Question about Cobra 148 GTL 120-Channels Base CB Radio
Low sound on incoming
I have little sound coming in turned all the way up in. & ext. have not checket out going yet . can a bad ant. line be the prob.?
  • 1,139 Answers
Have you checked your squelch control? try turning it completly counter clockwise this should un-squelch your receiver and increase the sound, however this might also be a sign of poor reception which would indicate a bad anntena, poor grounding or coaxial cable. Check and or replace these items before continuing. If replacing these do not help your situation then the unit itself has a problem. I would suggest that you take it to a radio repair shop and get the work done by a professional, since there are not user serviceable parts in the device.
Posted on Sep 04, 2007
My engine over heated from lack of coolant, now all my cool ant is leaking out fast
check for a bad head gasket, radiator, hoses etc. or a bad soft plug. if water in oil headgasket is bad!!
Apr 02, 2014 | 2006 Chevrolet Trailblazer Ext
Static on Powering on
You can start out by resoldering all poor solder connections and look for bad capacitors they will be puffed up on Top.
Oct 01, 2012 | Mitsubishi WS-65907 65" Rear Projection...
When calls come into the office ext. 10 rings. It's the receptionist's desk. However ext. 29 rings too. How can I stop ext. 29 from ringing on all incoming calls?
Changing ringing on a Partner system is done on either ext 10 or 11.
At one of those ext's press the feature key and "00"
Next press the left hand intercom twice
The display should say system programming
Press the right hand intercom once. The display should say Central telephone Programming.
Enter in the extension number that you want to program.
Press the line that you want to ring.
A solid light on the line means immediate ringing
A slow flashing light means delayed ringing (meaning the phone will wait 3 rings before starting to ring.)
A fast flashing light means no ringing.
When finished with that station press the right hand intercom and enter in the next extension to program and set ringing accordingly.
Press feature "00" to logout
Oct 26, 2010 | AT&T Lucent MLS-12D Phone
Will not receive incoming fax. Everything tests OK
First, Connect the Phone line in Line 1 EXT at back of printer
Check the No. of Rings on your Answer machine.
If you have 4 Rings set on Answer machine then you need to set 6 Rings on the printer ( as simple 2 rings more than your Answer machine )
And you need to turn off ECM on the Printer setup
Press Setup button
Scroll till you find Fax Settings - Press OK
Choose Rings to Answer - Set it - 6 ( based on the Rings on Answer machine ) - Press OK
Check for ECM - Error Correction Mode - Press OK
Turn it OFF - Press OK
Check for Auto Answer option - Turn it ON too.
Try to receive Fax.. it should come thru.
Jul 01, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
During incoming call the line will go to others extension line.
Consult an expert he will fix it bcos normally they wont let go their codes.
Rate this
Apr 06, 2009 | Panasonic KX-T7730 Corded Phone
Change the amount of rings
On ext 10 press feature 00, left intercom twice, #506, mode 1, line 01, press 3.
Do this for all of your lines
Dec 02, 2008 | Lucent PARTNER18 Corded Phone
Very very low sound/output
Helle there!
1) check your setting for sound to (2 way speakers)
2) Setting for Volume in control panel.
3) connector may be you need a little expantion from radio shack gold ext.
4) be sure you got sound from headphones !! **
Go it!
Jul 31, 2008 | Philips SBP1100/37 Portable Speaker System...
Cobra 148 GTL 120-Channels Base CB Radio Logo
Top Cobra Radio Communications Experts
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
