Question about Poulan Garden
Pull cord will not return - Poulan Garden
  • 906 Answers
You most likely have a broken return spring.
Posted on Jan 25, 2015
My pull cord won't release, to start engine.
if you cant pull it possible engine failure or debris in recoiler --check and inspect pull cord --remove plug and try to pull if engine turns it was air locked and should be able to start if locked solid have an internal failure -----if cord wont rewind return spring failure ,,rope jammed or debris
Jul 08, 2017 | Garden
The manual recoil starter I pulled starter slowly two or three times and then cord was loose no resistance what is the problem?
Sounds like the starter drive is jammed. Look for a large cog azt the back of the starter cord on the motor, manually push it in the opposite direction to the spin created when the cord is pulled.
Dec 29, 2015 | Garden
Cannot pull plug from machine
plug is either stuck or factory glitch. Returned mine to store and sales guy pulled a new one from the shelf. After pulling the cord on the new
unit it came out. They say its a 23 inch cord. Try pulling harder. If that doesn't work it may be factory glitch. return to store and make sure a
sales person pulls the cord out for you.
Sep 19, 2013 | Cuisinart Coffee on Demand 12-Cup...
Pull cord on homelite ut20006 trimmer
on the side where the pull cord was remove casing pull the cord through the hole on the casing wind the spring back on the strimmer not to tight but tight enough for the cord to return once pulled. Attach the cord onto the spring this will be obvious there is a little hole the cord goes through then pull a bit of cord through tie a nott then pull the cord back so the nott is tight against the spring ,let the spring spring back the gord shoul wind onto the spring reattach the casing and job done hope this helps
Apr 21, 2012 | Homelite Mighty Lite Lawn Trimmer
Hi I just purchased a mower. Briggs 158 and the pull cord is frozen. any ideas?
try taking the spark plug out and pulling the cord with it still out you may be oild fouled. if it pulls then continue pulling for several minutes and return plug
Jul 17, 2011 | Garden
I had to fix the pull cord and know the cord will not return to the housing i cant figure out how to fix
you need to untie the pull cord from the handle... and wind up the srping the wile holing it there fish out the end of the pull cord and retie it to the handle
Dec 13, 2010 | Homelite Garden
Broken pull rope of Mantis Tiller
Remove the starter assembly from the side of the engine. Remove the balance of the old cord from the spool and purchase about 1-meter of replacement cord from a saw shop (it should be nylon, not cotton). Insert the new cord into the center slot/hole in the spool, melt the end, and tie an overhand knot. Wind the cord around the spool several turns in the same direction as the old cord, then pull on the cord to wind the return spring inside the spool. Wedge the spool to prevent rewinding, then continue to wind the cord until about 8-10 inches are left. Feed the cord end through the cord port and into the handle. Melt the cord end, then tie an overhand knot and pull the knot back into the cavity in the handle. Remove the spool wedge and test the pull of the cord--it should pull out smoothly and return fully without slack. Hope this helps!
Dec 11, 2010 | Garden
Pull string won't recoil
Sounds like the return spring has either broken or come loose from an anchor point. Remove the entire starter mechanism from the saw and pull at the cord. The problem should be evident once you can see what is happening. It may be a kink formed in the cord that prevents return. Good luck!
May 23, 2010 | Poulan 18" Wild Thing Chainsaw
Pull cord is out and wont return. unable to crank stilh fs 45 we
Could be several things including a broken return spring. If you are not experienced with these springs please take it to a reputable shop to avoid any personal injury.
Jun 09, 2009 | Garden
Recoil not returning rope when pulled
There is a spring inside the pull cord housing that makes the cord come back in, it probably undid itself, remove the housing cover and rope assembly and you will see the spring, you need to retighten it and place everything back. hope this helps
May 31, 2009 | Ardisam 5.5 Hp Rear Tine Rototiller
Garden Logo
67 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
