Mobility H700 Wireless Headset
Motorola H700 won't pair with LG CU720 phone
You will need to enter pairing mode on your device. The H700 User Manual indicates that you do so by first turning off any previously paired device and opening the headset BOOM. The indicator light should light a steady purple while in pairing mode.
You may not need to turn off your phone if you do not desire this, you may be able to get by turning the blue tooth function off and on, on your phone and attempt to pair again.
Pairing Pin is likely 0000.
Dec 29, 2008 | Motorola Mobility H700 Wireless Headset
Password mda
I would definitely connect to a computer, then copy everything to a folder. Even if you have to reset your phone, you can always put your data back in later.
Aug 28, 2008 | T-Mobile MDA
Password is incorrect
well that is the code to use maybe it was changed , so you should take it back if it is a new one and have it replaced.
Aug 19, 2008 | Motorola Mobility H700 Wireless Headset
Forgot password for Motorolla H700
i did the 000 that didnt work and then i did the 0000 it worked so keep trying
Jul 29, 2008 | Motorola Mobility H700 Headset
Motorola H700 Bluetooth Headset
The password is on the H700 and can't be changed. It is 0000 (that is 4 zeros).
May 24, 2008 | Motorola Mobility H700 Wireless Headset
Need a passkey lost it
The problem you are having with your H700 is not the passkey. "0000" is correct. The problem is the pairing process. I just paired mine after reading this with my blackberry curve.
1. Close the H700.
2. Hold the big button down until you see a lavender light.
3. Open the H700 while still holding the button down.
4. At this point it is ready to be paired. If the light changes color, the H700 has timed out waiting to be paired and you will have to do steps 1 thru 3 again.
5. With the lavender light on the H700 go through the pairing procedure on the blackberry.
Mar 21, 2008 | Motorola Mobility H700 Wireless Headset
Motorola h700
If your running an HTC phone (If have an HTC Hermes) it has Windows Mobile 5 or 6 running the software for the phone.
I made a modification to the windows registry settings.
You will first need to download a registry-changing software:
http://www.breaksoft.com/Blog/Utilities/2005/1/Mobile_Registry_Editor.aspx
Then follow these steps to increase your bluetooth output:
To achieve better Stereo sound change the following values, found the the following keys.
I was able to do this in about 5 minutes.
[HKLM/Software/Microsoft/Bluetooth/A2DP/Settings]
Add new dword, Value name=BitPool; Value data=48 (Decimal)
Modify, Value name=UseJointStereo; Value data=0 (Decimal, Originally 1)
For BitPool:
Microsoft suggests the following bitpool values for optimal buffer sizes.
30 - Low audio quality
40 - Medium audio quality
48 - High audio quality
58 - Excellent audio quality
Chose one you like. I think 48 is good enough.
For UseJointStereo: use 0 instead of 1, then you got the real stereo.
If you run into any problems, please contact me.
Jan 29, 2008 | Motorola Mobility H700 Headset
TRYING TO PAIR THE H700 TO MY TMOBILE WING
Just have to re-pair it.With the H700 BT headsets the pairing mode is different from other BT headsets. to put it in pairing mode you first hold the talk button on the headset until the purple light comes on.Right after the purple light comes on you have to flip open the headset for it to stay in pairing mode. From there you continue through the phone. It will ask for a password; that will be "0000". then connect.
Jan 28, 2008 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
310 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
