Question about Toysmith Mini Mars Mud
Remove mars mud from clothing - Toysmith Mini Mars Mud
Build up of dirt in tub making clothes dirty... How do I clean inside of machine?
If you use powder detergent ( clay carrier) the build up is from undissolved powder ( clay)
It forms cakes between the spin tub and the outer bowl
The fix is to pull the washer apart and physically remove the caked up mud from all parts of the machine
The prevention of future mud is to use liquid detergents rather than powders
It works like this powder detergents have a small percentage of actual detergent in use and that is dried onto a clay base as a transporter agent
In the wash , the detergent is released but the clay will not dissolve
Most is pumped out with each spin but a certain amount remains , dries and starts the dirt process through the clothes
With liquid detergents there is the same amount of actual detergent but the carrier is water and that is diluted in the spin and completely flushed away
Dec 30, 2015 | Washing Machines
Tip
Taking care of your Cloth-Top
Do not wash the cloth top except when needed, and then use only RaggTopp Cleaner. Vacuum the top before washing your car. be careful to not get any car wash mixture on the top as it will remove some of the protectant (dish detergent will remove all of it!). Routine cloth top cleaning is vacuuming with a brush attachment. This should be done before each car wash and after driving in dusty areas. Washing should be done only if the top has become dirtied with bird droppings, tree sap, soot fallout, mud, etc.
on May 19, 2008 | 2001 BMW Z3
How do you remove bad odor from leaving dirty water in the machine
odor is from bacteria so any product that kills bacteria would be a help
try filling the tub as in a full wash , adding a cup full of bleach and running the wash cycle ( no clothe just water)
If you use washing powder as a detergent , there will be a build up of detergent mud under the wash bowl and the bacteria will be living in that mud
Aug 28, 2015 | Washing Machines
How do i remove the scratches from my Harman Kardon Aura?
Do not use any chemical reagent as it could mar the surface all the more using a damp soft cloth could help
Jun 22, 2015 | Harman Kardon Audio Players & Recorders
My clothes are coming out with brown marks, even if it is just hand washing being spun only.
you may have to remove the agitator and clean out the mud from under it
It may be a failed seal on the shaft and the gear box oil is being forced up the shaft and into the cloths.
The mud is from washing powder ( basic clay) that will not properly dissolve or be removed when the empty cycle is operating
If that is the case change over to liquid detergents
Apr 07, 2015 | Washing Machines
Get mars mud out of clothes
Use Rubbing Alcohol (70% Isopropyl Alcohol) from the drugstore. It is the easiest way to remove Mars Putty from natural fabrics and hair.Do a spot test first on a non-visible part of fabric to ensure the alcohol will not cause further damage. Liberally pour the rubbing alcohol onto the affected area. The Mars Putty should liquefy and become easily removed with a paper or cloth towel.
If your Mars Putty has adhered to a synthetic fabric such as nylon or polyester, Rubbing Alcohol may damage the fabric. Try WD-40 to loosen the Mars Putty and remove it from the surface.
If all else fails, take your garment to the dry cleaners and let them know your stain is silicone based.
Jun 15, 2014 | Toysmith Mini Mars Mud
Glasses
use toothpaste rub a small amount on the scratched lens depending on how deep the scratch is rub the toothpaste over the scratch until the scratch is repaired.
Glass lenses are delicate and can be easily scratched.
These scratches mar vision beyond the lens, and can sometimes obstruct vision completely.
Prevention is the best method to keep glasses clear, but accidents can occur.
Luckily, there are several ways to quickly and inexpensively remove scratches from glass lenses.
These methods include using toothpaste, baking soda, windshield fluid and vehicle wax.
Apply a small amount of toothpaste on a soft, cotton cloth.
Rub the toothpaste onto the lens using small, circular motions.
Continue wiping for about 10 seconds and rinse with cold water.
For deep scratches, the method may need to be repeated.
Mix two parts baking soda with one part water to form a thick paste.
Use the cotton cloth to apply the paste to the lens, rubbing in a circular motion.
Rinse afterward and dry with a separate cloth.
Once again, this step may need to be repeated for stalwart scratches.
Apply a small amount of windshield fluid to a soft cloth, and polish the glass lens for several seconds.
This is more useful for light scratches, and is usually not effective against deep, prominent blemishes.
Use a clean cloth to buff vehicle wax onto the glass lens, once again moving in a circular motion, and continuing until the scratches have been removed.
Use several cloths, as the wax can adhere to the fabric, marring its performance.
Purchase an eyeglass polishing kit from a local optometrist.
These kits usually contain a polishing fluid and a soft cloth.
They are ideal for removing scratches from small glass lenses on glasses, cameras, telescopes and more.
They can be purchased for $10 to $20 and include easy-to-understand directions.
May 17, 2013 | Optics
Mars mud is dried out. how do i make gooey again?
Put some water in it/on it and hit it whith a spoon and start mushing it
Jul 29, 2011 | Toys
Amana Washmachine (not all water removed during spin) ALW780QAW
you may have blockage in the drain pipe several feet from washer. if you can run spin cycle with hose in different location ex. tub,sink or outdoors. if this works run long snake down washer drain pipe to clean gypsum residual.
Jan 28, 2008 | Amana ALW780QA
Toysmith Mini Mars Mud Logo
42 people viewed this question
Top Toysmith Toys Experts
richie46
Are you a Toysmith Toy Expert? Answer questions, earn points and help others
