Question about Globe Union Lavatory Faucet
Danze bathroom sink faucet #LM80906 (B125) require repacement cartridge c/w ball
I need replacement part for bath sink cartridge 4570
The Moen 1225 or 1200 cartridges are the same except the 1200 is brass in stead of plastic. They will fit most Moen single handle faucets. If it is a two-handle faucet, the 1224 cartridge will fit most two-handle models unless it is a fancy widespread faucet more than about 15 years old. I don't know the model numbers for those cartridges. All of these cartridges require a removal tool if you can't get them out with a pair of pliers.
Dec 09, 2011 | Moen Soap & Lotion Dispenser 3910S
Water is dripping out the back of the the Danza 61/9 kitchen faucet
Just in case you need to do so.
  1. Turn the water off. The water control knob is located under your sink and is connected to the drain. Turn it counterclockwise to turn off the water.
  2. 2
    Open the faucet to relieve any differences in pressure. Pull up on the faucet as you would if you were turning it on.
  3. 3
    Plug the drain of the sink with its stopper to prevent any parts from going down it.
  4. 4
    Turn the faucet handle sharply to one side to reveal a small cover plate. Pry the plate off carefully with a flat-bladed screwdriver.
  5. 5
    Unscrew the screw that is located behind the cover plate with a 4 mm allen key.
  6. 6
    Lift the handle off and remove the cap beneath it.
  7. 7
    Firmly grip the exposed cartridge with your hands and pull up to remove it.
Read more: How to Remove the Cartridge from a Danze D403412 ' eHow.com http://www.ehow.com/how_7640485_remove-cartridge-danze-d403412.html#ixzz1D76xWEgn I your case I think all you need are new o-ring seals on the spout. once you have the handle off and have gotten to the cartage grab the spout and turn back and forth while pulling up and remove the spout you will see the o-rings. I would get the repair kit before you start. The video below is not your brand faucet but the o-ring replacement is about the same. http://www.youtube.com/watch?v=AipEYoYiIhc
Feb 05, 2011 | Danze D403412 Melrose Single Handle...
We do not have book on the kitchen faucet which was purchased by a previous owner. Looks just like the Danze D306357BN. It is leaking from the first joint above the base. A plumber could only tell us that...
there are several O-rings inside the spout assembly. 3 that I know of from memory.<br /> <br /> here is a link to the PDF parts breakdown to show your plumber. also that faucet is for the bathroom sink.<br /> <a href="http://www.danze.com/product_details.asp?g=2&amp;mg=5&amp;id=D306357BN">http://www.danze.com/product_details.asp?g=2&amp;mg=5&amp;id=D306357BN</a><br /> the link to the PDF is at the bottom of the page "illistrated parts list" <br /> <br /> here is the link to the kitchen faucet. just click on the "illistrated parts list" to get the breakdown.<br /> <a href="http://www.danze.com/product_details.asp?g=1&amp;mg=1&amp;id=D414357">http://www.danze.com/product_details.asp?g=1&amp;mg=1&amp;id=D414357</a><br /> <br /> if neither one of these is your faucet, just continue looking through till you find yours, and call a different plumber.<br /> <br /> hope that helps<br />
Aug 31, 2010 | Danze Plumbing
Have a 4 inch center moen that has solid handles with a decorative piece on the bottom. How do I remove the handles?
if it is like your picture then you have a monticello faucet. The handles unscrew. The ball looking part of the handle unscrews just like you are loosening a nut. Then you will be able to get to the cartridges,
Apr 10, 2010 | Moen Bathroom Sink Faucet - 4-inch...
My faucet drips and i believe there is no way to change the washer out. What can I do?
danze has a cartridge, if you have two handles you can turn the water off under the sink and isolate which one is leaking if you cant figure it out you can just take both of them out and have them both replaced. if it's a single handle there will just be one cartridge in there. you will have to remove the handle and a few other things and it should just pull right out of there. if you call danze they might send you some free cartridges if you ask nicely!
Aug 05, 2009 | Danze Plumbing
No water to single hole faucet after installation
the cartridge has trash in it.remove and clean,will work after that is done.
May 24, 2009 | Danze D222158 Parma Single Handle Hole...
How do you remove the areator from a danze bathroom faucet
They usually just screw off counter clockwise. You may have to purchase a special wrench that has a plastic protective cover so you can grip it to remove it. Or you can try using a towel with a pair of pliers to remove it.
Apr 10, 2009 | Danze D316440RBT Fairmont Two Handle Wall...
Kitchen Faucet Replacement
Option 1 ; Cap off the sprayer.  Option 2 ; Relocate the air gap as high as possible under the sink but then you have no drain under it in case it backflows (it is really a vacuum breaker ,  one way check valve) Option 3: Take back the faucet and get one of those that the spout is also the sprayer.
Jan 30, 2009 | Danze D316440RBT Fairmont Two Handle Wall...
Globe Union Lavatory Faucet Logo
643 people viewed this question
Top Globe Union Home Experts
Donni Steen
Tom Chichester
Are you a Globe Union Home Expert? Answer questions, earn points and help others
