Question about Celestica A8440 Server
Windows Server wont load
For some reason, when I try to install W2K3, the OS does not detect and Hard drives. I configured a raid 5 Array and the bios does detect it. Any suggestions?
    Scholar:
  • 133 Answers
You need to install the raid drivers during the OS installation otherwise the setup program will not recognise it. At the beginning of the setup, just after the black screen disappears and the setup screen appears, it will say at the bottom: "Press F6 if you want to install third party RAID / SCSI drivers" or something along those lines. That's where you dive for the F6 button and install the drivers from floppy disk. I'm sure you know where to get the drivers from, if not, do reply and ask. Good luck!
Posted on Sep 07, 2007
I have ML350 G3 Server SA 532 and 2 HDD SCSI, W2K. I want intall RAID 1 Can I help me???
unable to understand your question.
If you want to configure raid 1 and install OS freshly then follow these steps.
1) make ready all the required h/w.
2) Swith on the server.
3) when post starts reading SA532 controller press F8 button .
4) you will enter into Raid card bios.
5) select View to know any existing logical drive.
6) select Create logical drive,select both hdd's by pressing space bar.
7) press F8 to confirm changes,save and exit.
8) Enter into bios and set the boot controller order smart array controller as 1st.
9) press escape button and restart the server.
10) boot with cdrom and proceed for os installation.
6)
Jan 19, 2011 | HP Compaq ProLiant ML350 G3 Server
I want to install a new scsi but when my os windows small business server 2003 it gives me "setup either detected multiple disk in your machine that are indistinguishable or detected raw disk(s). Setup has...
using the ACU (array configuration utility) create a raid 0 with this drive after the hard drive is being formatted and is configured as raid 0 (no redundant) restart the server and the hard drive should be detected as a new logical volume with a assigned letter "D" "E"
ACU
Jul 30, 2010 | HP ProLiant ML370 G3 Server
Hard drive not detected. When i trying to install Win 2003 Server Std edition. It does not detect the hard drive.
you will need to download the RAID drivers from the Dell website
http://support.dell.com/support/downloads/download.aspx?c=us&cs=19&l=en&s=dhs&releaseid=R74082&SystemID=PWE_PNT_P3C_2450&os=WNT5&osl=en&deviceid=1374&devlib=0&typecnt=5&vercnt=7&formatcnt=2&fileid=126163 and load them onto a floppy drive.
Then when installing the server press F6 to install other drivers this will load the PEC drivers and W2k3 will then see your drives
Do not try to load the drivers from a USB as W2k3 is "preset" to only accept drivers from a floppy drive unlike WIndows server 2008
Hope this helps
Jul 22, 2010 | Dell PowerEdge 2650 Server
New install scsi hard disk no detect in ibm x3400 server
you will need to add the new drive to your array bbfore it will how up to be formated do this throught the array configuration util
Regards Al "alstech"
May 26, 2009 | IBM x3400 Server
SATA RAID Controller Card Problem?
You are almost there. Go into your BIOS and enable RAID. Then your raid bios should show up on next boot.
Feb 15, 2009 | Intel Motherboard
Ugrade of DL380 G4 Server HDD Raid Array 36GB --->146GB Required
Do a ghost on the first hard drive install ghost on new hard drive and replace, I can provide more details on procedure just ask
Jul 25, 2008 | HP Compaq ProLiant DL380 G4 Server
Run Compaq Array Configuration Utility
Hi Foambob,
Try all means to get a smartstart CD.
Normally new version will be able to use on older hardware , but no guarantees.
I have always found it easier to use smartstart CD auto mode.
You can also do the install and then run ntssd to update all the drivers etc., but I don't recommend it for novices. Use the auto mode , it takes longer but safely and surely.
Good luck
May 21, 2008 | Compaq ProLiant 5500 Server
Drive array problem
Hi Nick ,
As of now you can Select "F2" to accept data loss and re-enable logical drive. This Load OS Normally .
It seems that one of the HDD in the RAID 5 has failed , Did you notice any LED indications like red or amber on the HDDs ?? if so get that hdd replaced . Make sure the Failed HDD is replaced .
You can run the Array Diagnostic Utility from HP System tools to check the Failed Drives and also frimware version of the controller . If the frimware is not latest Update it from HP website. DL380 G4 should have Smart Array 6i controller .
Hope This was Helpful
cheers :)
May 17, 2008 | HP Compaq ProLiant DL380 G4 Server
Xseries 346 wont boot
You don't say whether or not your os is on the RAID 5 partition. Assuming that it is (for performance reasons, this is not recommended) then you should check to see if you have the option of configuring a separate raid configuration on your raid card (e.g. do you have a card with more then one RAID channel?) If this is so, I would create a separate RAID 1 array and install the OS just on that. Then you can mount the RAID 5 array with your data intact. Once you're up and running, you can remove the old OS partition, as it's no longer needed.
Apr 02, 2008 | IBM xSeries 346 Server
Celestica A8440 Server Logo
114 people viewed this question
Top Celestica Computers & Internet Experts
David Payne
David Payne
Are you a Celestica Computer and Internet Expert? Answer questions, earn points and help others
